8KP36CA
8KP36CA
    TOP-EMC(韬略)
    R-6(P-600)
    ESD抑制器/TVS二极管 P600
8KP36CA 数据手册
8KP12A-8KP43CA Axial Lead TVS Features • Glass passivated chip junction • 8000 W peak pulse power capability with a 10/1000us waveform • Repetitive rate(duty cycle):0.01% • Excellent clamping capability • Very fast response time • Low incremental surge ge resistance P600 • Typical Ir less than han 5uA 择 • High temperature ature soldering solderin guaranteed 260 °C, 40 s 选 Mechanical Data 佳 • Case:Molded plastic over glass passivated junction. 最 Base P/N P/NHE3 - RoHS compliant, high reliability/ automo automotive grade (AEC Q101 qualified) • Ter Terminals:Plated Axial lesds,solderable per J-STD002 and JESD22-B102. 0 VRWM 的 Primary Characteristics 案 12 V to 43V • Mounting Poition: Any 8000 W PD 8.00 W IFSM 600 A Typical Applications 175 °C Use in sensitive electronics protection against voltage transients induced by inductive load switching and -E MC 方 PPPM 技 TJ max. • Polarity: Color band denotes cathode end 科 lighting on ICs, MOSFET, signal lines of sensor units 略 for consumer, computer, industrial, automotive and telecommunication. 韬 Characteristics Maximum Ratings (TA = 25 °C unless otherwise noted) PARAMETER Peak pulse power dissipation with a 10/1000 μs waveform (1) Peak pulse current with a 10/1000 μs waveform (1) Power dissipation on infinite heatsink at TL = 75 °C (Fig. 5) Peak forward surge current 8.3 ms single half sine-wave (Fig. 3) Instantaneous forward voltage at 100 A (2) Operating junction and storage temperature range SYMBOL VALUE UNIT PPPM 8000 W IPPM See next table A PD 8.0 W IFSM 600 A VF 3.5 V TJ, TSTG - 55 to + 175 °C Notes: (1) Non-repetitive current pulse, per Fig. 3 and derated above TA = 25 °C per Fig. 2 (2) Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum 1/4 www.topleve.com 8KP12A-8KP43CA Pin Configuration Pin1 Pin 2 Pin 1 Pin2 (Uni) (Bi) Breakdown Test Maximum Maximum Maximum Stand off Voltage Current ent Clamping Clamp PeakPulse Reverse Voltage VBR(Volts)@IT IT Current Leakage Ipp Current BI-POLAR MIN MAX Vc@IPP IR@VRWM 最 UNI-POLAR 佳 VRWM 选 Part Number Reverse 择 Electrical Characteristics (mA) (V) (A) (μA) 1 19.9 402 1 16.50 1 21.5 372 1 的 (V) 13.30 3.30 8KP13A 8KP13 CA 13.0 14.40 8KP14A 8KP14CA 14.0 15.60 1 23.2 344 1 8KP15A 8KP15 CA 15.0 MC 17.20 16.70 -E 19.20 1 24.4 327.8 1 8KP16A 8KP16CA 16.0 17.80 19.70 1 26.0 307.6 1 8KP17A 8KP17CA 17.0 18.90 21.70 1 27.6 289.8 1 8KP18A 8KP18CA 略 18.0 20.00 23.30 1 29.2 273.9 1 8KP20A KP20 CA 8KP 20.0 22.20 25.50 1 32.4 246.9 1 8KP22A 8KP 22 CA 22.0 24.40 28.00 1 35.5 225.3 1 8KP24A 8KP24 CA 24.0 26.70 30.70 1 38.9 205.6 1 8KP26A 8KP 26 CA 26.0 28.90 33.20 1 42.1 190.0 1 8KP28A 8KP 28 CA 28.0 31.10 35.80 1 45.4 176.2 1 8KP30A 8KP 30 CA 30.0 33.30 38.30 1 48.4 165.2 1 8KP33A 8KP33 CA 33.0 36.70 42.20 1 53.3 150 1 8KP36A 8KP 36 CA 36.0 40.00 46.00 1 58.1 137.7 1 8KP40A 8KP 40 CA 40.0 44.40 51.10 1 64.5 124 1 8KP43A 8KP43CA 43.0 47.8 52.8 1 69.4 115 1 科 方 案 12.0 技 8KP12CA 韬 14.70 0 8KP12A 2/4 www.topleve.com 8KP12A-8KP43CA Ratings And Characteristics Curves (TA = 25 qC unless otherwise noted) 1000 100 90 Percent of Rated Power or Ipp Derating in Percentage % PPPM ̢ Peak Pulse Power - kW 110 100 10 8000W @10/1000μs 80 70 60 50 40 30 20 10 0 0 1 0.1 1 10 100 1000 25 td ̢ Pulse Width - μs 方 10/1000 μs Waveform as defined by R.E.A. td 0 1.0 0 3.0 2.0 125 150 175 200 佳᳔ 选Շ 择 10 100 VBR ̢Reverse Breakdown Voltage (V) 1000 Figure 4. Typical Junction Capacitance 韬 PD - Power Dissipation (W) 8 6 675 60 Hz Resistive or Inductive Load Peak Forward Surge Current IFSM (A) 略 科 技 Figure 3. Pulse Waveform eform Unidirectional @V RWM 100 -E t - Time (ms) Unidirectional V R=0V Bidirectional @VRWM 10 1 4.0 Bidirectional VR=0V 最 1000 的 案 Half Value - IPP IPPM 2 50 Cj ̢ Junction tion Capacitance ( pF) 100 10000 MC IPPM - Peak Pulse Current, % IRSM Peak Value IPPM 100 00 Initial Junction Temperature Figure 2. Pulse Power or Current vs. In TJ = 25 °C Pulse Width (td) is defined as the Point where the Peak Current decays to 50 % of IPPM tr = 10 μs 75 Ambient Temperature - TA (ć) ć Figure 1. Peak Pulse Power Rating Curve 150 50 10,000 4 L = 0.375" (9.5 mm) Lead Lengths 2 0 0 25 50 75 100 125 150 175 600 525 450 375 300 225 150 75 0 1 200 10 100 TL - Lead Temperature (°C) Figure 5. Power Derating Curve Figure 6. Maximum Non-repetitive Forward Surge Current 3/4 www.topleve.com 8KP12A-8KP43CA Package Dimensions Dim Millimeters Inches Min Max Min Max A 25.4 --- 1.000 --- B 8.6 9.1 0.340 0.360 C 1.2 1.3 0.048 0.052 D 8.6 9.1 0.340 0.360 选 择 Tape & reel specification 佳 Out line Per carton (pcs) 300 3K Packing Option Box 方 案 的 最 Taping Reel (pcs) MC Application Note They are able to withstand high levels of peak current while allowing a circuit breaker to trip or a fuse blow before shorting. This will enable the user to reset the breaker or replace the fuse and continue operation. n. For this type operation, it is recommended that at a sufficient mounting surface be used for dissipating ting the heat generated by the Transient Voltage Suppressor uppressor during the transient or over-voltage condition. tion. P8S36A 韬 略 科 技 -E The 8KP series of high power transient voltage suppressors were designed to be used on the output of switching power supplies. These devices may be used to replace crowbar circuits. Both the 5 % and 10 % voltage tolerances are referenced to the power supply output voltage level. Marking Codes Contact Information Contact Information SHENZHEN TOP-FLIGHT TECHNOLOGY CO.,LTD 4th Floor, C Building, Quansen Industrial Park , Bulong Road, Longhua New District, Shenzhen Tel: 86-755-82908191 Fax: 86-755-82908701 Email: kang@topleve.com Website: http://www.topleve.com 4/4 www.topleve.com
8KP36CA 价格&库存
很抱歉,暂时无法提供与“8KP36CA”相匹配的价格&库存,您可以联系我们找货
