东莞市佳仪电子有限公司
ISO 9001:2008
JEC Electronic CO.,LTD
Certified Firm
RoHS compliance
客户:
Customer:
日期:2019-4-19
安规(Y1/Y2)电容器承认书
SPECIFICATION
品名:
Part name:
FOR
APPROUAL
Safety standard Recognized Ceramic Capacitor
JD (Y1) / JY (Y2) 40/85/21/C
User part No: JD472M2GY5VS7LE
承认章:
VENDER
核
准
Approved by:
CUSTOMER
审
核
制
作
台湾:智中电子股份有限公司
JYH CHUNG ELECTRONIC CO.,LTD
台中市大理区仁化里工业一路 2 号
TEL:886-4-24912990
FAX;886-4-24912993
Http://www.jecco.cn
1
Introduction
This specification is applied to following safety standard recognized ceramic capacitor for
electronics appliance.
General Specifications :
-40℃
Operating Temp. Rang
Approved Monogram
to
+85℃
UL, SEMKO, FIMKO,NEMKO, SEV,
JD (Y1)
X1
400VAC
Y1
400VAC
DEMKO, VDE , CQC, KC
JY (Y2)
X1
400VAC
Y2
300VAC
Dielectric
Rated
JD (Y1)
400 VAC
Test
JD (Y1)
4000 VAC for 1 min.
Withstanding Voltage
Voltage
JY (Y2)
300 VAC
Voltage
JY (Y2)
2600 VAC for 1 min.
Y5P、Y5U
TANδ≦2.5%, measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃
Y5V
TANδ≦5.0%, measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃
Dissipation Factor(D.F)
Capacitance( C )
Range
Tolerance
JD (Y1)
10pF to 4700pF.measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃
JY (Y2)
10pF to10000pF.measured at 1KHz±10%, 1.0–5.0 Vrms, 25℃
Y5P for B
±10%
Y5U for E
±10%、±20
Y5V for F
±20%
Insulation Resistance( I R )
10,000 MΩ min, 500 VDC
Type Code
Cap. Change
Y5P
±10 %, max.
-40℃to+85℃
Y5U
+22%,–56 % max.
-40℃to+85℃
Y5V
+30%,–80 % max.
-40℃to+85℃
Temperature
Characteristics
Temp. Range
The reference
temperature: 25 ℃
Approval Standard And Recognized NO. :
Safety Standard
CSA ( Canada )
UL ( USA )
VDE ( Germany )
Standard NO.
UL60384-14
Recognized NO.
JD (Y1)
JY (Y2)
E187963
E187963
137027
123326
Monogram
DIN EN 60384-14(VDE 0565-1-1):2014-04;
EN 60384-14:2013-08 IEC 60384-14(ed.4)
SEMKO ( Sweden )
EN 60384-14:2013
1610477
1610476
SEV (Switzerland )
EN 60384 -14:13
16.0273
16.0272
FIMKO ( Finland )
EN 60384-14:2013
FI 29416
FI 29417
NEMKO ( Norway )
EN 60384-14:2013
NO.P1622115
NO.P16221156
DEMKO ( Denmark )
EN 60384-14:2013
D-05288
D-05287
FIMKO CB
IEC 60384-14:2013
FI 9088
FI 9090
CQC ( China )
IEC 60384-14:2005
CQC 10001046943
CQC 10001046944
SU03069-14001A
SU03069-14002A
KC ( Kti )
Approved
K60384-1
(2006-12)
K60384-14
(2006-12)
CB
2
Capacitance and dimensions :
JD (Y1) SERIES
PART
NUMBER
T.C.
CAP.
TOL.
Dimension(mm)
D max
F
T max
d(±0.05)
7.0ф
10±0.8
<6.0
0.56
JD10KY5P Y1
10pF
To
To
JD82KY5P Y1
82pF
JD101KY5P Y1
100PF
7.0ф
10±0.8
<6.0
0.56
JD151KY5P Y1
150PF
7.0ф
10±0.8
<6.0
0.56
7.0ф
10±0.8
<6.0
0.56
JD221KY5P Y1
±10%
220PF
K ±10%
JD331KY5P Y1
(Y5P)
330PF
8.0ф
10±0.8
<6.0
0.56
JD471KY5P Y1
470PF
7.0ф
10±0.8
<6.0
0.56
JD561KY5P Y1
560PF
8.5ф
10±0.8
<6.0
0.56
JD681KY5P Y1
680PF
9.5ф
10±0.8
<6.0
0.56
JD102KY5P Y1
1000PF
12.0ф
10±0.8
<6.0
0.56
JD102KY5U Y1
1000PF
9.0ф
10±0.8
<6.0
0.56
JD471MY5U Y1
470PF
7.0ф
10±0.8
<6.0
0.56
JD561MY5U Y1
560PF
7.5ф
10±0.8
<6.0
0.56
JD681MY5U Y1
680PF
7.5ф
10±0.8
<6.0
0.56
7.5ф
10±0.8
<6.0
0.56
K ±10%
JD102MY5U Y1
+22~-56%
1000PF
JD152MY5U Y1
(Y5U)
1500PF
9.0ф
10±0.8
<6.0
0.56
JD222MY5U Y1
2200PF
10.5ф
10±0.8
<6.0
0.56
JD332MY5U Y1
3300PF
13.0ф
10±0.8
<6.0
0.56
JD472MY5U Y1
4700PF
15.0ф
10±0.8
<6.0
0.56
JD102MY5V Y1
1000PF
7.0ф
10±0.8
<6.0
0.56
JD152MY5V Y1
1500PF
8.5ф
10±0.8
<6.0
0.56
9.0ф
10±0.8
<6.0
0.56
M ±20%
JD222MY5V Y1
+30~-80%
2200PF
M ±20%
JD332MY5V Y1
(Y5V)
3300PF
10.5ф
10±0.8
<6.0
0.56
JD392MY5V Y1
3900PF
11.5ф
10±0.8
<6.0
0.56
JD472MY5V Y1
4700PF
12.0ф
10±0.8
<6.0
0.56
Dimensions and Tolerance :
TYPE:FS
B= 3.0 mm max for FS
F FOR JD= 7.5 or 9.5 or12.5±0.8 mm
F FOR JY= 6.35 or 7.5 or 9.5 ±0.8 mm
L=3 ~ 33 mm.
3
JY (Y2) SERIES
PART
NUMBER
T.C.
CAP.
TOL.
Dimension(mm)
D max
F
T max
d(±0.05)
6.5ф
7.5±0.8
<5.0
0.56
JY10KY5P Y2
10pF
To
To
JY82KY5P Y2
82pF
JY101KY5P Y2
100PF
6.5ф
7.5±0.8
<5.0
0.56
JY151KY5P Y2
150PF
6.5ф
7.5±0.8
<5.0
0.56
6.5ф
7.5±0.8
<5.0
0.56
JY221KY5P Y2
±10%
220PF
JY271KY5P Y2
(Y5P)
270PF
6.5ф
7.5±0.8
<5.0
0.56
JY331KY5P Y2
330PF
6.5ф
7.5±0.8
<5.0
0.56
JY471KY5P Y2
470PF
7.5ф
7.5±0.8
<5.0
0.56
JY561KY5P Y2
560PF
7.5ф
7.5±0.8
<5.0
0.56
JY681KY5P Y2
680PF
7.5ф
7.5±0.8
<5.0
0.56
JY102KY5P Y2
1000PF
9.0ф
7.5±0.8
<5.0
0.56
JY471KY5U Y2
470PF
6.5ф
7.5±0.8
<5.0
0.56
7.5ф
7.5±0.8
<5.0
0.56
JY561KY5U Y2
K ±10%
K ±10%
560PF
680PF
7.5ф
7.5±0.8
<5.0
0.56
JY102MY5U Y2
+22~-56%
1000PF
7.5ф
7.5±0.8
<5.0
0.56
JY222MY5U Y2
(Y5U)
2200PF
9.5ф
7.5±0.8
<5.0
0.56
11.0ф
7.5±0.8
<5.0
0.56
JY681KY5U Y2
M±20%
JY332MY5U Y2
3300PF
JY472MY5U Y2
4700PF
13.0ф
7.5±0.8
<5.0
0.56
JY102MY5V Y2
1000PF
7.0ф
7.5±0.8
<5.0
0.56
JY152MY5V Y2
1500PF
7.0ф
7.5±0.8
<5.0
0.56
JY222MY5V Y2
2200PF
7.5ф
7.5±0.8
<5.0
0.56
JY332MY5V Y2
3300PF
9.0ф
7.5±0.8
<5.0
0.56
9.5ф
7.5±0.8
<5.0
0.56
9.5ф
7.5±0.8
<5.0
0.56
JY392MY5V Y2
3900PF
JY472MY5V Y2
+30~-80%
M±20%
4700PF
JY562MY5V Y2
(Y5V)
5600PF
11.5ф
7.5±0.8
<5.0
0.56
JY682MY5V Y2
6800PF
11.5ф
7.5±0.8
<5.0
0.56
JY822MY5V Y2
8200PF
14.5ф
7.5±0.8
<5.0
0.56
JY103MY5V Y2
10000PF
14.5ф
7.5±0.8
<5.0
0.56
JY103MY5V Y2
10000PF
14.5ф
9.5±0.8
<5.0
0.56
MARKING:
JD (Y1)
JY (Y2)
Trade mark
Type , Capacitance
and Tolerance
4
性能与试验 (Performance and Test) :
编号
项
目
性
能
试
1
外观及尺寸
参考第 2~ 3 页之图表。
1~1
2
记号标示
必须干净及清晰。
2~1
验
方
法
生产线必须做全数外观检验并分别剔除不
良品。尺寸利用微测仪或卡尺测量。
标示需能承受异丙醇擦拭。
额定电压:400 VAC for Y1。
耐
电
3
端子间
无异常。
3~1
试验电压:4000 VAC,时间一分钟。
额定电压:300 VAC for Y2。
压
试验电压:2600 VAC,时间一分钟。
I
端子、封装间
无异常。
3~2
试验电压:2000 VAC,时间一分钟。
注意: 1.批量生产时测试时间为 2 秒钟。
2.耐压测试应为缓升或零启动。
3.工作电流按容量与电压大小限于 2~5mA。
4
5
6
7
耐电压(Ⅲ)(适用于安全
(1)纱布须不引燃。
性能符号 A2)
(2)电容器须不冒烟。
耐电压(Ⅳ)(适用于安全
性能号 B2)
4~1
依 CNS 3432,11 节规定。
5~1
依 CNS3432, 12 节规定。
(3)元件与封装须不散飞。
(4)端子不能移动离开安
装位置 3mm 以上。
绝缘
端子间
10000MΩ以上。
电阻
端子、封装间
以上。
静电容量
10000MΩ
必须符合要求之容许差规格内。
6~1
测定电压为 500±50V,在一分钟内要在
规定值内。
7~1
测定温度 25±2℃。
7~2
测定电压:1Vrms 以下。
7~3
测定频率:1KHz±10%。
8~1
与第 7 项同。
散逸因子(CKS):
8
散逸因子
特性:B, E 2.5%以下。
特性:F 5.0%以下。
温度阶段
使用温度特性(CKS):
9
静电容量
温度特性
9~1
1、20±2℃→2、﹣25±2℃
→3、20±2℃→4、85±2℃
范围内静电容量变化率。
→5、20±2℃
特性 B 变化率±10%以内。
容量变化率:(CKS)
特性 E 变化率+22%—56%以内。
C.C(%)=(Ctx—Ct20)/Ct20*100
特性 F 变化率+30%—80%以内。
9~2
Ctx:温度阶段 1、3、5 除外,2 到 4
之间任何温度时之容量值。
Ct20:温度阶段 3 时之容量值。
导线不断裂,电容器不破损。
10~1
抗拉强度
10
端子强度
10~2
导线不致被折断,电容器不破
弯曲强度
损。
线径(mm)
负荷重 kgs
时间(秒)
0.5Φ
0.5
10
0.6Φ~0.8Φ
1
10
固定后负荷施力方向为端子引出之方向。
线径(mm)
10~3
负荷重 kgs
弯曲角度
0.5Φ
0.25
爲 90° 两
0.6Φ~0.8Φ
0.5
回以上。
5
外观
无显著异常。
耐
耐电压(I)端子间
合于编号 3 之规定。
湿
绝缘
端子间
编号 6 所规定值之 1/2 以上。
性
电阻
端子、封装间
11
稳
静电容量变化率
状
湿度:90~95%RH。
特性 E ±20%以内。
11~3
时间:500±12 小时。
特性 F ±30%以内。
11~4
取出置常温下 1~2 小时后测之。
12~1
温度:40±2℃。
12~2
湿度:90~95%RH。
12~3
时间:500±12 小时。
特性 E ±20%以内。
12~4
电压:依交流额定电压印加之。
特性 F ±30%以内。
12~5
电流:50mA 以下。
12~6
取出置常温下 1~2 小时后测定之。
13~1
温度:85±3℃。
13~2
时间:1000±12 小时。
13~3
电压:依 200% 额定电压印加之。
13~4
电流:50mA 以下。
13~5
取出置常温下 1~2 小时后测定之。
特性 B、E
5%以下。
特性 F 7.5%以下。
外观
无显著异常。
耐电压(I)端子间
合于编号 3 之性能。
绝缘
编号 6 所规定之 1/2 以上。
电阻
端子间
端子、封装间
耐
湿
11~2
散逸因子(CKS):
散逸因子
12
温度:40±2℃。
CKS: 特性 B ±15%以内。
定
态
11~1
CKS: 特性 B ±15%以内。
静电容量变化率
负
荷
散逸因子(CKS):
散逸因子
特性 B、E
5%以下。
特性 F 7.5%以下。
外观
无显著异常。
耐电压(I)端子间
合于编号 3 之规定。
高
绝缘
端子间
编号 6 所规定之 1/2 以上。
温
电阻
端子、封装间
负
13
荷
CKS: 特性 B ±15%以内。
静电容量变化率
连
14
15
特性 E ±20%以内。
特性 F ±30%以内。
散逸因子
散逸因子(CKS):
续
特性 B、E
特性 F 7.5%以下。
5%以下。
焊
外观
无显著异常。
14~1
焊锡温度 350±10℃。
锡
耐电压(I)端子间
合于编号 3 之性能。
14~2
浸渍时间 3.5±0.5 秒。
耐
静电容量变化率
CKS: 特性 B ±10%以内。
14~3
在常温常湿中放置 4~24 小时后测定之。
导线之横截面积上须有圆周之
15~1
焊锡温度为 260±5℃(符合 RoHS)。
3/4 以上之面积为焊锡所付着。
15~2
浸渍时间为 2±0.5 秒。
热
特性 E±15%以内。
性
特性 F±20%以内。
焊锡之付着性
试验开始后,在第 1 次及第 2 次移开试验火
16
耐燃性
适用于安全性能符号 A2,B2。
16~1
焰后,不得燃烧 15 秒以上或不爆炸。而且
在第 3 次后,继续燃烧 1 分钟而不爆炸。
将样本完全浸渍于异丙醇溶剂
17
耐溶剂性(本体)
中 5±0.5 分后取出,观察本体
有无溶解,而后放置于常温中
17~1
试验后其电性能须符合标准。
48 小时后,量测其电气特性。
使用棉纱沾异丙醇,
以每 1 平方公分 5±0.5N
18
耐溶剂性 (标志)
18~1
之力,1 秒钟来回两次擦拭本体上的标示,
往返 5 次。标志应清晰可辨。
6
品名說明 ( Part No. Explain ) :
品名 ( Part No. ):
J
D
說明 ( Explain No. ):
1
2
2
2
2
3
M
2
4
G
Y
5
5
U
6
S
L
8
9
E
10
TO JEC Marking
firstword
Rated voltage:
Y-for Y2,X1 capacitance
2F-for 300V
D-for Y1,X1 capacitance
2G-for 400V
Rated capacitance value:
221-for 220PF
222-for 2200PF
Tolerance:
Material:
J-for ± 5%
Y5P-forY5P
K-for ± 10%
Y5U-forY5U
M-for ± 20%
Y5V-forY5V
Lead form:
Coating:
S for F.S.
Pitch:
O for F.O.
5-for 5mm
Length:
I for F.I.
7-for 7.5mm
5 - for 5mm
A for AA
9-for 9.5mm
0 - for 10mm
2 for A2
0-for 10mm
L - for 25mm
B-for 12.5mm
T - for taping
E:Epoxy
G:Phenolic resin
脚型说明(Lead form) :
F.I.型
F.O. 型
F.S. 型
A2. 型
AA. 型
包装说明(Packaging) :
1.inside:
One bag 500PCS-1000PCS.
PE bag size:
13×15×0.1mm
16×18×0.1mm
18×20×0.1mm
20×25×0.1mm
2.outsize:
Use box packaging
Box size:
305×215×145mm
450×325×160mm
7
Part No.:
JD472M2GY5VS7LE
D:
11.0
mm / MAX
T:
6.0
mm / MAX
F:
7.5 ±
L:
25
d:
0.56
B:
3
0.8
mm
MAX
0.05
mm
mm / MAX
TEST CONDITIONS
测
试
条
件
温度范围
-40℃ ~
+85℃
TEST FREQ & VOL
測試頻率與電壓
1K Hz 1.0 V
TEST TEMP
測試溫度
25 ℃ ± 2 ℃
RATED CAP.
公稱靜電容量
4700
PF
CAP. TOL.
靜電容量容許差
± 20
TEMP. CHARACT
溫度特性
Y5V
INITIAL DF δ
初期損耗角 δ
2.5%
INSULATION RESISTANCE INITIAL
初期絕緣電阻
10000 MΩMIN
CURRENT
工作电流
≦5mA
BETWEEN TERMINALS
端子間
AC4000V
RATED VOLTAGE
額定電壓
X1 400VAC , Y1 400VAC
MAX
FOR 60 SEC
材质温度曲线图:
8
很抱歉,暂时无法提供与“JY332M2FY5VS7LE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39224
- 100+0.36609
- 300+0.33994
- 500+0.31379
- 2000+0.30072
- 5000+0.29287
- 国内价格
- 10+0.32098
- 100+0.25834
- 300+0.22713
