152EC0345
152EC0345
    KNSCHA(科尼盛)
    AEC-D22X25MM_TM
    3300UF ±20% 35V
152EC0345 数据手册
KNSCHA Snap-in Type Aluminum Electrolytic Capacitors Customer : ◆KNSCHA SHA Series Snap-in Terminal Type Aluminum Electrolytic Capacitors,105°C High Ripple Current PRODUCT CHARACTERISTICS Cap. (120Hz) Cap. Tol. Rate Volt. Surge Volt. Oper. Temp. Nominal Case Size Leakage Current D.F. Max RC 120HZ ESR 100KHZ Normal service life (uF) (%) (V-DC) (V-DC) (℃) D*L(mm) Max(uA) () (Arms) (Ω) (Hours) 152EC0328 470 ±20 450 500 -25∽105℃ 30*45 1379 0.20 1.61 / 3000 152EC0331 220 ±20 450 500 -25∽105℃ 30*30 944 0.20 1.00 / 3000 152EC0344 10000 ±20 50 62 -40∽105℃ 35*40 2121 0.30 4.04 / 3000 152EC0345 3300 ±20 35 43 -40∽105℃ 22*25 1019 0.40 1.45 / 3000 KNSCHA P/N 第3页,共17页 KNSCHA Snap-in Type Aluminum Electrolytic Capacitors -------------------------------------------------------------------------------------------STRUCTURE and MATERIALS AL RIVET TERMINAL BAKE LITE AL TAB AL TAB VINYL SLEEVE CATHODE FOIL ANODE FOIL AL CASE ELEMENT ADHESIVE TAPE BOTTOM PLATE(Φ20↑) SEPARATOR SAFETY VENT LARGE SIZED TYPE CAPACITORS COMPONENT MATERIALS PART NAME AL RIVET ALUMINUM 99.9% TERMINAL SPCC BAKE LITE RUBBER+PAPER LAMINATE AL TAB ALUMINUM 99.9% OVER INK SLEEVE P.E.T (Polyethylene Terephthalate Resin) AL CASE ALUMINUM 99.5% ANODE FOIL FORMED ALUMINUM 99.9% OVER CATHODE FOIL FORMED ALUMINUM 98.4% OVER SEPARATOR INSULATION PAPER ADHESIVE TAPE POLY PROPYLENE FILM
152EC0345 价格&库存
很抱歉,暂时无法提供与“152EC0345”相匹配的价格&库存,您可以联系我们找货
152EC0345
库存:308
152EC0345
    • 1+3.94979
    • 10+3.25125
    • 60+2.90629
    • 120+2.56133
    库存:300
