FR101W THRU FR107W SOD123FL
Surface Mount Fast Recovery Rectifiers
Pinning
Reverse Voltage - 50 to 1000 V
1.Cathode
Forward Current - 1 A
1
FEATURES
For surface mounted applications
Low profile package
Glass Passivated Chip Junction
Easy to pick and place
Fast reverse recovery time
2.Anode
2
SOD123FL
Marking Code
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: SOD-123FL
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 15mg / 0.00053oz
Absolute Maximum Ratings and characteristics
FR101W
F1
F1A
FR102W
F2
F1B
FR103W
F3
F1D
FR104W
F4
F1G
FR105W
F5
F1J
FR106W
F6
F1K
FR107W
F7
F1M
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
FR101W
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at Tc = 125 °C
IF(AV)
1
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.3
V
IR
5
100
μA
Typical Junction Capacitance at VR=4V,f=1MHZ
Cj
15
pF
Maximum Reverse Recovery Time(1)
Trr
Typical Thermal Resistance (2)
RθJA
85
°C/W
Tj, Tstg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current Ta = 25 °C
at Rated DC Blocking Voltage
Ta=125 °C
Operating and Storage Temperature Range
FR102W FR103W FR104W FR105W FR106W FR107W Units
150
250
500
nS
(1)Measured with IF=0.5A,IR=1A,In=0.25A
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yfwdiode.com
2/3
SOD-123FL
Package Outline
Plastic surface mounted package; 2 leads
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.3
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
Summary of Packing Options
Package
SOD-123FL
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
10000
EIA-481-1
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“FR104W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03560
- 3000+0.02830
- 国内价格
- 50+0.06188
- 600+0.04868
- 1200+0.04795
- 3000+0.03776
- 国内价格
- 50+0.07690
- 500+0.06048
- 3000+0.04850
- 6000+0.04310
- 24000+0.03834
- 51000+0.03586
- 国内价格
- 50+0.07049
- 600+0.05544
- 1200+0.05461
- 3000+0.04445
