31343103
31343103
    METZCONNECT
    插件,P=3.5mm
    接线端子 间距:3.50mm 1x3P 直插
31343103 数据手册
Data Sheet PT093xxVBBN Page 1/5 P/N 313431xx xx=number of poles 2018/02/02 Illustration see enlarged drawing at the end of the document Product specification • pin header, solderable • centerline 3.50 mm, direction of connection vertical 0° • closed ends • color black • codeable Page 2/5 P/N 313431xx xx=number of poles 2018/02/02 Data Sheet PT093xxVBBN Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 3.5 mm 2 16 CTI 600 2.7 mm IP 00 III 3 200.0 V 2.5 kV III 2 500.0 V 2.5 kV Approvals V/A 300 / 8 9 A / 125 V / 2.5 kV / 3 / Material insulating material flammability class Glow-Wire Flammability GWFI Glow-Wire Flammability GWIT contact pin material contact pin surface PA66 V0 960 °C acc. to IEC 60695-2-12 775 °C acc. to IEC 60695-2-13 CuZn Ni + Sn Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance Acc. to JEDEC JESD22-B102E 245°C/5s ISO 2768 -mH II 2 500.0 V 2.5 kV Page 3/5 P/N 313431xx xx=number of poles 2018/02/02 Data Sheet PT093xxVBBN Matching Part to P/N 310891 313391 316131 316141 ASP043 ASP063 Product name FT143xxVBFC Typ 089 RP033xxVBLC Typ 339 RP043xxHBLD Typ 613 RP043xxHBLC Typ 614 SP043xxVBNN ASP043 SP063xxVGNN ASP063 Accessories P/N 720293-01-2 Product name 720293 Data Sheet PT093xxVBBN Illustration Drawing L=(pole size - 1) x centerline + 5 [0.197] Page 4/5 P/N 313431xx xx=number of poles 2018/02/02 Data Sheet PT093xxVBBN PCB Layout Powered by TCPDF (www.tcpdf.org) Page 5/5 P/N 313431xx xx=number of poles 2018/02/02
31343103 价格&库存
很抱歉,暂时无法提供与“31343103”相匹配的价格&库存,您可以联系我们找货
