RS521S, RS522S
RS521, RS522, RS524
3.6MHz, Rail-to-Rail I/O
CMOS Operational Amplifier
FEATURES
DESCRIPTION
HIGH GAIN BANDWIDTH:3.6MHz
RAIL-TO-RAIL INPUT AND OUTPUT
0.8mV Typical Vos
INPUT VOLTAGE RANGE: -0.1V to +5.6V
with Vs = 5.5V
SUPPLY RANGE: +2.5V to +5.5V
SHUTDOWN: RS521S/RS522S
SPECIFIED UP TO +125°C
MicroSIZE PACKAGES: SOT23-5, SOT23-6
The RS52X families of products offer low voltage
operation and rail-to-rail input and output, as well as
excellent speed/power consumption ratio, providing
an excellent bandwidth (3.6MHz) and slew rate of
1.8V/us. The op-amps are unity gain stable and
feature an ultra-low input bias current.
The devices are ideal for sensor interfaces, active
filters and portable applications. The RS521S,
RS522S include a shutdown mode. Under logic
control, the amplifiers can be switched from normal
operation to a standby current that is less than
1uA.The RS52X families of operational amplifiers are
specified at the full temperature range of −40°C to
+125°C under single or dual power supplies of 2.5V
to 5.5V.
APPLICATIONS
SENSORS
PHOTODIODE AMPLIFICATION
ACTIVE FILTERS
TEST EQUIPMENT
DRIVING A/D CONVERTERS
PIN CONFIGURATIONS
2
3
4
-IN
OUT
1
V-
2
+IN
3
6
V+
NC
1
5
EN
-IN
2
4
3
+IN
-IN
NC
7
V+
6
5
4
V-
8
OUT
1
-IN A
2
+IN A
3
V-
4
En A
5
NC
SOT23-6
SOT23-5
OUT A
+IN
V+
V+
9
OUT B
8
-IN B
7
+IN B
6
En B
14
OUT D
13
-IN D
A
B
10
V-
5
1
RS521
OUT
RS522S
RS521S
RS521
SOIC-8(SOP8),MSOP-8
MSOP-10
RS521B
- IN
3
5
-IN
2
OUT +IN
3
V-
4
V+
4
EN
7
V+
2
8
1
V-
1
+ IN
RS522
RS521S
NC
6
OUT
5
NC
OUT A
-IN A
1
8
V+
OUT A
1
2
7
OUTB
-IN A
2
6
-IN B
+IN A
3
12
+IN D
5
+IN B
V+
4
11
V-
+IN B
5
10
+IN C
-IN B
6
9
-IN C
OUT B
7
8
OUT C
+IN A
3
V-
4
SOT23-5
RS524
A
B+
SOIC-8(SOP8)
SOIC-8(SOP8),MSOP-8
Note: NC indicates no internal connection
A
B
D
+ C
SOIC-14(SOP14),TSSOP-14
REV B.4
1
www.run-ic.com
RS521S, RS522S
RS521, RS522, RS524
ABSOLUTE MAXIMUM RATINGS (1)
Supply Voltage, V+ to V-...............................................7.0V
Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V
Current (2)…………………....…..... ±10mA
Storage Temperature ……….…………… −65°C to +150°C
Operating Temperature ……….………… −40°C to +125°C
Junction Temperature................................................150°C
Package Thermal Resistance @ TA = +25°C
SOT23-5, SOT23-6………………….………………200°C/W
MSOP-10, SOIC-8 …………………….…………... 150°C/W
SOIC-14, TSSOP-14………….……….……………100°C/W
Lead Temperature (Soldering, 10s) ……………........260°C
ESD Susceptibility
HBM …......................................................................5000V
MM ……………………….........………………...……….400V
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance
degradation to complete device failure. Precision
integrated circuits may be more susceptible to
damage because very small parametric changes
could cause the device not to meet its published
specifications.
(1) Stresses above these ratings may cause permanent damage. Exposure to
absolute maximum conditions for extended periods may degrade device
reliability. These are stress ratings only, and functional operation of the
device at these or any other conditions beyond those specified is not
implied.
(2) Input terminals are diode-clamped to the power-supply rails. Input
signals that can swing more than 0.5V beyond the supply rails should
be current-limited to 10mA or less.
PACKAGE/ORDERING INFORMATION
2
www.run-ic.com
RS521S, RS522S
RS521, RS522, RS524
ELECTRICAL CHARACTERISTICS
(At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.)
PARAMETER
CONDITIONS
TJ
RS521S, RS522S,
RS521, RS522, RS524
MIN
TYP
MAX
UNIT
5.5
V
260
86
350
uA
0.8
3
POWER SUPPLY
Vs
Operating Voltage Range
IQ
Quiescent Current/Amplifier
PSRR
Power-Supply Rejection Ratio
Vs=2.5V to 5.5V,
Vcm=(V-)+0.5V
25C
2.5
25C
25C
-40C to 125C
76
69
dB
INPUT
Vos
IB
Input Offset Voltage
Input Offset Voltage Average
Drift
Input Bias Current
Ios
Input Offset Current
Vos TC
Vcm
CMRR
Common-Mode Voltage Range
Common-Mode Rejection Ratio
25C
2
-40C to 125C
Vs= 5.5V
Vs= 5.5V, Vcm
=-0.1V to 4V
Vs= 5.5V, Vcm
=-0.1V to 5.6V
mV
uV/C
25C
1
10
pA
25C
1
10
pA
5.6
V
25C
-0.1
25C
-40C to 125C
25C
-40C to 125C
76
71
62
60
87
25C
-40C to 125C
25C
-40C to 125C
100
86
100
87
107
dB
71
OUTPUT
AOL
Open-Loop Voltage Gain
RL=10KΩ, Vo=
0.05V to 4.95V
RL=2KΩ
RL=10KΩ
dB
110
25C
31
7
mV
25C
80
mA
Slew Rate
25C
1.8
V/us
Gain-Bandwidth Product
25C
3.6
MHz
Phase Margin
25C
Output Swing From Rail
Iout
RL=2KΩ, Vo=
0.15V to 4.85V
Output Short-Circuit Current
FREQUENCY RESPONSE
SR
GBP
PM
ts
Setting Time,0.1%
Overload Recovery Time
VIN·Gain≥VS
65
0.5
us
0.7
us
NOISE
en
Input Voltage Noise Density
f = 1KHz
25C
15
nV/√Hz
f = 10KHz
25C
13
nV/√Hz
25C
很抱歉,暂时无法提供与“RS522XM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.75400
- 50+2.06280
- 150+1.76040
- 500+1.38240
