31524103
31524103
    METZCONNECT
    插件,P=3.5mm
    接线端子 间距:3.50mm 1x3P 直插
31524103 数据手册
Data Sheet PW063xxVBBN Page 1/5 P/N 315241xx xx=number of poles 2017/01/25 Illustration see enlarged drawing at the end of the document Product specification • pin header, THR solderable • centerline 3.50 mm, direction of connection vertical 0° • closed ends • color black • Tape & Reel packaging • with alternative face, codeable Page 2/5 P/N 315241xx xx=number of poles 2017/01/25 Data Sheet PW063xxVBBN Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 3.2 mm 2 24 CTI 400 2.48 mm IP 10 III 3 160 V 2.5 kV III 2 320 V 2.5 kV Approvals V/A 300 / 10 10 A / 130 V / 2.5 kV / 3 / IEC 61984 Material insulating material flammability class Glow-Wire Flammability GWFI Glow-Wire Flammability GWIT contact pin material contact pin surface PA46 V0 CuMg Cu + Sn Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance Acc. to IPC/JEDEC J-STD-020D-MSL 1 ISO 2768 -mH II 2 320 V 2.5 kV Page 3/5 P/N 315241xx xx=number of poles 2017/01/25 Data Sheet PW063xxVBBN Matching Part to P/N 315131 315141 FW143XXVBFC SW063XXVBNN Product name RW043xxHBLD Typ 513 RW043xxHBLC Typ 514 FW143xxVBFC SW063xxVBNN Accessories P/N 700268-01-0 (on request) 700268-0132 (on request) 700268-0194 (on request) Product name F_Kodier sw F_Kodier sw F_Kodier sw Data Sheet PW063xxVBBN Illustration Drawing L=(pole size - 1) x centerline + 4.9 [0.193] Page 4/5 P/N 315241xx xx=number of poles 2017/01/25 Data Sheet PW063xxVBBN PCB Layout Powered by TCPDF (www.tcpdf.org) Page 5/5 P/N 315241xx xx=number of poles 2017/01/25
31524103 价格&库存
很抱歉,暂时无法提供与“31524103”相匹配的价格&库存,您可以联系我们找货
