Minos High Power Products
Features:
①
②
③
④
NPN
TRANSISTORS
Power Amplifier Applications
Complementary to 2SA1943
High collector voltage:VCEO=230V (min)
Recommended for 100-W high-fidelity audio frequency
amplifier Output stage
Note: Using continuously under heavy loads (e.g. the application
of high temperature/current/voltage and the significant change in
temperature, etc.) may cause this product to decrease in the
reliability significantly even if the operating conditions (i.e.
operating temperature/current/voltage, etc.) are within the
absolute maximum ratings.
MINOS
TO-3PL
Absolute Maximum Ratings(Tc=25℃)
Characteristics
Collector-base voltage
Collector-emitter voltage
Emitter-base voltage
Collector current
Base current
Collector power dissipation
Tc=25℃
Junction temperature
Storage temperature range
Symbol
VCBO
VCEO
VEBO
IC
IB
PC
Rating
230
Unit
V
230
7
17
3
180
V
V
A
A
Tj
TSTG
150
-55~150
W
Package Marking And Ordering Information:
Ordering Codes
2SC5200
Package
TO-3PL
Product Code
5200
www.mns-kx.com
Packing
Tube
Electrical CharacteristicsTc=(25℃)
Test Condition
Characteristics
Collector cut-off current
Emitter cut-off current
Dc current gain
Symbol
ICBO
IEBO
hFE
VCB=230V;
VEB=7V;
IC=5A;
Collector-emitter saturation voltage
Transition frequency
VCE(sat)
fT
IC=4A;
VCE=10V;
Symbol
Paramter
RθJC
Junction-to-Case
Min
IE=0
Ic=0
VCE=4V;
70
IB=0.4A
ICE=500mA ;f=1MHZ
Typ
0.68
TYPICAL CHARACTERISTICS
HFE--IC
DC current gain HFE
VCE=5V
Collector current IC (A)
www.mns-kx.com
Typ
58
Max
Unit
500
500
140
uA
uA
0.5
V
MHZ
Units
℃/W
Package Information
TO-3PL PACKAGE
www.mns-kx.com
NOTE:
1.
Exceeding the maximum ratings of the device in performance may cause damage to the device,
even the permanent failure, which may affect the dependability of the machine. Please do not
exceed the absolute maximum ratings of the device when circuit designing.
2.
When installing the heat sink, please pay attention to the torsional moment and the smoothness of
the heat sink.
3.
MOSFETs is the device which is sensitive to the static electricity, it is necessary to protect the device
from being damaged by the static electricity when using it.
4.
Shenzhen Minos reserves the right to make changes in this specification sheet and is subject to
change withoutprior notice.
CONTACT:
深圳市迈诺斯科技有限公司(总部)
地址:深圳市福田区华富街道田面社区深南中路4026号田面城市大厦22B-22C
邮编:518025
电话:0755-83273777
www.mns-kx.com
很抱歉,暂时无法提供与“2SC5200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.58800
- 10+5.46480
- 25+4.48200
- 100+3.93120
- 400+3.59640
- 800+3.42360
