YWLD1608-1R0K
YWLD1608-1R0K
    YJYCOIN(益嘉源)
    SMD,1.8x1.25mm
    1UH ±10%
YWLD1608-1R0K 数据手册
Wire Wound Chip Inductor -YWLD1608 Series ■ Features ● Minature size,suitable for SMT. ● Using terminal electrode structure to restrain the parasitic component effect quite caused by lead. ● Execellent in solderability and heat resistance. ● Best frequency special property and intense ability to resist interference. ● Operating temperature:-40℃ ~ +85℃. ■ Applications ● Protable communication equipment and PDA,high speed electronic device. ● Used for radiation high speed noise suppression. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance value ⑷ :Inductance Tolerance: M=±20%,K=±10%,J=±5% ■ Shapes and Dimensions (Unit:mm) TYPE YWLD1608 A Max. 1.80 深圳市益嘉源电子有限公司 http://www.yjycoin.com B Max. 1.25 C Max. 1.10 D Typ. 0.64 E Typ. 0.64 F Typ. 1.02 1 Wire Wound Chip Inductor -YWLD1608 Series ■ YWLD1608 Series Part Number L (uH) Freq. (MHz) Q Typ. SRF Typ. (MHz) Rdc Max. (Ω) Irms Typ. (mA) Color YWLD1608-1R0□ 1.0 7.9 16 250 0.41 700 / YWLD1608-1R5□ 1.5 7.9 16 160 0.52 600 Brown YWLD1608-1R8□ 1.8 7.9 16 121 0.56 580 Red YWLD1608-2R2□ 2.2 7.9 16 103 0.72 580 Orange YWLD1608-2R7□ 2.7 7.9 16 72 0.81 500 Yellow YWLD1608-3R9□ 3.9 7.9 16 61 1.08 460 Blue YWLD1608-4R7□ 4.7 7.9 16 51 0.97 420 Violet YWLD1608-5R6□ 5.6 7.9 16 47 1.43 380 Gray YWLD1608-6R8□ 6.8 7.9 16 43 1.95 340 White YWLD1608-100□ 10 2.5 14 36 2.40 280 Brown YWLD1608-120□ 12 2.5 14 32 2.96 260 Red YWLD1608-150□ 15 2.5 14 29 3.38 220 Orange YWLD1608-220□ 22 2.5 14 24 4.69 200 Green YWLD1608-270□ 27 2.5 14 20 6.76 140 Blue YWLD1608-330□ 33 2.5 14 15 8.58 120 Violet ※ Rating DC current:temperature rise(ΔT) is 40 ℃ approximately at Irms. ※ Saturation DC current:Inductance drop approximately 30% of L0 at Isat. ※ Storage temp.:-10℃ ~ + 40℃ R.H.:65% Max. ※ Moisture sensitivity level(MSL)2(1 year floor life at
YWLD1608-1R0K
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一款高速光耦器件,具有高隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚(发光二极管阳极),2脚(发光二极管阴极),3脚(输出晶体管集电极),4脚(输出晶体管发射极),5脚(输出晶体管基极),6脚(Vcc)。 4. 参数特性:工作温度范围为-55℃至+125℃,隔离电压为5000Vrms,响应时间为100ns。 5. 功能详解:EL817通过内部发光二极管和光敏晶体管实现电信号的光电隔离,适用于高速数字信号传输。 6. 应用信息:EL817常用于高速数字通信、工业控制系统、医疗设备等领域。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
YWLD1608-1R0K 价格&库存
很抱歉,暂时无法提供与“YWLD1608-1R0K”相匹配的价格&库存,您可以联系我们找货
YWLD1608-1R0K
  • 10+0.42488
  • 100+0.33686
  • 300+0.29279
  • 1000+0.25974
库存:2442
