5KP30CA
5KP30CA
    SUNMATE(森美特)
    R-6
    ESD抑制器/TVS二极管 反向截止电压(Vrwm) 30 击穿电压(V) 33.3 R-6
5KP30CA 数据手册
5KP5.0A(CA) - 5KP190A(CA) AXIAL LEADED TRANSIENT VOLTAGE SUPPRESSORS DIODE VOLTAGE RANGE: 5.0 - 19 0 V POWER: 5000Wa t t s Features ! Uni- and Bi-Directional Versions Available ! ! Excellent Clamping Capability ! Plastic Case Material has UL Flammability Classification Rating 94V-O Fast Response Time A A B Mechanical Data ! ! Case: JEDEC R-6 Molded Plastic Terminals: Axial Leads, Solderable per ! MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch ! Weight: 2.10 grams (approx.) C D R-6 Dim Min A 25.4 — B 8.6 9.1 C 1.2 1.3 Max All Dimensions in mm Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol Value Unit Peak Pulse Power Dissipation at TA = 25°C (Note 1, 2, 5) Figure 3 PPPM 5000 Minimum W Peak Forward Surge Current (Note 3) IFSM 400 A Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 1 IPPM See Table 1 A Steady State Power Dissipation (Note 2, 4) PM(AV) 8.0 W Operating and Storage Temperature Range Tj, TSTG -55 to +175 °C Note: 1. Non-repetitive current pulse, per Figure 1 and derated above TA = 25°C per Figure 4. 2. Mounted on 20mm2 copper pad. 3. 8.3ms single half sine-wave duty cycle = 4 pulses per minutes maximum, 4. Lead temperature at 75°C = TL . 5. Peak pulse power waveform is 10/1000µS. 1 of 5 www.sunmate.tw TYPE (UNI) (BI) Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Current VRWM (V) VBR MIN(V) VBR MAX(V) IT (mA) Test Maximum Clamping Voltage @IPP VC(V) Peak Pulse Current Reverse Leakage @VRWM IPP(A) IR(uA) 5KP5.0 5KP5.0C 5.0 6.40 7.55 10 9.6 520.8 1000.0 5KP5.0A 5KP5.0CA 5.0 6.40 7.25 10 9.2 543.5 1000.0 5KP6.0 5KP6.0C 6.0 6.67 8.45 10 11.4 438.6 1000.0 5KP6.0A 5KP6.0CA 6.0 6.67 7.67 10 10.3 485.4 1000.0 5KP6.5 5KP6.5C 6.5 7.22 9.14 10 12.3 406.5 500.0 5KP6.5A 5KP6.5CA 6.5 7.22 8.30 10 11.2 446.4 500.0 5KP7.0 5KP7.0C 7.0 7.78 9.86 10 13.3 375.9 200.0 5KP7.0A 5KP7.0CA 7.0 7.78 8.95 10 12.0 416.7 200.0 5KP7.5 5KP7.5C 7.5 8.33 10.67 1.0 14.3 349.7 50.0 5KP7.5A 5KP7.5CA 7.5 8.33 9.58 1.0 12.9 387.6 50.0 5KP8.0 5KP8.0C 8.0 8.89 11.3 1.0 15.0 333.3 10.0 5KP8.0A 5KP8.0CA 8.0 8.89 10.23 1.0 13.6 367.6 10.0 5KP8.5 5KP8.5C 8.5 9.44 11.92 1.0 15.9 314.5 5.0 5KP8.5A 5KP8.5CA 8.5 9.44 10.82 1.0 14.4 347.2 5.0 5KP9.0 5KP9.0C 9.0 10.0 12.6 1.0 16.9 295.9 5.0 5KP9.0A 5KP9.0CA 9.0 10.0 11.5 1.0 15.4 324.7 5.0 5KP10 5KP10C 10 11.1 14.1 1.0 18.8 266.0 5.0 5KP10A 5KP10CA 10 11.1 12.8 1.0 17.0 294.1 5.0 5KP11 5KP11C 11 12.2 15.4 1.0 20.1 248.8 5.0 5KP11A 5KP11CA 11 12.2 14.0 1.0 18.2 274.7 5.0 5KP12 5KP12C 12 13.3 16.9 1.0 22.0 227.3 5.0 5KP12A 5KP12CA 12 13.3 15.3 1.0 19.9 251.3 5.0 5KP13 5KP13C 13 14.4 18.2 1.0 23.8 210.1 5.0 5KP13A 5KP13CA 13 14.4 16.5 1.0 21.5 232.6 5.0 5KP14 5KP14C 14 15.6 19.8 1.0 25.8 193.8 5.0 5KP14A 5KP15 5KP14CA 5KP15C 14 15 15.6 16.7 17.9 21.1 1.0 1.0 23.2 26.9 215.5 185.9 5.0 5.0 5KP15A 5KP15CA 15 16.7 19.2 1.0 24.4 204.9 5.0 5KP16 5KP16C 16 17.8 22.6 1.0 28.8 173.6 5.0 5KP16A 5KP16CA 16 17.8 20.5 1.0 26.0 192.3 5.0 5KP17 5KP17C 17 18.9 23.9 1.0 30.5 163.9 5.0 5KP17A 5KP17CA 17 18.9 21.7 1.0 27.6 181.2 5.0 5KP18 5KP18C 18 20.0 25.3 1.0 32.2 155.3 5.0 5KP18A 5KP18CA 18 20.0 23.3 1.0 29.2 171.2 5.0 5KP20 5KP20C 20 22.2 28.1 1.0 35.8 139.7 5.0 5KP20A 5KP20CA 20 22.2 25.5 1.0 32.4 154.3 5.0 2 of 5 www.sunmate.tw Reverse Stand-Off Voltage TYPE Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Current Maximum Clamping Voltage @IPP Test Peak Pulse Current Reverse Leakage @VRWM (BI) VRWM (V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) 5KP22 5KP22C 22 24.4 30.9 1.0 39.4 126.9 5.0 5KP22A 5KP22CA 22 24.4 28.0 1.0 35.5 140.8 5.0 5KP24 5KP24C 24 26.7 33.8 1.0 43.0 116.3 5.0 5KP24A 5KP24CA 24 26.7 30.7 1.0 38.9 128.5 5.0 5KP26 5KP26C 26 28.9 36.6 1.0 46.6 107.3 5.0 5KP26A 5KP26CA 26 28.9 33.2 1.0 42.1 118.8 5.0 5KP28 5KP28C 28 31.1 39.4 1.0 50.0 100.0 5.0 5KP28A 5KP28CA 28 31.1 35.8 1.0 45.4 110.1 5.0 5KP30 5KP30C 30 33.3 42.2 1.0 53.5 93.5 5.0 5KP30A 5KP30CA 30 33.3 38.3 1.0 48.4 103.3 5.0 5KP33 5KP33C 33 36.7 46.5 1.0 59.0 84.7 5.0 5KP33A 5KP33CA 33 36.7 42.2 1.0 53.3 93.8 5.0 5KP36 5KP36C 36 40.0 50.7 1.0 64.3 77.8 5.0 5KP36A 5KP36CA 36 40.0 46.0 1.0 58.1 86.1 5.0 5KP40 5KP40C 40 44.4 56.3 1.0 71.4 70.0 5.0 5KP40A 5KP40CA 40 44.4 51.1 1.0 64.5 77.5 5.0 5KP43 5KP43C 43 47.8 60.5 1.0 76.7 65.2 5.0 5KP43A 5KP43CA 43 47.8 54.9 1.0 69.4 72.0 5.0 5KP45 5KP45C 45 50.0 63.3 1.0 80.3 62.3 5.0 5KP45A 5KP45CA 45 50.0 57.5 1.0 72.7 68.8 5.0 5KP48 5KP48C 48 53.3 67.5 1.0 85.5 58.5 5.0 5KP48A 5KP48CA 48 53.3 61.3 1.0 77.4 64.6 5.0 5KP51 5KP51C 51 56.7 71.8 1.0 91.1 54.9 5.0 5KP51A 5KP51CA 51 56.7 65.2 1.0 82.4 60.7 5.0 5KP54 5KP54C 54 60.0 76.0 1.0 96.3 51.9 5.0 5KP54A 5KP54CA 54 60.0 69.0 1.0 87.1 57.4 5.0 5KP58 5KP58C 58 64.4 81.6 1.0 103 48.5 5.0 5KP58A 5KP58CA 58 64.4 74.1 1.0 93.6 53.4 5.0 5KP60 5KP60C 60 66.7 84.5 1.0 107 46.7 5.0 5KP60A 5KP60CA 60 66.7 76.7 1.0 96.8 51.7 5.0 5KP64 5KP64C 64 71.1 90.1 1.0 114 43.9 5.0 5KP64A 5KP64CA 64 71.1 81.8 1.0 103 48.5 5.0 5KP70 5KP70C 70 77.8 98.6 1.0 125 40.0 5.0 5KP70A 5KP70CA 70 77.8 89.5 1.0 113 44.2 5.0 5KP75 5KP75C 75 83.0 105.7 1.0 134 37.3 5.0 5KP75A 5KP75CA 75 83.0 95.8 1.0 121 41.3 5.0 (UNI) 3 of 5 www.sunmate.tw Reverse Stand-Off Voltage Breakdown Voltage Min. @IT Breakdown Voltage Max. @ IT Current Maximum Clamping Voltage @IPP (BI) VRWM (V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) 5KP78 5KP78C 78 86.0 109.8 1.0 139 36.0 5.0 5KP78A 5KP78CA 78 86.0 99.7 1.0 126 39.7 5.0 5KP85 5KP85C 85 94.0 119.2 1.0 151 33.1 5.0 5KP85A 5KP85CA 85 94.0 108.2 1.0 137 36.5 5.0 5KP90 5KP90C 90 100 126.5 1.0 160 31.3 5.0 5KP90A 5KP90CA 90 100 115.5 1.0 146 34.2 5.0 5KP100 5KP100C 100 111 141.0 1.0 179 27.9 5.0 5KP100A 5KP100CA 100 111 128.0 1.0 162 30.9 5.0 5KP110 5KP110C 110 122 154.5 1.0 196 25.5 5.0 5KP110A 5KP110CA 110 122 140.5 1.0 177 28.2 5.0 5KP120 5KP120C 120 133 169.0 1.0 214 23.4 5.0 5KP120A 5KP120CA 120 133 153.0 1.0 193 25.9 5.0 5KP130 5KP130C 130 144 182.5 1.0 231 21.6 5.0 5KP130A 5KP130CA 130 144 165.5 1.0 209 23.9 5.0 5KP150 5KP150C 150 167 211.5 1.0 268 18.7 5.0 5KP150A 5KP150CA 150 167 192.5 1.0 243 20.6 5.0 5KP160 5KP160C 160 178 226.0 1.0 287 17.4 5.0 5KP160A 5KP160CA 160 178 205.0 1.0 259 19.3 5.0 5KP170 5KP170C 170 189 239.5 1.0 304 16.4 5.0 5KP170A 5KP170CA 170 189 217.5 1.0 275 18.2 5.0 5KP180 5KP180C 180 200 253.8 1.0 321 15.6 5.0 5KP180A 5KP180CA 180 200 230.4 1.0 290 17.2 5.0 5KP190 5KP190C 190 211 267.9 1.0 339 14.7 5.0 5KP190A 5KP190CA 190 211 243.2 1.0 306 16.3 5.0 TYPE (UNI) 4 of 5 Test Peak Pulse Current Reverse Leakage @VRWM www.sunmate.tw Typical Characteristics Fig1. Pulse Dearting Curve Fig2. Maximum Non-Repetitive Peak Forward Surge Current Fig3. Pulse Waveform Fig4. Typical Junction Capacitance 5 of 5 www.sunmate.tw
5KP30CA 价格&库存
很抱歉,暂时无法提供与“5KP30CA”相匹配的价格&库存,您可以联系我们找货
5KP30CA
  • 1+2.80000
  • 10+2.64000
  • 30+2.32000
  • 100+2.08000
  • 500+1.92000
  • 1000+1.80800
库存:390
5KP30CA
  • 1+4.78116
  • 10+4.07322
  • 30+3.71412
  • 100+3.36528
  • 400+3.20112
  • 800+3.09852
库存:384
