PSPMAA0402-1R0M-ANP
PSPMAA0402-1R0M-ANP
    PROD(谱罗德)
    SMD,4.45x4.05mm
    1UH ±20% 7A
PSPMAA0402-1R0M-ANP 数据手册
Version: 2.0 SPECIFICATION FOR APPROVAL ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CUSTOMER : CUSTOMER P/N : DESCRIPTION : SMD INDUCTOR : PSPMAA0402-1R0M-ANP P/N REVISION NO. : Version: 2.0 DATE : 2017-4-19 NOTES : STANDARD DOCUMENTED APPROVED Kevin CHECKED Ben PREPARED Peter CUSTOMER APPROVAL company seals PROD TECHNOLOGY CO., LTD. E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 2.0 SPECIFICATION FOR APPROVAL ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V Version REVISON ITEM 1.0 First Version 2.0 First Version BEFORE REVISON AFTER REVISON DATE 2016-3-11 PSPFE-0402-1R0M PROD TECHNOLOGY CO., LTD. PSPMAA0402-1R0MANP 2017-4-19 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 2.0 COIL SPECIFICATION ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V PACKING DIMENSIONS (mm)   0402 Dimensions A B C D E F G H 4.05 ± 0.25 4.45 ± 0.25 2.0 MAX 1.5 ± 0.3 0.8 ± 0.3 4.95 Typ 2.15 Typ 2.3 Typ EXPLANATION OF PART NUMBERS P S P M A A Serial Codes 0 4 0 Size 2 - 1 R 0 M Inductance - A N P Descriptio ELECTRICAL CHARACTERISTICS @ 26 ℃ Ambient Temperture Lo (μH) TOLERANCE Typical Heat Rating DC Current (A) (Idc) 1.0 ±20% 4.5 INDUCTANCE ITEM P/N PSPMAA0 402-1R0MANP Typical Saturation DC Current (A) (Isat) 7 DCR mΩ @ 25℃ Typical DCR mΩ @ 25℃ MAX 24 27  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30% ¥ Operation Temperature Range :  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions -55℃ ~ 125℃ all effect the part temperature. Part temperature should be verified in the end application. PROD TECHNOLOGY CO., LTD. Page: 1 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN CHARACTERISTICS Version: 2.0 ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CONNECTIONS MARKING 1R0 ◎ Inductor Contents ONE (1) Set(s) of Coil ◎ DC/AC Currnet Shall Be Introduced By Any One of Two Pads  1.2 100 90 80 70 60 50 40 30 20 10 0  1 0.8 0.6 0.4 0.2 0 0 1 2 3 4 5 6 7 ℃ PERFORMANCE CURVES 8  RECOMMENDED SOLDERING TEMP. GRAPH ℃        A B C D E 260℃ 230℃ 10 Sec 150℃ 60~240 Sec  Page: PROD TECHNOLOGY CO., LTD. 2 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN CHARACTERISTICS Version: 2.0 ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V MECHANICAL RELIABILITY TEST Specification & Requirement Solderability Method Used The surface of terminal/pin tested shall Solder heat proof: be covered with new solder by 95% Preheating: 180 ±10℃ 90 seconds Soldering: 255 ±5℃ for 3 ±1 sec Inductance change within ± 5% Without Drop down with 981m/s2 (100G) shock Shock mechanical damage Attitude upon a rubber block method shock testing machinem, 3 tests. Inductance change within ± 5% Without Vibration frequency: Vibration mechanical damage 10Hz to 55Hz to 10Hz 60 seconds cycle Vibration time: 2 hours ENDURANCE RELIABILITY TEST Specification & Requirement Thermal Shock Heat Resistance Humidity Resistance Low Temp. Storing High Temp. Storing Method Used Inductance change within ± 5% Without -25℃, (30 mins) -> room temp. (5 mins) -> mechanical damage 125℃, (30 mins) -> room temp. (5 mins) 100 cycles Inductance change within ± 5% Without Apply IDC current @ 85℃ ambient mechanical damage Duration: 1000 hrs Inductance change within ± 5% Without Apply IDC current @ 60℃ ambient mechanical damage Humidity: 90~95% Duration: 1000 hrs Inductance change within ± 5% Without Storing Temp. mechanical damage -25 ±2 ℃ for total 1,000 +4/-0 hours Inductance change within ± 5% Without Storing Temp. mechanical damage 125 ±2 ℃ for total 1,000 +4/-0 hours Page: PROD TECHNOLOGY CO., LTD. 3 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN PACKING FOR SMD Version: 2.0 ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CARRIERTAPEING REEL & CARRIER MATERIALS (PAPER PLASTICS) UNIT : (mm) A 3000 B 12 W 12 P 8 Ao 4.6 ± 0.2 Bo 4.75 ± 0.2 Ko 2.15 ± 0.2 Typical Pulling Force: 100 grams typical Page: PROD TECHNOLOGY CO., LTD. 4 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN PACKING FOR SMD Version: 2.0 ITEM P/N PSPMAA0402-1R0M-ANP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V TEST DATA SPEC A B C D E (mm) (mm) (mm) (mm) (mm) 4.05 ± 0.25 4.45 ± 0.25 2.0 MAX No. DCR INDUCTANCE Max( mΩ ) L(0) ± 20% 1.5 ± 0.3 0.8 ± 0.3 7 A 27 1.00 ≈70% L(0) 1 4.06 4.60 1.83 1.52 0.82 25.4 0.94 PASS 2 4.05 4.62 1.82 1.55 0.83 25.1 1.02 PASS 3 4.04 4.64 1.88 1.54 0.81 25.3 0.98 PASS 4 4.04 4.68 1.85 1.52 0.86 25.0 0.96 PASS 5 4.03 4.63 1.82 1.54 0.85 25.2 1.03 PASS 6 4.04 4.68 1.86 1.51 0.84 24.9 1.06 PASS 7 4.03 4.62 1.85 1.52 0.82 25.1 0.94 PASS 8 4.05 4.67 1.87 1.50 0.86 24.8 0.96 PASS 9 4.06 4.63 1.81 1.56 0.83 24.7 0.94 PASS 10 4.04 4.64 1.90 1.53 0.82 25.1 0.99 PASS X 4.04 4.64 1.85 1.53 0.83 25.06 0.98 R 0.03 0.08 0.09 0.06 0.05 0.70 0.12  0.00 All test Data is referenced to 25℃ ambient Page: PROD TECHNOLOGY CO., LTD. 5 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN ANNOUNCEMENTS 产品注意事项 使用本产品时,请注意以下事项 © 产品保存期限为12个月,保存条件:温度5~40℃,湿度10~80%RH以内,超过保存期限可能会使 产品端子电极发生氧化。 © 请勿在极端环境下使用和保存(高盐,强酸,强碱,强辐射等)。 © 产品焊接前,请进行预热;预热温度与焊接温度之间温差建议控制在150℃以内。 © 产品焊接后需重新拆卸焊接修正时,请遵循规格书规定的条件范围;过高的加热温度以及反复的拆 卸可能会导致产品失效。 © 产品焊接到线路板后,请注意不可因线路板整体变形或局部变形而施加给电感剩余应力,这可能 会导致电感发生破裂,脱落,以致失效。 © 产品请勿接触清洗剂,酒精等液体,这会侵蚀产品本体,从而导致产品失效。 © 产品通电后温度会随电流的增大而上升,设计时请务必考虑留有余量。 © 过高的静电会对产品产生永久性损害,请注意静电防护。 © 产品通电过程请勿触摸产品任何部位,防止触电。 © 本产品作为磁性产品,设计时请务必考虑周边元器件与本产品可能产生的相互影响。 © 本产品适用于一般电子设备,如:AV设备,通信设备,家电产品,娱乐设备,计算机设备,个人设备,办公设 备,计测设备,工业机器人等。且该一般电子设备需在常规的操作和使用方法环境下使用。 对于需要高度安全性和可靠性的,或者因本产品失效造成设备故障,误操作,运转不良等危及到人的生命身体 及财产安全,以及对社会产生较大不良影响的特殊用途,设计使用前务必同本公司沟通,设计使用者如在未取 得我司书面同意状况下使用造成任何后果,我司不予承担。特殊用途包含但不限定如下清单: 1 军用设备 8 关系到国防安全的设备 2 运输设备(汽车,轨道交通产品,船舶等) 9 防灾赈灾设备 3 航空,航天设备 10 各种安规设备 4 发电控制设备 11 紧急救护设备 5 核动力相关设备 12 其他被认定为特殊用途的设备 6 爆炸引燃控制设备 7 交通控制设备 Page: 6 PROD TECHNOLOGY CO., LTD. E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN
PSPMAA0402-1R0M-ANP 价格&库存
很抱歉,暂时无法提供与“PSPMAA0402-1R0M-ANP”相匹配的价格&库存,您可以联系我们找货
PSPMAA0402-1R0M-ANP
库存:3799
PSPMAA0402-1R0M-ANP
  • 1+0.56910
  • 200+0.39270
  • 1500+0.35700
  • 3000+0.33390
库存:3000
