ASCQ000603037N5H00
ASCQ000603037N5H00
    CHILISIN(奇力新)
    INDUCTOR RF
ASCQ000603037N5H00 数据手册
Automotive Chip Inductor ASCQ Series AEC-Q200 RoHS Compliant Halogen Free REACH Compliant ■ Part Numbering A Grade SCQ Series Name 00 Control Code 060303 Dimensions Code (mm) 060303 0.6x0.3x0.3 1N0 Inductance (nH) 0N6 0.6 1N0 1.0 10N 10 B 00 Tolerance Internal Code B C H ±0.1nH ±0.2nH ±3% This specification applies to Multilayer Chip Inductors for Automotive Electronics based on AEC-Q200 except for Power train and Safety. Automotive Chip Inductor ASCQ Series AEC-Q200 ASCQ00060303 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. ASCQ000603030N6□00 ASCQ000603030N7□00 ASCQ000603030N8□00 ASCQ000603030N9□00 ASCQ000603031N0□00 ASCQ000603031N1□00 ASCQ000603031N2□00 ASCQ000603031N3□00 ASCQ000603031N4□00 ASCQ000603031N5□00 ASCQ000603031N6□00 ASCQ000603031N7□00 ASCQ000603031N8□00 ASCQ000603031N9□00 ASCQ000603032N0□00 ASCQ000603032N1□00 ASCQ000603032N2□00 ASCQ000603032N3□00 ASCQ000603032N4□00 ASCQ000603032N5□00 ASCQ000603032N6□00 ASCQ000603032N7□00 ASCQ000603032N8□00 ASCQ000603032N9□00 ASCQ000603033N0□00 ASCQ000603033N1□00 ASCQ000603033N2□00 ASCQ000603033N3□00 ASCQ000603033N4□00 ASCQ000603033N5□00 ASCQ000603033N6□00 ASCQ000603033N7□00 Inductance L,Q Q SRF RDC IDC Tolerance (nH) Test Freq. Min. (MHz)Min. (Ω)Max. (mA)Max. (±%) 0.6 0.7 0.8 0.9 1.0 1.1 1.20 1.30 1.40 1.50 1.60 1.70 1.80 1.90 2.00 2.10 2.20 2.30 2.4 2.5 2.6 2.7 2.8 2.9 3 3.1 3.2 3.3 3.4 3.5 3.6 3.7 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 9500 9300 9100 8900 8700 8600 8400 8200 8100 8000 0.06 0.06 0.06 0.06 0.07 0.07 0.08 0.09 0.12 0.15 0.19 0.11 0.12 0.13 0.15 0.16 0.20 0.24 0.26 0.28 0.30 0.32 0.20 0.22 0.24 0.25 0.28 0.28 0.29 0.30 0.32 0.36 900 900 900 900 850 850 800 760 640 600 510 680 640 620 600 550 500 460 430 415 405 400 500 480 460 450 415 415 410 405 400 370 B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B Note: When ordering, please specify tolerance code. Tolerance: B=±0.1nH / C=±0.2nH / H=±3% 1. Operating temperature range 55 125 2. Applied the current to coils, the inductance shall be less than 10% initial value 3. Measure Equipment: L & Q: Agilent E4991A+Agilent 16197A SRF: Agilent E4991A or HP19196C RDC: HP4338B or CHEN HWA 502 Automotive Chip Inductor ASCQ Series AEC-Q200 ASCQ00060303 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. ASCQ000603033N8□00 ASCQ000603033N9□00 ASCQ000603034N3□00 ASCQ000603034N7□00 ASCQ000603035N1□00 ASCQ000603035N6□00 ASCQ000603036N2□00 ASCQ000603036N8□00 ASCQ000603037N5□00 ASCQ000603038N2□00 ASCQ000603039N1□00 ASCQ0006030310N□00 ASCQ0006030312N□00 ASCQ0006030315N□00 ASCQ0006030318N□00 ASCQ0006030322N□00 Inductance L,Q Q SRF RDC IDC Tolerance (nH) Test Freq. Min. (MHz)Min. (Ω)Max. (mA)Max. (±%) 3.8 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 12 15 18 22 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 500 MHz,500 mV 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 7800 7700 6500 6400 6100 5500 5100 4800 4600 4300 4000 3800 3300 2600 2300 1900 0.40 0.41 0.48 0.42 0.45 0.47 0.52 0.55 0.55 0.57 0.65 0.85 0.85 0.89 1.05 1.29 355 350 320 350 330 325 305 305 305 290 270 230 230 220 205 190 B B C C C C C H H H H H H H H H Note: When ordering, please specify tolerance code. Tolerance: B=±0.1nH / C=±0.2nH / H=±3% 1. Operating temperature range 55 125 2. Applied the current to coils, the inductance shall be less than 10% initial value 3. Measure Equipment: L & Q: Agilent E4991A+Agilent 16197A SRF: Agilent E4991A or HP19196C RDC: HP4338B or CHEN HWA 502 Automotive Chip Inductor ASCQ Series AEC-Q200 ASCQ00060303 Type ■ Characteristics Graph 1 0.5 0 1 10 100 1000 2.5 2 0 1 10 100 1000 100 1000 L(nH) Q L(nH) 2 0 10000 1000 L(nH) Q L(nH) 1000 2 1.5 0 10000 10 100 1000 0 10000 FREQUENCY(MHz) RDC
ASCQ000603037N5H00 价格&库存
很抱歉,暂时无法提供与“ASCQ000603037N5H00”相匹配的价格&库存,您可以联系我们找货
