MDA1040-330M
MDA1040-330M
    KOHER(科或)
    SMD,10x11mm
    33UH ±20% 5.5A
MDA1040-330M 数据手册
MDA Series SMD Low Profile High Current Molded Inductor Size 1040 FEATURES ■ ■ ■ ■ ■ ■ ■ ■ ■ Shielded construction Capable of corresponding high frequency . Low loss realized with low DCR. High performance (Isat) realized by metal dust core. Ultra low buzz noise, due to composite construction. 100% Lead(Pb)-Free and RoHS compliant. High reliability -Reliability test complied to AEC-Q200 Operating temperature: -55 to +155 °C (including self-temperature rise) Quantity: 500PCS APPLICATION ■ ■ ■ ■ ■ ■ Headlamps, tail lamps and interior lighting HVAC Doors, window lift and seat control Audio subsystem Digital instrument cluster In-Vehicle Infotainment and navigation Dimensions: [mm] 0.15μH-1.50μH Land Pattern: [mm] 11.0±0.3 2.0±0.3 Marking 12.5 3.5 3.8±0.2 E 10.0±0.3 10.0±0.3 5.4 Dimensions: [mm] 1.8μH-47μH Land Pattern: [mm] 11.0±0.3 2.0±0.3 Marking 12.5 3.5 3.8±0.2 E 10.0±0.3 10.0±0.3 5.4 Electrical Properties: Tolerance Temperature Rise Current Typ. (A) Saturation Current Typ. (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) E 0.15 ±30% 44.0 82.0 0.50 0.60 3.0±0.3 MDA1040-R22M 0.22 ±20% 36.0 70.0 0.72 0.83 3.0±0.3 MDA1040-R36M 0.36 ±20% 33.0 51.0 1.05 1.18 3.0±0.3 Part No Inductance @ 100KHz/1V (μH) MDA1040-R15N KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Part No Inductance @ 100KHz/1V (μH) Tolerance Temperature Rise Current Typ. (A) Saturation Current Typ. (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) E MDA1040-R47M 0.47 ±20% 32.0 46.0 1.30 1.50 3.0±0.3 MDA1040-R56M 0.56 ±20% 25.0 34.0 1.60 1.80 2.5±0.3 MDA1040-R68M 0.68 ±20% 23.0 31.0 1.90 2.20 2.5±0.3 MDA1040-1R0M 1.00 ±20% 20.0 29.0 2.90 3.25 2.5±0.3 MDA1040-1R5M 1.50 ±20% 17.5 26.0 3.70 4.20 2.5±0.3 MDA1040-1R8M 1.80 ±20% 16.5 23.0 5.10 5.70 3.0±0.3 MDA1040-2R2M 2.20 ±20% 15.0 20.0 5.80 6.70 3.0±0.3 MDA1040-3R3M 3.30 ±20% 11.0 17.5 10.5 11.8 3.0±0.3 MDA1040-4R7M 4.70 ±20% 8.80 15.2 15.8 19.0 3.0±0.3 MDA1040-5R6M 5.60 ±20% 8.00 14.1 19.0 22.8 3.0±0.3 MDA1040-6R8M 6.80 ±20% 7.80 12.2 22.0 24.5 3.0±0.3 MDA1040-8R2M 8.20 ±20% 7.60 9.50 25.0 28.0 3.0±0.3 MDA1040-100M 10.0 ±20% 7.50 8.60 27.0 30.0 3.0±0.3 MDA1040-150M 15.0 ±20% 6.25 7.00 41.0 45.0 3.0±0.3 MDA1040-220M 22.0 ±20% 5.00 6.20 58.0 66.0 3.0±0.3 MDA1040-330M 33.0 ±20% 4.40 5.50 84.0 91.0 3.0±0.3 MDA1040-470M 47.0 ±20% 3.50 4.00 125 143 3.0±0.3 Saturation Current will cause L to drop approximately 30% Temperature Rise Current: The actual value of DC current when the temperature rise is △T=40°C Typical Electrical Characteristics: MDA1040-R22M 0.16 80 0.24 80 0.4 80 0.12 60 0.18 60 0.3 60 0.08 40 0.12 40 0.2 40 0.04 20 0.06 20 0.1 20 18 36 54 72 0 90 0.00 0 16 DC CURRENT(A) 32 48 64 0 80 0.0 0 12 DC CURRENT(A) MDA1040-R47M 24 36 48 TEMP. RISE(℃) 100 INDUCTANCE (uH) 0.5 TEMP. RISE(℃) 100 INDUCTANCE (uH) 0.30 0.00 0 0 60 DC CURRENT(A) MDA1040-R56M MDA1040-R68M 1.0 100 0.52 80 0.60 80 0.8 80 0.39 60 0.45 60 0.6 60 0.26 40 0.30 40 0.4 40 0.13 20 0.15 20 0.2 20 0.00 0 12 24 36 48 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 0 60 0.00 0 9 18 27 DC CURRENT(A) 36 0 45 0.0 0 8 16 24 32 TEMP. RISE(℃) 100 INDUCTANCE (uH) 0.75 TEMP. RISE(℃) 100 INDUCTANCE (uH) 0.65 TEMP. RISE(℃) INDUCTANCE (uH) MDA1040-R36M 100 TEMP. RISE(℃) INDUCTANCE (uH) MDA1040-R15N 0.20 0 40 DC CURRENT(A) www.kohergroup.com MDA1040-1R5M 1.2 80 1.6 80 1.76 80 0.9 60 1.2 60 1.32 60 0.6 40 0.8 40 0.88 40 0.3 20 0.4 20 0.44 20 8 16 24 32 0 40 0.0 0 7 DC CURRENT(A) 28 0 35 0.00 0 5 10 15 0 25 20 DC CURRENT(A) MDA1040-3R3M MDA1040-4R7M 6.5 100 2.8 80 3.6 80 5.2 80 2.1 60 2.7 60 3.9 60 1.4 40 1.8 40 2.6 40 0.7 20 0.9 20 1.3 20 0.0 0 5 10 15 20 0 25 0.0 0 4 DC CURRENT(A) 8 12 16 0 20 0.0 0 4 DC CURRENT(A) MDA1040-5R6M 8 12 TEMP. RISE(℃) 100 INDUCTANCE (uH) 4.5 TEMP. RISE(℃) 100 INDUCTANCE (uH) 3.5 TEMP. RISE(℃) 0 20 16 DC CURRENT(A) MDA1040-6R8M MDA1040-8R2M 100 6.4 80 8.0 80 10.0 80 4.8 60 6.0 60 7.5 60 3.2 40 4.0 40 5.0 40 1.6 20 2.0 20 2.5 20 0.0 0 4 8 12 16 0 20 0.0 0 3 DC CURRENT(A) 6 9 12 0 15 0.0 0 2.5 DC CURRENT(A) MDA1040-100M 5.0 7.5 10.0 TEMP. RISE(℃) 12.5 INDUCTANCE (uH) 100 TEMP. RISE(℃) 10.0 INDUCTANCE (uH) 100 TEMP. RISE(℃) 8.0 0 12.5 DC CURRENT(A) MDA1040-150M MDA1040-220M 32.5 100 11.6 80 18.0 80 26.0 80 8.7 60 13.5 60 19.5 60 5.8 40 9.0 40 13.0 40 2.9 20 4.5 20 6.5 20 0.0 0 2.5 5.0 7.5 10.0 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 0 12.5 0.0 0 2 4 6 DC CURRENT(A) 8 0 10 0.0 0 1.5 3.0 4.5 6.0 TEMP. RISE(℃) 100 INDUCTANCE (uH) 22.5 INDUCTANCE (uH) 100 TEMP. RISE(℃) 14.5 TEMP. RISE(℃) INDUCTANCE (uH) 21 DC CURRENT(A) MDA1040-2R2M INDUCTANCE (uH) 14 TEMP. RISE(℃) 100 INDUCTANCE (uH) 2.20 TEMP. RISE(℃) 100 INDUCTANCE (uH) 2.0 0.0 0 INDUCTANCE (uH) MDA1040-1R8M 100 TEMP. RISE(℃) INDUCTANCE (uH) MDA1040-1R0M 1.5 0 7.5 DC CURRENT(A) www.kohergroup.com MDA1040-470M 100 36.0 80 52 80 27.0 60 39 60 18.0 40 26 40 9.0 20 13 20 0.0 0 1.5 3.0 4.5 6.0 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com 0 7.5 0.0 0 1.2 2.4 3.6 4.8 TEMP. RISE(℃) 65 INDUCTANCE (uH) 100 TEMP. RISE(℃) INDUCTANCE (uH) MDA1040-330M 45.0 0 6.0 DC CURRENT(A) www.kohergroup.com
MDA1040-330M
物料型号:MDA Series SMD Low Profile High Current Molded Inductor Size 1040
器件简介:高性能金属粉尘芯,超低噪音,100%无铅,符合RoHS标准,低直流电阻,高可靠性,符合AEC-Q200标准,能在-55至+155摄氏度下工作。
引脚分配:尺寸为3.0±0.3mm,标记为5.4mm。
参数特性: - 电感值:0.15μH至47μH - 公差:±20%至+20% - 温升电流典型值:44.0A至8.00A - 饱和电流典型值:82.0A至3.50A - 直流电阻典型值:0.50mΩ至19.0mΩ - 直流电阻最大值:0.60mΩ至22.8mΩ
功能详解:该系列电感器在汽车电子中应用广泛,如HVAC、门窗控制、座椅控制、前大灯、尾灯、室内照明、音频子系统、数字仪表板、车载信息娱乐和导航系统。
应用信息:适用于汽车电子的各种子系统中,包括但不限于HVAC、门窗控制、座椅控制、照明系统、音频系统和数字仪表等。
封装信息:尺寸为10.0±0.3mm x 11.0±0.3mm,标记为5.4mm。
MDA1040-330M 价格&库存
很抱歉,暂时无法提供与“MDA1040-330M”相匹配的价格&库存,您可以联系我们找货
