EJ
EJ
    DY(迪一电子)
    SMF(SOD-123FL)
    耐压:600V 电流:1A 反向恢复时间:35NS
EJ 数据手册
ES1AL THRU ES1JL Single Phase 1.0AMP Surface Mount Super Fast Recovery Rectifier Features · Glass passivated device · Ideal for surface mouted applications · Low reverse leakage Case: SOD-123FL · Metallurgically bonded construction · High temperature soldering guaranteed: 260℃ /10 seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension · Plastic material-UL flammability 94V-0 Mechanical Data · Case: SOD-123FL, molded plastic · Terminals: plated leads solderable per MIL-STD-750, Method 2026 · Polarity: Color band denotes cathode end · Mounting position: Any Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SYMBOL ES1AL ES1BL ES1DL ES1GL ES1JL Code EA EB ED EG EJ 50 100 200 400 600 V 35 70 140 280 420 V UNITS VRRM Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRWM RMS Reverse Voltage VRMS VDC @TL =90℃ Average Rectified Output Current Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 8.3ms Single half sine-wave @Tj=125 ℃ 1.0 IF(AV) A 30 IFSM A 24 Superimposed On Rated Load (JEDEC Method) Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 1.0ms Single half sine-wave @T j=125℃ Superimposed On Rated Load (JEDEC Method) IFSM 48 A 10000 times of the wave surge current ( time width 1ms, time interval 3s ) IFSM 22.5 A I 2t 3.735 A2s I2t Rating for Fusing (t < 8.3ms) Forward Voltage per element @IF=1.0A Peak Reverse Current @TA =25℃ At Rated DC Blocking Voltage @TA =125 ℃ Maximum reverse recovery time @TA =25℃ (NOTE 1) @TA =125 ℃ Typical Junction Capacitance (Note 2) Typical thermal resistance (Note 3) Operating and Storage Temperature Range 60 VFM IR Trr 0.95 1.3 5.0 100 1.7 V uA 35 200 ns CJ 10 pF RθJA 60 ℃/W TJ,TSTG -55to+150 ℃ Note:1.Measured with IF=0.5A, IR=1A, Irr=0.25A. 2.Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C. 3. Device mounted on FR-4 substrate, 25.4 25.4mm,2oz,single-sided,PC boards with 2.1 2.1mm copper pad version:04 1 of 3 ES1AL THRU ES1JL Single Phase 1.0AMP Surface Mount Super Fast Recovery Rectifier IF INSTANTANEOUS FORWARD CURRENT,(A) I(AV) AVERAGE FORWARD CURRENT (A) FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 175 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 25 20 15 10 5.0 0 1 10 100 10 TA=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 ES1AL-ES1DL ES1GL ES1JL 0.01 0 0.4 0.8 1.2 1.6 1.8 V F , INSTANTANEOUSFORWARD VOLTAGE (V) 1,000 100 10 TA=125 C 1 0.1 TA=25 C 0.01 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLYAGE(%) NUMBER OF CYCLES AT 60 Hz (1.3) Fig.5 TYPICAL CAPACITANCE version:04 20 FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT I R INSTANTANEOUS REVERSE CURRENT (uA) I FSMPEAK FORWARD SURGE CURRENT (A) LEAD TEMPERATURE(OC) FIG. 2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 2 of 3 ES1AL THRU ES1JL Single Phase 1.0AMP Surface Mount Super Fast Recovery Rectifier Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:04 3 of 3
很抱歉,暂时无法提供与“EJ”相匹配的价格&库存,您可以联系我们找货
