GLY10N05
GLY10N05
    SPRAGUE-GOODMAN
    FIXED IND 10NH 400MA 320MOHM SMD
GLY10N05 数据手册
ENGINEERING BULLETIN Sprague-Goodman SG-800H.1 Supercedes SG-800G SURFCOIL SMT INDUCTORS ® FEATURES • Lead free, ROHS Compliant • High Q • High self-resonant frequency including nonmagnetic models in microwave range • Shielded series use ferrite filled encapsulation to reduce external magnetic coupling • Low DC resistance • Carrier and reel packaging is standard • Ten case sizes SPECIFICATIONS Electrical • Inductance & Q, etc.: See tables • Temperature range –20°C to +85°C, except GLY, GLYC, GLZ, GLZB and GLZP Models are – 40°C to +85°C - Change of L = ±10% max, except GLX, GLY, GLYC, GLZ, GLZB and GLZP Models are ± 5% - Change of Q = ±20% max, except GLY, GLYC, GLZ, GLZB and GLZP Models are ±25% • Rated Current: See tables. Current rating is determined by either or both of the following conditions: 1. Self heating raises SURFCOIL temperature 20°C 2. Inductance value reduced by 10% from saturation effect Mechanical (Chip Inductors) • Suitable for wave flow soldering, infrared, and vapor phase reflow (typically over 90% coverage) • Withstands soldering temperatures without damage • Fully encapsulated and thermally cycled for stability and highest reliability Encapsulation: Epoxy resin all series; GLC, GLD and GLW have ferrite filler for closed magnetic circuit. Core: Ferrite (except high frequency GLA and GLU series, which are nonmagnetic) Coil: Polyurethane enameled copper wire Terminal: Phosphor-Bronze tin plated [View applies to molded bobbin wound types] Sprague-Goodman Electronics, Inc. 1700 SHAMES DRIVE, WESTBURY, NY 11590 TEL: 516-334-8700 • FAX: 516-334-8771 E-MAIL: info@spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H GLZ SERIES — LASER CUT 0402 SIZE Inductance L (nH) 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 47.0 56.0 68.0 82.0 100.0 Standard Inductance Tolerance ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% ± 5% Model No. GLZ1N030 GLZ1N225 GLZ1N520 GLZ1N817 GLZ2N214 GLZ2N711 GLZ3N309 GLZ3N908 GLZ4N706 GLZ5N605 GLZ6N805 GLZ8N205 GLZ10N05 GLZ12N05 GLZ15N05 GLZ18N05 GLZ22N05 GLZ27N05 GLZ33N05 GLZ39N05 GLZ47N05 GLZ56N05 GLZ68N05 GLZ82N05 GLZR1005 SRF (MHz) min 6000 6000 6000 6000 6000 5500 5500 5200 4800 4600 4000 3500 2800 2800 2500 2200 2000 1800 1800 1800 1800 1500 1500 1400 1200 Q min 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 Q/L Test Rated DCR Freq. Current (Ω) (MHz) (mA) max 100 400 0.05 100 400 0.06 100 400 0.07 100 400 0.08 100 400 0.09 100 400 0.10 100 400 0.12 100 360 0.15 100 360 0.17 100 340 0.19 100 320 0.30 100 320 0.35 100 320 0.41 100 320 0.45 100 240 0.60 100 240 0.70 100 200 0.80 100 200 1.20 100 170 1.40 100 150 1.70 100 140 2.10 100 130 2.50 100 120 4.00 100 110 4.50 100 90 5.50 GLZ GLZB and GLZP Series Outline Drawing 0.02 ± 0.006 0.5 ± 0.15 0.02 ± 0.006 0.5 ± 0.15 0.008 TYP 0.2 0.039 ± 0.006 1.0 ± 0.15 1 0.022 ± 0.002 0.55 ± 0.05 2 3 0.063 ± 0.004 1.6 ± 0.1 4 0.022 ± 0.002 0.55 ± 0.05 PAD LAYOUT MATERIAL ITEM 1) Encapsulant Epoxy Resin Tin coat 2) Terminal over Ni plate Copper 3) Coil Alumina 4) Core All dimensions are in/mm. GLZB SERIES — HIGH Q LASER CUT 0402 SIZE Inductance L (nH) 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 Standard Inductance Tolerance ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 2% 2% 2% 2% 2% 2% 2% 2% Inductance Test Freq. (MHz) Model No. SRF (MHz) min Q Typ (800 MHz) Q min (100 MHz) Rated Current (mA) DCR (Ω) max 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 GLZB1N020 GLZB1N217 GLZB1N513 GLZB1N811 GLZB2N209 GLZB2N707 GLZB3N306 GLZB3N905 GLZB4N704 GLZB5N604 GLZB6N803 GLZB8N202 GLZB10002 GLZB12002 GLZB15002 GLZB18002 GLZB22002 GLZB27002 GLZB33002 GLZB39002 6000 6000 6000 6000 6000 5500 5500 5200 4800 4600 4000 3500 2800 2800 2500 2200 2200 1800 1800 1800 41 41 40 40 40 40 39 39 39 39 39 39 39 38 36 36 36 36 35 35 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 400 400 400 400 400 400 400 360 360 340 320 320 320 320 240 240 200 200 170 170 0.05 0.06 0.07 0.08 0.09 0.10 0.12 0.15 0.17 0.19 0.30 0.35 0.41 0.45 0.60 0.70 0.80 1.20 1.40 1.70 nH nH nH nH nH nH nH nH nH nH nH nH GLZP SERIES — HIGH CURRENT LOW DCR LASER CUT 0402 SIZE Inductance L (nH) 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10.0 Standard Inductance Tolerance ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 0.3 nH ± 5% ± 5% ± 5% Model No. GLZP2N214 GLZP2N711 GLZP3N309 GLZP3N908 GLZP4N706 GLZP5N605 GLZP6N805 GLZP8N205 GLZP10N05 SRF (GHz) min 5.3 5.3 5.0 4.8 4.6 4.2 4.0 3.7 3.2 Q min 7 7 7 7 7 7 7 7 7 Q/L Test Frequency (MHz) 100 100 100 100 100 100 100 100 100 Rated Current (A) 1.9 1.8 1.5 1.4 1.3 1.2 1.1 0.90 0.75 DCR (Ω) max 0.04 0.05 0.07 0.08 0.10 0.12 0.16 0.21 0.26 Carrier and reel specifications on page 12. 2 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H GLY SERIES — LASER CUT 0603 SIZE Inductance L (nH) (100 MHz) Standard Inductance Tolerance* 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 47.0 56.0 68.0 82.0 100.0 120.0 150.0 180.0 220.0 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.3 0.3 0.3 0.3 0.3 0.3 0.3 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% 5% nH nH nH nH nH nH nH Model No. SRF (GHz) min Q Typ (800 MHz) Q min (100 MHz) Rated Current (mA) DCR (Ω) max GLY1N030 GLY1N225 GLY1N520 GLY1N817 GLY2N214 GLY2N711 GLY3N309 GLY3N905 GLY4N705 GLY5N605 GLY6N805 GLY8N205 GLY10N05 GLY12N05 GLY15N05 GLY18N05 GLY22N05 GLY27N05 GLY33N05 GLY39N05 GLY47N05 GLY56N05 GLY68N05 GLY82N05 GLYR1005 GLYR1205 GLYR1505 GLYR1805 GLYR2205 6.0 6.0 6.0 6.0 6.0 6.0 5.5 5.5 4.8 4.6 3.5 3.5 2.8 2.8 2.5 2.3 2.0 2.0 1.8 1.8 1.8 1.8 1.5 1.5 1.3 1.2 1.1 1.0 0.9 47 47 47 45 35 35 35 36 36 36 36 36 37 37 38 39 40 41 40 39 38 35 35 33 30 25 22 20 17 7 7 8 8 8 8 9 9 9 9 9 9 10 10 10 10 10 10 10 11 11 12 12 12 12 5 5 4 4 500 500 500 500 500 500 500 450 450 430 430 400 400 400 350 350 300 300 300 300 250 250 250 250 200 130 100 80 70 0.05 0.06 0.07 0.08 0.09 0.10 0.12 0.15 0.17 0.18 0.20 0.28 0.32 0.35 0.41 0.45 0.50 0.55 0.60 0.80 0.95 1.2 1.3 1.5 1.8 3.0 4.5 6.5 7.5 * ± 0.2 nH inductance tolerance is available for inductance values from 1.0 to 8.2 nH. ± 2% inductance tolerance is available for inductance values of 10.0 nH and up. Consult factory regarding these special units. GLYC SERIES — HIGH CURRENT LOW DCR LASER CUT 0603 SIZE Inductance L (nH) (100 MHz) Standard Inductance Tolerance Model No. SRF (GHz) min Q min (100 MHz) Rated Current (A) DCR (m Ω) max 2.2 2.7 3.3 3.9 ± ± ± ± 10% 10% 10% 10% GLYC2N210 GLYC2N710 GLYC3N310 GLYC3N910 6.0 5.0 5.0 5.2 8 8 8 9 2.1 2.1 2.1 2.1 30 30 40 40 4.7 5.6 6.8 8.2 ± ± ± ± 10% 10% 10% 10% GLYC4N710 GLYC5N610 GLYC6N810 GLYC8N210 4.8 4.6 4.0 3.5 9 9 9 9 2.1 2.1 1.9 1.7 50 55 55 60 10.0 12.0 15.0 18.0 22.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLYC10N10 GLYC12N10 GLYC15N10 GLYC18N10 GLYC22N10 2.8 2.5 2.2 2.0 1.8 9 9 9 9 9 1.4 1.3 0.9 0.8 0.7 65 80 100 120 150 Carrier and reel specifications on page 12. GLY and GLYC Series Outline Drawing 0.031 ± 0.006 0.8 ± 0.15 0.031 ± 0.006 0.8 ± 0.15 0.063 ± 0.006 1.6 ± 0.15 0.02 ± 0.008 TYP 0.4 ± 0.2 0.035 ± 0.004 0.9 ± 0.1 0.035 ± 0.004 0.9 ± 0.1 0.091 ± 0.01 2.3 ± 0.3 PAD LAYOUT TYPICAL Q VERSUS FREQUENCY—GLY AND GLYC Series 1 80 2 3 60 10 nH GLYC 4 ITEM 1) Encapsulant 2) Terminal 3) Coil 4) Core MATERIAL Epoxy Resin Tin coat over Ni plate Copper Alumina 40 Q 20 47 nH GLY 4.7 nH GLY 0 10 All dimensions are in/mm. 1000 100 10000 FREQUENCY (MHz) SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 3 SURFCOIL® SMT INDUCTORS SG-800H GLX SERIES — HIGH FREQUENCY NONMAGNETIC WIREWOUND 0805 SIZE Inductance L (µH) Standard Inductance Tolerance* Model No. SRF (MHz) min Q min Q/L Test Frequency (MHz) Rated Current (mA) DCR (Ω) max 0.010 0.012 0.015 0.018 0.022 ± ± ± ± ± 10% 10% 10% 10% 10% GLX10N10 GLX12N10 GLX15N10 GLX18N10 GLX22N10 2500 2500 2500 2000 2000 10 10 12 12 15 100 100 100 100 100 540 535 520 480 465 0.18 0.23 0.23 0.29 0.29 0.027 0.033 0.039 0.047 0.056 ± ± ± ± ± 10% 10% 10% 10% 10% GLX27N10 GLX33N10 GLX39N10 GLX47N10 GLX56N10 1800 1500 1500 1000 1000 15 15 15 15 15 100 100 100 100 100 455 395 390 385 360 0.34 0.39 0.40 0.46 0.51 0.068 0.082 0.10 0.12 0.15 ± ± ± ± ± 10% 10% 10% 10% 10% GLX68N10 GLX82N10 GLXR1010 GLXR1210 GLXR1510 800 800 800 600 600 15 15 8 8 10 100 100 25.2 25.2 25.2 340 330 285 275 230 0.57 0.62 0.86 0.99 1.47 0.18 0.22 0.27 0.33 0.39 ± ± ± ± ± 10% 10% 10% 10% 10% GLXR1810 GLXR2210 GLXR2710 GLXR3310 GLXR3910 600 500 300 200 150 10 10 10 10 10 25.2 25.2 25.2 25.2 25.2 195 170 165 160 150 1.61 1.83 1.95 2.16 2.37 0.47 0.56 0.68 0.82 1.00 ± ± ± ± ± 10% 10% 10% 10% 10% GLXR4710 GLXR5610 GLXR6810 GLXR8210 GLX1R010 150 100 100 80 80 10 10 10 10 8 25.2 25.2 25.2 25.2 7.96 145 140 130 125 120 2.56 2.69 3.02 3.38 3.87 *±5% Inductance tolerance is available for inductance values of 0.033 µH and up. TYPICAL Q VERSUS FREQUENCY— Non Magnetic GLX Series GLX Series Outline Drawing 100 39 nH 0.039 ± 0.004 1.0 ± 0.1 0.049 ± 0.01 1.25 ± 0.3 0.1 µH 50 40 15 nH QQ 30 0.22 µH 0.039 TO 0.047 1.0 TO 1.2 0.049 ± 0.008 1.25 ± 0.2 20 0.47 µH 0.047 ± 0.008 1.2 ± 0.2 10 10 100 1000 0.035 TO 0.051 0.9 TO 1.3 0.016 ± 0.008 0.40 ± 0.2 0.20 TO 0.15 3.0 TO 3.8 + 0.01 0.079 _ 0.008 PAD LAYOUT 0.3 2.00 + _ 0.2 FREQUENCY (MHz) All dimensions are in/mm. GLW SERIES — HIGH CURRENT MOLDED BOBBIN WOUND 1008 SIZE Induct- Standard ance Inductance L (µH) Tolerance Model No. SRF Q/L Test Rated DCR (MHz) Q Freq. Current (Ω) min min (MHz) (mA) max 1.0 1.5 2.2 3.3 4.7 ± ± ± ± ± 20% 20% 20% 20% 20% GLW1R020 GLW1R520 GLW2R220 GLW3R320 GLW4R720 95 85 65 55 43 10 10 10 8 8 7.96 7.96 7.96 7.96 7.96 475 435 390 340 285 0.45 0.55 0.65 0.85 1.2 6.8 10.0 12.0 15.0 22.0 33.0 ± ± ± ± ± ± 10% 10% 10% 10% 10% 10% GLW6R810 GLW10010 GLW12010 GLW15010 GLW22010 GLW33010 39 32 25 21 18 16 8 20 20 20 20 20 7.96 2.52 2.52 2.52 2.52 2.52 275 210 195 175 160 120 1.3 2.2 2.7 3.2 4.0 6.5 Carrier and reel specifications on page 12. 4 GLU and GLW Series Outline Drawing MARKING (inductance & tolerance) 0.047 ± 0.004 1.2 ± 0.1 0.079 ± 0.008 2.0 ± 0.2 0.098 ± 0.012 2.5 ± 0.3 0.055 ± 0.008 1.4 ± 0.2 0.055 ± 0.004 1.4 ± 0.1 0.063 ± 0.008 1.6 ± 0.2 0.016 ± 0.008 TYP 0.4 ± 0.2 TERMINALS APPROX. FLUSH TO MOUNTING SURFACE 0.055 ± 0.008 1.4 ± 0.2 PAD LAYOUT All dimensions are in/mm. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H GLU SERIES — MOLDED BOBBIN WOUND 1008 SIZE Inductance L (µH) Standard Inductance Tolerance* Model No. SRF (MHz) min Q min Q/L Test Freq. (MHz) Rated Current (mA) DCR (Ω) max 0.22 0.27 0.33 0.39 0.47 ± ± ± ± ± 10% 10% 10% 10% 10% GLUR2210M GLUR2710M GLUR3310M GLUR3910M GLUR4710M 230 210 190 175 160 25 25 25 25 25 25.2 25.2 25.2 25.2 25.2 190 180 170 160 155 0.70 0.75 0.85 0.95 1.00 0.56 0.68 0.82 1.00 1.20 ± ± ± ± ± 10% 10% 10% 10% 10% GLUR5610M GLUR6810M GLUR8210M GLU1R010 GLU1R210 150 135 125 115 100 25 25 25 25 25 25.2 25.2 25.2 7.96 7.96 150 140 130 195 180 1.10 1.25 1.40 0.65 0.75 1.50 1.80 2.20 2.70 3.30 ± ± ± ± ± 10% 10% 10% 10% 10% GLU1R510 GLU1R810 GLU2R210 GLU2R710 GLU3R310 90 85 80 75 65 25 25 25 25 25 7.96 7.96 7.96 7.96 7.96 170 160 155 145 135 0.85 0.95 1.05 1.20 1.30 3.90 4.70 5.60 6.80 8.20 ± ± ± ± ± 10% 10% 10% 10% 10% GLU3R910 GLU4R710 GLU5R610 GLU6R810 GLU8R210 60 55 50 45 40 25 25 25 25 25 7.96 7.96 7.96 7.96 7.96 130 125 120 115 105 1.40 1.55 1.75 1.95 2.20 10.0 12.0 15.0 18.0 22.0 ± ± ± ± ± 5% 5% 5% 5% 5% GLU10005 GLU12005 GLU15005 GLU18005 GLU22005 32 30 28 25 22 25 25 25 25 25 2.52 2.52 2.52 2.52 2.52 80 75 70 65 60 3.5 3.8 4.4 5.0 5.8 27.0 33.0 39.0 47.0 56.0 ± ± ± ± ± 5% 5% 5% 5% 5% GLU27005 GLU33005 GLU39005 GLU47005 GLU56005 21 20 18 17 16 20 20 20 20 20 2.52 2.52 2.52 2.52 2.52 115 110 90 80 75 6.3 7.1 9.5 11.0 12.1 ± 5% ± 5% ± 5% GLU68005 GLU82005 GLU10105 15 13 12 20 20 15 2.52 2.52 0.796 70 65 60 16.6 19.0 21.0 68.0 82.0 100.0 * ± 5% Inductance tolerance is available for inductance values up to 8.2 µH. Carrier and reel specifications on page 12. GLU SERIES — NONMAGNETIC HIGH FREQUENCY MOLDED BOBBIN WOUND 1008 SIZE Inductance L (µH) Standard Inductance Tolerance* Model No. SRF (MHz) min Q min Q/L Test Freq. (MHz) Rated Current (mA) DCR (Ω) max 0.010 0.012 0.015 0.018 ± ± ± ± 10% 10% 10% 10% GLU10N10 GLU12N10 GLU15N10 GLU18N10 2500 2200 1800 1550 10 10 10 10 100 100 100 100 280 270 255 250 0.32 0.34 0.38 0.40 0.022 0.027 0.033 0.039 ± ± ± ± 10% 10% 10% 10% GLU22N10 GLU27N10 GLU33N10 GLU39N10 1350 1150 1000 890 15 15 15 15 100 100 100 100 240 230 220 215 0.43 0.47 0.51 0.55 0.047 0.056 0.068 0.082 ± ± ± ± 10% 10% 10% 10% GLU47N10 GLU56N10 GLU68N10 GLU82N10 770 670 590 520 15 15 15 15 100. 100. 100. 100. 205 200 190 185 0.59 0.63 0.68 0.73 0.10 0.12 0.15 0.18 ± ± ± ± 10% 10% 10% 10% GLUR1010 GLUR1210 GLUR1510 GLUR1810 460 400 340 300 10 10 10 10 25.2 25.2 25.2 25.2 175 170 160 155 0.80 0.87 0.98 1.05 0.22 0.27 0.33 0.39 ± ± ± ± 10% 10% 10% 10% GLUR2210 GLUR2710 GLUR3310 GLUR3910 260 230 200 180 10 10 10 10 25.2 25.2 25.2 25.2 145 140 135 130 1.15 1.25 1.37 1.47 0.47 0.56 0.68 0.82 ± ± ± ± 10% 10% 10% 10% GLUR4710 GLUR5610 GLUR6810 GLUR8210 160 145 130 100 10 10 10 10 25.2 25.2 25.2 25.2 125 120 110 100 1.58 1.70 1.85 2.10 *±5% Inductance tolerance is available for inductance values of 0.033 µH and up. Carrier and reel specifications on page 12. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 5 SURFCOIL® SMT INDUCTORS SG-800H GLA SERIES — MOLDED BOBBIN WOUND 1210 SIZE Inductance L (µH) Standard Inductance Tolerance † Model No. SRF (MHz) min Q min Q/L Test Freq. (MHz) Rated Current (mA) DCR (Ω) max 0.22 0.27 0.33 0.39 ± ± ± ± 10% 10% 10% 10% GLAR2210M GLAR2710M GLAR3310M GLAR3910M 230 210 190 175 25 25 25 25 25.2 25.2 25.2 25.2 360 345 330 305 0.29 0.32 0.35 0.39 0.47 0.56 0.68 0.82 ± ± ± ± 10% 10% 10% 10% GLAR4710M GLAR5610M GLAR6810M GLAR8210M 160 150 135 125 25 25 25 25 25.2 25.2 25.2 25.2 290 275 260 245 0.44 0.49 0.55 0.61 1.00 1.20 1.50 1.80 ± ± ± ± 10% 10% 10% 10% GLA1R010 GLA1R210 GLA1R510 GLA1R810 115 100 90 85 30 * 30 * 30 * 30 * 7.96 7.96 7.96 7.96 230 215 210 200 0.69 0.75 0.75 0.82 2.20 2.70 3.30 3.90 ± ± ± ± 10% 10% 10% 10% GLA2R210 GLA2R710 GLA3R310 GLA3R910 80 75 65 60 30 * 30 * 30 * 30 * 7.96 7.96 7.96 7.96 190 180 180 * 175 * 0.95 1.1 1.2 * 1.3 * 4.70 5.60 6.80 8.20 ± ± ± ± 10% 10% 10% 10% GLA4R710 GLA5R610 GLA6R810 GLA8R210 55 50 45 40 30 * 30 * 30 * 30 * 7.96 7.96 7.96 7.96 165 * 160 * 150 * 140 * 1.5 1.6 * 1.8 * 2.0 * 10.0 12.0 15.0 18.0 ± ± ± ± 10% 10% 10% 10% GLA10010 GLA12010 GLA15010 GLA18010 36 33 30 27 30 30 30 30 2.52 2.52 2.52 2.52 140 * 125 * 120 * 110 * 2.1 2.5 2.8 3.3 * * * * 22.0 27.0 33.0 39.0 ± ± ± ± 10% 10% 10% 10% GLA22010 GLA27010 GLA33010 GLA39010 25 22 20 20 30 30 30 30 2.52 2.52 2.52 2.52 105 * 90 * 85 * 80 * 3.7 5.0 5.6 6.4 * * ** ** 47.0 56.0 68.0 82.0 ± ± ± ± 10% 10% 10% 10% GLA47010 GLA56010 GLA68010 GLA82010 15 15 15 11 30 30 30 30 * 2.52 2.52 2.52 2.52 75 70 65 60 7.0 8.0 9.0 10.0 100.0 120.0 150.0 180.0 220.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLA10110 GLA12110 GLA15110 GLA18110 GLA22110 10 10 8 7 7 20 * 20 * 20 20 20 0.796 0.796 0.796 0.796 0.796 60 55 50 50 45 10.0 11.0 15.0 17.0 21.0 † Inductance values from 1.0 µH and up also available with ±5% inductance tolerance. Consult factory regarding these special units. * Rerated 12/91 **Rerated 6/97 GLAC SERIES — HIGH POWER LOW DCR SHIELDED MOLDED BOBBIN WOUND 1210 SIZE Inductance Standard L Inductance (µH) Tolerance Model No. SRF Q /L Test Rated DCR (MHz) Q Freq. Current (Ω) min min (MHz) (mA) max 1.0 1.5 2.2 3.3 ± ± ± ± 20% 20% 20% 20% GLAC1R020 100 GLAC1R520 80 GLAC2R220 65 GLAC3R320 50 7 7 7 7 7.96 7.96 7.96 7.96 500 390 350 270 0.09 0.10 0.13 0.16 4.7 6.8 10.0 15.0 ± ± ± ± 20% 20% 10% 10% GLAC4R720 GLAC6R820 GLAC10010 GLAC15010 46 36 29 25 7 7 10 10 7.96 7.96 2.52 2.52 240 200 160 145 0.18 0.25 0.34 0.42 22.0 33.0 47.0 68.0 ± ± ± ± 10% 10% 10% 10% GLAC22010 GLAC33010 GLAC47010 GLAC68010 18 16 13 10 10 10 10 10 2.52 2.52 2.52 2.52 115 95 80 60 0.65 0.91 1.30 1.95 100.0 150.0 220.0 330.0 ± ± ± ± 10% 10% 10% 10% GLAC10110 GLAC15110 GLAC22110 GLAC33110 8 7 5 4 20 20 20 20 0.796 0.796 0.796 0.796 50 45 35 30 3.12 4.03 7.15 9.23 GLA, GLAC, GLC and GLD Series Outline Drawing MARKING (inductance & tolerance) 0.0 98 ± 0.008 2.5 ± 0.2 0.075 ± 0.004 1.9 ± 0.1 0.126 ± 0.012 3.2 ± 0.3 0.063 ± 0.008 TYP 1.6 ± 0.2 0.067 ± 0.004 1.7 ± 0.1 0.083 ± 0.008 2.1 ± 0.2 0.087 ± 0.008 2.2 ± 0.2 PAD LAYOUT 0.024 ± 0.008 TYP 0.6 ± 0.2 TERMINALS APPROX. FLUSH TO MOUNTING SURFACE All dimensions are in/mm. Carrier and reel specifications on page 12. 6 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H GLA SERIES — NONMAGNETIC HIGH FREQUENCY MOLDED BOBBIN WOUND 1210 SIZE Standard Inductance Inductance L (µH) Tolerance Inductance Test Freq. (MHz) Model No. SRF (MHz) min Q min Q Test Frequency (MHz) Rated Current (mA) DCR (Ω) max 0.047 0.056 0.068 0.082 ± ± ± ± 20% 20% 20% 20% 100.0 100.0 100.0 100.0 GLA47N20 GLA56N20 GLA68N20 GLA82N20 680 600 540 500 10 10 10 10 100.0 100.0 100.0 100.0 450 420 400 380 0.20 0.22 0.25 0.27 0.10 0.12 0.15 0.18 ± ± ± ± 20% 20% 20% 20% 100.0 25.2 25.2 25.2 GLAR1020 GLAR1220 GLAR1520 GLAR1820 450 400 350 320 10 10 10 10 100.0 25.2 25.2 25.2 360 240 230 220 0.30 0.67 0.72 0.81 0.22 0.27 0.33 0.39 ± ± ± ± 10% 10% 10% 10% 1.0 1.0 1.0 1.0 GLAR2210 GLAR2710 GLAR3310 GLAR3910 280 250 220 200 10 10 10 10 25.2 25.2 25.2 25.2 210 200 190 180 0.90 1.0 1.1 1.2 0.47 0.56 0.68 0.82 ± ± ± ± 10% 10% 10% 10% 1.0 1.0 1.0 1.0 GLAR4710 GLAR5610 GLAR6810 GLAR8210 180 160 150 135 10 10 10 10 25.2 25.2 25.2 25.2 175 170 155 145 1.4 1.5 1.7 1.9 1.00 1.20 1.50 1.80 ± ± ± ± 5% 5% 5% 5% 1.0 1.0 1.0 1.0 GLA1R005 GLA1R205 GLA1R505 GLA1R805 120 110 95 85 13 13 13 13 7.96 7.96 7.96 7.96 125 120 115 110 2.1 2.3 2.7 3.0 2.20 2.70 3.30 3.90 ± ± ± ± 5% 5% 5% 5% 1.0 1.0 1.0 1.0 GLA2R205 GLA2R705 GLA3R305 GLA3R905 80 70 62 57 13 13 13 13 7.96 7.96 7.96 7.96 110 105 100 95 3.2 3.6 4.2 4.4 4.70 5.60 6.80 8.20 ± ± ± ± 5% 5% 5% 5% 1.0 1.0 1.0 1.0 GLA4R705 GLA5R605 GLA6R805 GLA8R205 52 46 42 38 13 13 13 13 7.96 7.96 7.96 7.96 70 65 60 60 7.7 8.7 10.0 11.0 GLC SERIES — SHIELDED MOLDED BOBBIN WOUND 1210 SIZE Standard Inductance Inductance L (µH) Tolerance Inductance Test Freq. (MHz) Model No. SRF (MHz) min Q min Q Test Frequency (MHz) Rated Current (mA) DCR (Ω) max 10.0 12.0 15.0 18.0 22.0 ± ± ± ± ± 10% 10% 10% 10% 10% 1.0 1.0 1.0 1.0 1.0 GLC10010 GLC12010 GLC15010 GLC18010 GLC22010 30 28 25 23 20 40 40 40 40 40 5.0 5.0 5.0 5.0 5.0 18 17 15 13 12 1.8 2.0 2.2 2.5 2.8 27.0 33.0 39.0 47.0 56.0 ± ± ± ± ± 10% 10% 10% 10% 10% 1.0 1.0 1.0 1.0 1.0 GLC27010 GLC33010 GLC39010 GLC47010 GLC56010 18 17 15 14 13 40 40 40 40 40 5.0 5.0 5.0 5.0 5.0 10 10 9 8 7 3.2 3.5 3.8 4.0 4.5 68.0 82.0 100.0 120.0 150.0 ± ± ± ± ± 10% 10% 10% 10% 10% 1.0 1.0 1.0 1.0 0.1 GLC68010 GLC82010 GLC10110 GLC12110 GLC15110 12 11 10 9 5 40 40 40 40 40 1.5 1.5 1.5 1.5 1.5 6 6 5 5 5 5.0 6.0 7.0 8.0 9.0 180.0 220.0 270.0 ± 10% ± 10% ± 10% 0.1 0.1 0.1 GLC18110 GLC22110 GLC27110 5 4 4 40 40 40 1.5 1.5 1.5 5 5 5 11.0 12.0 14.0 Carrier and reel specifications on page 12. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 7 SURFCOIL® SMT INDUCTORS SG-800H GLD SERIES — HIGH CURRENT SHIELDED MOLDED BOBBIN WOUND 1210 SIZE InductStandard ance Inductance L (µH) Tolerance Model No. SRF Q /L Test Rated DCR (MHz) Q Freq. Current (Ω) min min (MHz) (mA) max 1.0 1.5 2.2 3.3 4.7 6.8 ± ± ± ± ± ± 20% 20% 20% 20% 20% 20% GLD1R020 GLD1R520 GLD2R220 GLD3R320 GLD4R720 GLD6R820 150 110 80 58 46 38 7 7 7 7 7 7 7.96 7.96 7.96 7.96 7.96 7.96 600 550 500 400 350 300 0.15 0.18 0.23 0.28 0.34 0.42 10.0 12.0 15.0 18.0 22.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLD10010 GLD12010 GLD15010 GLD18010 GLD22010 23 21 18 17 15 15 15 15 15 15 2.52 2.52 2.52 2.52 2.52 240 230 220 205 185 0.50 0.60 0.74 0.90 1.15 27.0 33.0 39.0 47.0 56.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLD27010 GLD33010 GLD39010 GLD47010 GLD56010 13 12 11 9.5 8.5 15 15 15 15 15 2.52 2.52 2.52 2.52 2.52 165 155 145 135 110 1.45 1.65 1.90 2.25 3.30 68.0 82.0 100.0 120.0 150.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLD68010 GLD82010 GLD10110 GLD12110 GLD15110 7.5 7.0 6.5 6.0 5.5 15 15 20 20 20 2.52 2.52 0.796 0.796 0.796 105 100 90 75 70 3.70 4.20 5.00 7.00 8.00 180.0 220.0 270.0 330.0 ± ± ± ± 10% 10% 10% 10% GLD18110 GLD22110 GLD27110 GLD33110 5.0 4.0 3.5 3.0 20 20 20 20 0.796 0.796 0.796 0.796 65 60 55 50 9.50 11.00 14.50 16.00 GLA, GLAC, GLC and GLD Series Outline Drawing MARKING (inductance & tolerance) 0.0 98 ± 0.008 2.5 ± 0.2 0.075 ± 0.004 1.9 ± 0.1 0.126 ± 0.012 3.2 ± 0.3 0.063 ± 0.008 TYP 1.6 ± 0.2 0.067 ± 0.004 1.7 ± 0.1 0.083 ± 0.008 2.1 ± 0.2 0.087 ± 0.008 2.2 ± 0.2 PAD LAYOUT 0.024 ± 0.008 TYP 0.6 ± 0.2 TERMINALS APPROX. FLUSH TO MOUNTING SURFACE All dimensions are in/mm. GLBP SERIES — HIGH CURRENT LOW DCR SHIELDED MOLDED BOBBIN WOUND 1812 SIZE InductStandard ance Inductance L (µH) Tolerance Model No. SRF Q /L Test Rated DCR (MHz) Q Freq. Current (Ω) min min (MHz) (mA) max 10.0 12.0 15.0 18.0 ± ± ± ± 10% 10% 10% 10% GLBP10010 GLBP12010 GLBP15010 GLBP18010 19 17 15 14 10 10 10 10 2.52 2.52 2.52 2.52 360 340 320 310 0.65 0.70 0.80 0.90 22.0 27.0 33.0 39.0 ± ± ± ± 10% 10% 10% 10% GLBP22010 GLBP27010 GLBP33010 GLBP39010 13 11 10 9.5 10 10 10 10 2.52 2.52 2.52 2.52 300 270 250 230 1.00 1.20 1.40 1.60 47.0 56.0 68.0 82.0 ± ± ± ± 10% 10% 10% 10% GLBP47010 GLBP56010 GLBP68010 GLBP82010 8.5 8.0 7.0 6.5 10 10 10 10 2.52 2.52 2.52 2.52 210 190 170 160 1.90 2.20 2.60 3.50 100.0 120.0 150.0 180.0 220.0 ± ± ± ± ± 10% 10% 10% 10% 10% GLBP10110 GLBP12110 GLBP15110 GLBP18110 GLBP22110 6.0 5.5 5.0 4.5 4.0 20 20 20 20 20 0.796 0.796 0.796 0.796 0.796 150 130 120 110 90 4.00 4.50 6.50 7.50 9.00 GLB AND GLBP Series Outline Drawing MARKING (inductance & tolerance) 0.126 ± 0.008 3.2 ± 0.2 0.079 ± 0.008 2.0 ± 0.2 0.177 ± 0.012 4.5 ± 0.3 0.118 ± 0.004 3.0 ± 0.1 0.063 ± 0.008 1.6 ± 0.2 0.087 ± 0.008 2.2 ± 0.2 0.126 ± 0.008 3.2 ± 0.2 PAD LAYOUT 0.024 ± 0.008 TYP 0.6 ± 0.2 TERMINALS APPROX. FLUSH TO MOUNTING SURFACE All dimensions are in/mm. Carrier and reel specifications on page 12. 8 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H GLB SERIES — MOLDED BOBBIN WOUND 1812 SIZE Inductance L (µH) Standard Inductance Inductance Test Freq. Tolerance* (MHz) Model No. SRF (MHz) min Q min Q Test Frequency (MHz) Rated Current (mA) DCR (Ω) max 0.22 0.27 0.33 0.39 ± ± ± ± 20% 20% 20% 20% 1.0 1.0 1.0 1.0 GLBR2220 GLBR2720 GLBR3320 GLBR3920 230 200 180 155 30 30 30 30 25.20 25.20 25.20 25.20 700 650 630 620 0.30 0.32 0.35 0.37 0.47 0.56 0.68 0.82 ± ± ± ± 20% 20% 20% 20% 1.0 1.0 1.0 1.0 GLBR4720 GLBR5620 GLBR6820 GLBR8220 135 120 105 90 30 30 30 30 25.20 25.20 25.20 25.20 580 560 530 500 0.40 0.42 0.48 0.50 1.00 1.20 1.50 1.80 ± ± ± ± 20% 20% 20% 20% 1.0 1.0 1.0 1.0 GLB1R020 GLB1R220 GLB1R520 GLB1R820 80 70 60 50 30 30 30 30 25.20 25.20 25.20 7.96 470 460 430 410 0.52 0.55 0.61 0.61 2.20 2.70 3.30 3.90 ± ± ± ± 20% 20% 20% 20% 1.0 1.0 1.0 1.0 GLB2R220 GLB2R720 GLB3R320 GLB3R920 45 43 39 36 50 50 50 50 7.96 7.96 7.96 7.96 410 400 380 360 0.61 0.61 0.66 0.74 4.70 5.60 6.80 8.20 ± ± ± ± 20% 20% 20% 20% 1.0 1.0 1.0 1.0 GLB4R720 GLB5R620 GLB6R820 GLB8R220 33 30 26 24 50 50 50 50 5.00 5.00 5.00 5.00 350 330 310 250 0.81 0.88 1.00 1.60 10.0 12.0 15.0 18.0 ± ± ± ± 10% 10% 10% 10% 1.0 1.0 1.0 1.0 GLB10010 GLB12010 GLB15010 GLB18010 22 20 18 16 50 50 50 50 5.00 5.00 5.00 2.52 235 225 215 205 1.8 1.9 2.1 2.3 22.0 27.0 33.0 39.0 ± ± ± ± 10% 10% 10% 10% 1.0 1.0 1.0 1.0 GLB22010 GLB27010 GLB33010 GLB39010 15 13 12 10 50 50 50 50 2.52 2.52 2.52 2.52 195 185 175 165 2.6 2.9 3.1 3.6 47.0 56.0 68.0 82.0 ± ± ± ± 10% 10% 10% 10% 1.0 0.1 0.1 0.1 GLB47010 GLB56010 GLB68010 GLB82010 9.7 9.0 8.2 7.5 50 40 40 40 2.52 2.52 2.52 2.52 130 125 115 110 4.2 4.7 5.3 5.9 100.0 120.0 150.0 180.0 ± ± ± ± 10% 10% 10% 10% 0.1 0.1 0.1 0.1 GLB10110 GLB12110 GLB15110 GLB18110 6.7 6.1 5.5 5.1 40 40 40 40 2.52 1.50 1.50 1.50 105 100 95 85 8.8 10.0 11.0 13.0 220.0 270.0 330.0 390.0 ± ± ± ± 10% 10% 10% 10% 0.1 0.1 0.1 0.1 GLB22110 GLB27110 GLB33110 GLB39110 4.5 4.1 3.7 3.3 40 40 40 40 0.796 0.796 0.796 0.796 85 80 75 70 13.0 14.0 16.0 19.0 470.0 560.0 680.0 820.0 1000.0 ± ± ± ± ± 10% 10% 10% 10% 10% 0.1 0.1 0.1 0.1 0.1 GLB47110 GLB56110 GLB68110 GLB82110 GLB10210 3.3 2.7 2.5 2.4 2.1 30 30 30 30 30 0.796 0.796 0.796 0.796 0.796 55 50 50 45 40 31.0 35.0 39.0 45.0 53.0 * Inductance values from 1.00 to 8.2 µH also available with ±10% inductance tolerance. Inductance values from 10.0 µH and up also available with ±5% inductance tolerance. Consult factory regarding these special units. Carrier and reel specifications on page 12. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 9 SURFCOIL® SMT INDUCTORS SG-800H.1 GL06 SERIES — ECONOMY SURFCOIL® AIR CORE INDUCTORS Induct- Standard ance Inductance L (nH) Tolerance* Q/L Test Q Frequency min (MHz) Model No. ID (in/ mm) B (in/ mm) L (in/ mm) C (in/ mm) D (in/ mm) 1.65 2.55 3.85 5.40 5.60 ± ± ± ± ± 10% 10% 10% 5% 5% GL06A01N6510 GL06A02N5510 GL06A03N8510 GL06A05N4005 GL06A05N6005 100 100 100 100 100 800 800 800 800 800 0.018 / 0.45 0.020/ 0.52 0.020/ 0.52 0.021/ 0.54 0.021/ 0.54 0.061/ 1.55 0.052/ 1.32 0.058/ 1.46 0.106/2.69 0.059/1.50 0.088/2.23 0.090/2.29 0.098/2.50 0.84/2.14 0.164/4.16 0.04/1.00 0.04/1.00 0.04/1.00 0.04/1.00 0.112/2.85 0.10/2.6 0.10/2.6 0.10/2.6 0.10/2.6 0.18/4.5 7.15 8.80 9.85 12.55 ± ± ± ± 5% 5% 5% 5% GL06A07N1505 GL06A08N8005 GL06A09N8505 GL06A12N5505 100 100 100 100 800 800 800 800 0.026/ 0.65 0.026/ 0.65 0.026/ 0.65 0.030/ 0.7 0.064/1.62 0.064/1.62 0.065/1.65 0.061/1.55 0.172/4.38 0.165/4.19 0.163/4.15 0.163/4.15 0.112/2.85 0.112/2.85 0.112/2.85 0.112/2.85 0.18/4.5 0.18/4.5 0.18/4.5 0.18/4.5 * Tighter tolerances are available, consult factory. GL12 SERIES — ECONOMY SURFCOIL® AIR CORE INDUCTORS Induct- Standard ance Inductance L (nH) Tolerance* Q/L Test Q Frequency min (MHz) Model No. ID (in/mm) B (in/mm) L (in/mm) C (in/mm) D (in/mm) 2.5 5.0 8.0 12.5 18.5 ± ± ± ± ± 10% 10% 10% 10% 10% GL12A02N5010 GL12A05N0010 GL12A08N0010 GL12A12N5010 GL12A18N5010 100 100 100 100 100 150 150 150 150 150 0.053/1.35 0.053/1.35 0.061/1.55 0.060/1.53 0.061/1.55 0.091/2.3 0.082/2.1 0.10/2.6 0.11/2.7 0.10/2.6 0.11/2.9 0.135/3.45 0.15/3.7 0.2/4 0.135/3.45 0.065/1.65 0.065/1.65 0.065/1.65 0.065/1.65 0.065/1.65 0.17/4.2 0.17/4.2 0.17/4.2 0.17/4.2 0.17/4.2 17.5 22.5 28.0 35.5 43.0 ± ± ± ± ± 10% 5% 5% 5% 5% GL12A17N5010 GL12A22N5005 GL12A28N0005 GL12A35N5005 GL12A43N0005 100 100 100 100 100 150 150 150 150 150 0.061/1.55 0.061/1.55 0.061/1.55 0.061/1.55 0.061/1.55 0.11/2.7 0.11/2.7 0.11/2.7 0.11/2.8 0.11/2.8 0.25/6.4 0.27/6.8 0.26/6.6 0.24/6.2 0.26/6.6 0.19/4.7 0.19/4.7 0.19/4.7 0.19/4.7 0.19/4.7 0.29/7.3 0.29/7.3 0.29/7.3 0.29/7.3 0.29/7.3 * Tighter tolerances are available, consult factory. GL06 Series Outline Drawing ENCAPSULATION (FLAT SURFACE FOR EASE OF PICK & PLACE) GL12 Series Outline Drawing ENCAPSULATION (FLAT SURFACE FOR EASE OF PICK & PLACE) L L 0.04 1.0 0.11 2.8 0.03 TYP 0.8 0.051 TYP 1.3 TIN PLATE TIN PLATE B ID 176° ± 4° 0.098 2.5 B C ID D 176° ± 4° 0.13 3.3 PAD LAYOUT All dimensions are in/mm. C D PAD LAYOUT All dimensions are in/mm. Carrier and reel specifications are on the web at www.spraguegoodman.com/800/800p1/html 10 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com SURFCOIL® SMT INDUCTORS SG-800H.1 GL15 SERIES — ECONOMY SURFCOIL® AIR CORE INDUCTORS Inductance L (nH) Standard Inductance Tolerance* Model No. Q min Q/L Test Frequency (MHz) ID (in/mm) B (in/mm) L (in/mm) 22.0 27.0 33.0 39.0 47.0 150 150 150 150 150 GL15A22N0005 GL15A27N0005 GL15A33N0005 GL15A39N0005 GL15A47N0005 100 100 100 100 100 150 150 150 150 150 0.096/2.45 0.08/2.2 0.096/2.45 0.087/2.2 0.098/2.5 0.1/3 0.1/3 0.1/3 0.1/3 0.11/2.8 0.2/5 0.18/4.5 0.21/5.3 0.19/4.9 0.19/4.8 56.0 68.0 82.0 100.0 120.0 150 150 150 150 150 GL15A56N0005 GL15A68N0005 GL15A82N0005 GL15AR100005 GL15AR120005 100 100 100 100 100 150 150 150 150 150 0.091/2.3 0.100/2.55 0.098/2.5 0.096/2.45 0.11/2.8 0.12/3.1 0.11/2.8 0.12/3.1 0.1/3 0.1/3 0.12/4.7 0.17/4.4 0.18/4.5 0.18/4.6 0.18/4.6 * Tighter tolerances are available, consult factory. GL25 SERIES — ECONOMY SURFCOIL® AIR CORE INDUCTORS Inductance L (nH) Standard Inductance Tolerance* Model No. Q min Q/L Test Frequency (MHz) ID (in/mm) B (in/mm) L (in/mm) 90.0 111.0 130.0 150.0 50 50 50 50 GL25A90N0005 GL25AR111005 GL25AR130005 GL25AR150005 90 90 90 90 50 50 50 50 0.12/3.05 0.12/3.05 0.12/3.05 0.128/3.25 0.1/3 0.1/3 0.11/2.9 0.1/3 0.35/8.8 0.35/8.8 0.34/8.6 0.33/8.4 169.0 206.0 222.0 246.0 307.0 50 50 50 50 50 GL25AR169005 GL25AR206005 GL25AR222005 GL25AR246005 GL25AR307005 90 90 90 90 90 50 50 50 50 50 0.128/3.25 0.128/3.25 0.128/3.25 0.128/3.25 0.13/3.4 0.1/3 0.1/3 0.13/3.3 0.14/3.5 0.13/3.3 0.33/8.4 0.3/8 0.33/8.5 0.4/9 0.34/8.6 90 90 90 90 50 50 50 50 0.14/3.5 0.14/3.6 0.14/3.6 0.144/0.365 0.12/3.1 0.12/3.1 0.124/3.15 0.1/3 0.33/8.4 0.33/8.5 0.33/8.5 0.34/8.6 380.0 422.0 491.0 538.0 * Tighter tolerances 50 GL25AR380005 50 GL25AR422005 50 GL25AR491005 50 GL25AR538005 are available, consult factory. GL25 Series Outline Drawing GL15 Series Outline Drawing ENCAPSULATION (FLAT SURFACE FOR EASE OF PICK & PLACE) ENCAPSULATION (FLAT SURFACE FOR EASE OF PICK & PLACE) L L 0.10 2.6 0.91 2.3 0.059 TYP 1.5 0.08 2 TIN PLATE TIN PLATE B ID 176° ± 4° 0.20 5.2 0.11 2.8 0.23 5.8 B ID 0.19 4.7 176° ± 4° PAD LAYOUT All dimensions are in/mm. 0.2 6 0.39 10 PAD LAYOUT All dimensions are in/mm. Carrier and reel specifications are on the web at www.spraguegoodman.com/800/800p1/html SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 11 SURFCOIL® SMT INDUCTORS SG-800H CARRIER SPECIFICATIONS Dimension Model A Tolerance B C D 0.008 0.008 0.012 ± -—–— ±-—–— ± -—–— 0.2 0.2 0.3 Series E 0.002 ±-—–— 0.05 F 0.004 0.004 ±-—–— ±-—–— 0.1 0.1 G H K L 0.002 ±-—–— 0.05 0.004 ±-—–— 0.1 0.008 ±-—–— 0.2 0.002 ±-—–— 0.05 M N 0.004 0.004 + -—–— ± -—–— 0.1 0.1 - 0 0.11 — - –— 2.8 0.14 — - –— 3.6 0.31 — - –— 8.0 0.14 — - –— 3.5 0.069 — - —–— 1.75 0.16 — - –— 4.0 0.079 — - ––— 2.0 0.16 — - ––— 4.0 0.091 — - ––— 2.3 0.01 — - –— 0.3 0.059 — - –––––— 1.5 GLU, GLW 0.14 — - —– 3.6 0.095 — - –––— 2.4 0.19 — - –— 4.9 0.11 —–––– 2.9 0.472 — - –—— 12.0 0.31 —–––– 8.0 0.22 — - –––— 5.5 0.14 —–––— 3.5 0.069 — - —–— 1.75 0.069 —–––––— 1.75 0.31 -—––––– 8.0 0.16 — - —–– 4.0 0.079 — - —––– 2.0 0.079 — - —–––– 2.0 0.16 -—––––— 4.0 0.16 — - –— 4.0 0.13 — - ––––– 3.4 0.073 — - ––––— 1.85 0.01 — - –— 0.3 0.01 — - –— 0.3 0.059 — - ––––— 1.5 0.059 — - ––––— 1.5 0.043 — - ––––— 1.1 GLX 0.057 — - —–––– 1.45 0.089 — - —–––– 2.25 0.31 — -— 8.0 0.14 — -— 3.5 0.069 — - ––––— 1.75 0.16 — -— 4.0 0.079 — - —–––– 2.0 0.16 — -— 4.0 0.055 — - ––––— 1.4 0.0098 — - –––—— 0.25 0.059 — - ––––— 1.5 0.043 — - ––––— 1.1 GLY, GLYC 0.039 — - —–––– 1.0 0.071 — - ––––— 1.8 0.31 — -— 8.0 0.14 — -— 3.5 0.069 — - ––––— 1.75 0.16 — -— 4.0 0.079 — - ––––— 2.0 0.16 — -— 4.0 0.039 — - ––––— 1.0 0.0098 — - —–––— 0.25 0.059 — - ––––— 1.5 — GLZ, GLZB, GLZP 0.028 — - —–––– 0.71 0.048 — - ––––— 1.21 0.31 — -— 8.0 0.14 — -— 3.5 0.069 — - ––––— 1.75 0.16 — -— 4.0 0.079 — - ––––— 2.0 0.16 — -— 4.0 — — — — GLA, GLAC, GLC, GLD GLB, GLBP Carrier Outline Drawing H E G M — — L COVER TAPE D C B K A F N Not to scale. All dimensions are in/mm. REEL SPECIFICATIONS Dimension Model Series Qty A — 0.079 ±— - ––––— 2.0 Tolerance GL A, GLAC, GLC, GLD, GLU, GLW B C 0.02 0.02 ±— - ––— ± — - –— 0.5 0.5 D E T W 0.03 ±— - –— 0.8 0.02 ±— - –— 0.5 0.02 ±— - –— 0.5 0.01 ±— - –— 0.3 2,000 7.01 - –— — 178 2.4 -— — 60 0.51 -— — 13 0.83 — - –— 21 0.079 — - ––––— 2.0 0.043 — - ––––— 1.1 0.35 — - ––— 9.0 3,000 7.01 — - —– 178 2.4 — -— 60 0.51 — -— 13 0.83 — - —– 21 0.079 — - ––––— 2.0 0.043 — - –––—– 1.1 0.35 — - –— 9.0 500 7.01 - –— — 178 2.4 -— — 60 0.51 — - –— 13 0.83 — - –— 21 0.079 — - ––––— 2.0 0.043 — - —— 1.1 0.51 — -— 13 7.01 - —– — 178 2.4 — -— 60 0.51 -— — 13 0.83 - —– — 21 0.079 — - ––––— 2.0 0.043 — - –––—– 1.1 0.35 — - –— 9.0 Reel Outline Drawing W C E A GL X, GLY, GLYC GLB, GLBP GLZ, GLZB, GLZP 12 10,000 B D T Not to scale. All dimensions are in/mm. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com ©2005 SPRAGUE-GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED. PRINTED IN U.S.A. 2.50501
GLY10N05 价格&库存
很抱歉,暂时无法提供与“GLY10N05”相匹配的价格&库存,您可以联系我们找货
