1N5400 - 1N5408
AXIAL LEADED SILICON RECTIFIER DIODES
VOLTAGE RANGE: 50 - 1000V
CURRENT: 3.0 A
Features
! High Current Capability and Low Forward
Voltage Drop
! Low Reverse Leakage Current
B
A
A
! Plastic Material: UL Flammability
Classification Rating 94V-0
Mechanical Data
C
D
Case: DO-201AD
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: Cathode Band
Mounting Position: Any
Marking: Type Number
Weight: 1.1 grams (approx.)
DO-201AD
Dim
Min
Max
A
25.40
¾
B
7.20
9.50
C
1.20
1.30
D
4.80
5.30
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
@ TA = 25°C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current
@ TA = 105°C
(Note 1)
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on rated load
(JEDEC Method)
Symbol
1N
5400
1N
5401
1N
5402
1N
5404
1N
5406
1N
5407
1N
5408
Unit
VRRM
VRWM
VR
50
100
200
400
600
800
1000
V
VR(RMS)
35
70
140
280
420
560
700
V
IO
3.0
A
IFSM
200
A
@ IF = 3.0A
VFM
1.0
V
Peak Reverse Current
at Rated DC Blocking Voltage
@ TA = 25°C
@ TA = 150°C
IRM
10
100
mA
Typical Junction Capacitance
(Note 2)
Cj
Forward Voltage
Typical Thermal Resistance Junction to Ambient
Operating and Storage Temperature Range
Notes:
50
25
pF
RqJA
15
K/W
Tj, TSTG
-65 to +150
°C
1. Valid provided that leads are kept at ambient temperature at a distance of 9.5mm from the case.
2. Measured at 1.0MHz and applied reverse voltage of 4.0V DC.
1 of 2
www.sunmate.tw
3.0
2.0
1.0
50
75
100
125
150
175
200
IF, INSTANTANEOUS FORWARD CURRENT (A)
I(AV), AVERAGE FORWARD CURRENT (A)
4.0
200
100
10
1.0
0.2
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Forward Current Derating Curve
0.4
0.8
1.2
1.6
2.0
2.4
2.8
3.2
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Typical Forward Characteristics
200
100
1N5400 - 1N5405
100
Cj, CAPACITANCE (pF)
IFSM, PEAK FORWARD SURGE CURRENT (A)
Tj = 25ºC
1N5406 - 1N5408
10
Tj = 25°C
Pulse width = 8.3ms
f = 1MHz
Tj = 25ºC
1.0
10
1.0
10
1.0
100
10
100
VR, REVERSE VOLTAGE (V)
Fig. 4 Typical Junction Capacitance
NUMBER OF CYCLES AT 60Hz
Fig. 3 Maximum Non-Repetitive Surge Current
2 of 2
www.sunmate.tw
很抱歉,暂时无法提供与“1N5408”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39358
- 100+0.30853
- 300+0.26594
- 1000+0.23106
- 5000+0.20561
- 10000+0.19278
- 国内价格
- 1+0.26250
- 10+0.24750
- 30+0.21750
- 100+0.19500
- 500+0.18000
- 1000+0.16950
