OP07DMM/TR
OP07DMM/TR
    HGSEMI(华冠)
    MSOP-8
    OP07 OP07C OP07D OP07CDR OP07DR
OP07DMM/TR 数据手册
OP07C/OP07D Very low offset single bipolar operational amplifier Features  Extremely low offset: 150µV/ max.  Low input bias current: 1.8nA  LOW Vio drift: 0.5µV/°C  Ultra stable with time: 2µV/month max.  Wide supply voltage range: ±3V to ± 22V  Temperature range: 0°C to -70°C SOP8 MSOP8 DIP8 Ordering Information DEVICE Package Type MARKING Packing Packing Qty OP07CN DIP8 OP07C TUBE 2000/box OP07DN DIP8 OP07D TUBE 2000/box OP07CM/TR SOP8 OP07C REEL 2500/reel OP07DM/TR SOP8 OP07D REEL 2500/reel OP07CMM/TR MSOP8 OP07C REEL 3000/reel OP07DMM/TR MSOP8 OP07D REEL 3000/reel http://www.hgsemi.com.cn 1/7 2019 AUG OP07C/OP07D Description The OP07 is a very high precision op-amp with an offset voltage maximum of 150µV. Offering also low input current (1.8nA) and high gain (400V/mV), the OP07 is particularly suitable for instrumentation applications. Pin Configuration DIP8/SOP8/MSOP8 Schematic diagram Figure 1. Schematic diagram http://www.hgsemi.com.cn 2/7 2019 AUG OP07C/OP07D Figure 2. Input offset voltage nulling circuit Absolute maximum ratings Table 1. Absolute maximum ratings Symbol Value Unit Supply voltage ± 22 V Differential input voltage ± 30 V Vi Toper Tstg Input voltage ± 22 V 0 to 70 °C -65 to 150 °C Rthja Rthjc Thermal resistance junction to ambient DIP8 85 °C/W Thermal resistance junction to case DIP8 41 °C/W HBM: human body model 1.5 kV MM: machine model 200 V CDM: charged device model 1.5 kV VCC Vid ESD Parameter Operating temperature Storage temperature 1. Short-circuits can cause excessive heating and destructive dissipation. 2. Rth are typical values. 3. Human body model: 100pF discharged through a 1.5kΩ resistor between two pins of the device, done for all couples of pin combinations with other pins floating. 4. 5. Machine model: a 200pF cap is charged to the specified voltage, then discharged directly between two pins of the device with no external series resistor (internal resistor < 5 Ω ). Done for all couples of pin combinations with other pins floating. Charged device model: all pins plus package are charged together to the specified voltage and then discharged directly to the ground. http://www.hgsemi.com.cn 3/7 2019 AUG OP07C/OP07D Electrical characteristics Table 2. VCC+ = 15 V, VCC- = Ground, Tamb = 25° C (unless otherwise specified) Symbol Vio OP07C OP07D Min. Typ. Max. Min. Typ. Max. Parameter Input offset voltage 0°C ≤ Tamb ≤+70°C 60 150 85 250 Unit µV Long term input offset - voltage stability (1) 0.4 Input offset voltage drift 0.5 Input offset current (Vic = 0V)0°C ≤ Tamb ≤ +70°C 0.8 DIio Input offset current drift 15 50 15 50 pA/°C DIib Input bias current drift 15 50 15 50 pA/°C Ro Rid Open loop output resistance 60 Differential input resistance 33 33 MW Ric Common mode input resistance 120 120 GW ±13.5 V DVio Iio ±13 Vicm Input common mode voltage range0°C ≤ Tamb ≤ +70°C CMR Common-mode rejection ratio (Vic = Vicm -min) 0°C≤ Tamb ≤ +70°C 100 Supply voltage rejection ratio (VCC = ±3 to ±18V) 90 0°C ≤ Tamb ≤ +70°C 86 SVR ±13 97 uV/Mo 2.5 6 0.8 7 6 7 uV/°C nA 60 ±13 ±13.5 ±13 120 94 110 94 106 90 104 86 dB 104 dB Large signal voltage gain Avd VCC = ±15, RL = 2k , VO = ±10V 120 40 0°C ≤ Tamb ≤ +105°C 100 VCC = ±3, RL = 500 , VO = ±0.5V 100 400 ±12 ±13 120 400 V/mV 100 100 400 ±12 ±13 Output voltage swing Vopp RL = 10k RL = 2k ±11.5 ±12.8 RL = 1k 0°C ≤ Tamb ≤ +105°C RL = 2k SR GBP ICC ±11.5 ±12.8 ±12 V ±12 ±11 ±11 Slew rate ( LR= 2k , CL= 100pF) 0.17 0.17 V/us Gain bandwidth product (RL = 2kΩ, CL = 100pF, f = 100kHz) 0.5 0.5 MHz Supply current - no load 2.7 0°C ≤ Tamb ≤ +70°C 5 2.7 6 VCC = ±3V 5 6 0.67 1.3 0.67 1.3 f = 10Hz 11 20 11 20 f = 100Hz 10.5 13.5 10.5 13.5 10 11.5 10 11.5 f = 10Hz 0.3 0.9 0.3 0.9 f = 100Hz 0.2 0..3 0.2 0..3 f = 1kHz 0.1 0.2 0.1 0.2 mA Equivalent input noise voltage en f = 1kHz nV Hz Equivalent input noise current in pA Hz 1. Long term input offset voltage stability refers to the average trend line of Vio vs time over extended periods after the first 30 days of operation. http://www.hgsemi.com.cn 4/7 2019 AUG OP07C/OP07D Physical Dimensions SOP8 Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP8) A A1 B C C1 D Min: 1.35 0.05 4.90 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 5.10 6.20 4.00 0.80 8° 0.45 Symbol: Q a b 1.27 BSC DIP8 D1 L1 L E B d D A c a b Dimensions In Millimeters(DIP8) A B D D1 E L L1 a b c Min: 6.10 9.00 8.40 7.42 3.10 0.50 3.00 1.50 0.85 0.40 Max: 6.68 9.50 9.00 7.82 3.55 0.70 3.60 1.55 0.90 0.50 Symbol: http://www.hgsemi.com.cn 5/7 d 2.54 BSC 2019 AUG OP07C/OP07D Physical Dimensions MSOP8 Q A C1 C B A1 D 0.20 b a Dimensions In Millimeters(MSOP8) A A1 B C C1 D Min: 0.80 0.05 2.90 4.75 2.90 0.35 0° 0.25 Max: 0.90 0.20 3.10 5.05 3.10 0.75 8° 0.35 Symbol: http://www.hgsemi.com.cn 6/7 Q a b 0.65 BSC 2019 AUG OP07C/OP07D IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 7/7 2019 AUG
OP07DMM/TR 价格&库存
很抱歉,暂时无法提供与“OP07DMM/TR”相匹配的价格&库存,您可以联系我们找货
