4628
4628
    KEYSTONE
    保险丝HLDR盒250V 5A PCB
4628 数据手册
5mm x 20mm FUSE HOLDERS SLIM LINE LOW PROFILE .354 [9.0] .953 [24.2] .382 [9.7] .472 [12.0] .375 [9.6] .951 [24.2] .425 [10.8] .467 [11.9] .156 [4.0] .167 [4.3] .130 [3.3] DIA. .886 [22.5] . .047 [1.20] .860 [21.9] .051 [1.30] Mounting Detail • Optional cover with window protects and insulates fuse • Flame Retardant • Not UL rated .052 [1.30] DIA. (2) PLS SPECIFICATIONS Base & Cover: Nylon, UL Rated 94V-0 Clips: Brass, Tin Plate Rated: 5 Amps @ 250V AC CAT. NO. 4628 - Holder CAT. NO. 4628C - Cover only (with window) 5mm & 3AG FUSE HOLDERS Mounting Detail .886 [22.5] • Low profile, space saving design • Optional cover protects and insulates fuse • Flame Retardant • Not UL rated .860 [21.9] .052 [1.30] DIA. (2) PLS SPECIFICATIONS Base & Cover: Nylon, UL Rated 94V-0 Clips: Brass, Tin Plate Rated: 5 Amps @ 250V AC CAT. NO. 4527 - Holder CAT. NO. 4527C - Cover only FULLY INSULATED PC SNAP-IN ® .920 [23.4] 1.142 [29.0] REF. .866 [22.0] .413 [10.5] DIA. .500 [12.7] .417 [10.6] .197 [5.0] .020 [.50] (2) PLS .047 [1.20] • Supplied unassembled • Shock resistant • Fuse can be accessed from board edge • Fuse is completely enclosed, protecting use from shorting and breaking • Not UL rated .492 [12.5] .070 [1.80] .900 [22.9] .089 [2.25] Mounting Detail Mounting Detail .492 [12.5] .052 [1.30] DIA. (2) PLS SPECIFICATIONS Base: PBT Contacts: Brass, Tin Plate Rated: 10 Amps @ 250V AC CAT. NO. 4525 .220 [5.6] .062 [1.55] .217 [5.5] • Snap-in design for wave soldering • Flame Retardant • Optional cover protects and insulates fuse - Cat. No. 3527C .900 [22.9] .078 [2.00] DIA. (2) PLS SPECIFICATIONS Base: .062 (1.57) FR-4, UL Rated 94V-0 Clips: Brass, Tin Plate UL Rated: 6.3 Amps @ 250V AC CAT. NO. 3527 - Holder 3AG FUSE HOLDERS TERMINATION LUGS CAN BE USED WITH WIRES OR PC MOUNT ® PRESS-FIT, IDEAL FOR WAVE SOLDERING .450 [11.4] .310 [7.9] .140 [3.6] DIA. HOLE 1.000 [25.4] .281 [7.2] .188 [4.8] .078 [1.98] DIA. .060 [1.50] .300 [7.6] (2) PLS 1.375 [34.9] .125 [3.2] 1.380 [35.1] SPECIFICATIONS Base: .062 (1.57) FR-4, UL Rated 94V-0 Clips: Brass, Tin Plate UL Rated: 15 Amps @ 500VAC SPECIFICATIONS Base: .062 (1.57) FR-4, UL Rated 94V-0 Clips: Brass, Tin Plate UL Rated: 15 Amps @ 500VAC Mounting Detail Mounting Detail 1.375 [35.0] .300 [7.6] (2) PLS 1.000 [25.4] CAT. NO. 3526 .140 [3.6] .040 [1.00] Optional cover available - Cat. No. 4245C CAT. NO. 4245 .070 [1.78] DIA. (4) PLS Optional cover available - Cat. No. 4245C SNAP-IN DESIGN ASSURES STABILITY DURING WAVE SOLDERING MOLDED CASE .703 [17.9] REF. .130 [3.3] .300 [7.6] (2) PLS 1.375 [34.9] SPECIFICATIONS Base: .032 (1.57) FR-4, UL Rated 94V-0 Clips: Brass, Tin Plate UL Rated: 15 Amps @ 500VAC .420 [10.7] .060 [1.50] Mounting Detail 1.375 [35.0] .300 [7.6] (2) PLS CAT. NO. 4250 Optional cover available - Cat. No. 4245C 44 .430 [10.9] Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com .070 [1.78] DIA. (4) PLS 1.650 [41.9] SPECIFICATIONS Base: LCP, UL Rated 94V-0 Clips: .020 (.51) Brass Nickel Plated UL Rated: 15 Amps @ 250 VAC CAT. NO. 3523 RoHS COMPLIANT ~ ISO 9001 CERTIFIED .312 [7.9] DIA C'BORE .144 [3.7] DIA. HOLE .250 [6.4] Optional cover available - Cat. No. 4245C ® .468 [11.9] www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 Mounting Hole: .144 (3.7) Dia.
很抱歉,暂时无法提供与“4628”相匹配的价格&库存,您可以联系我们找货
  • 49+6.4447049+0.82960
  • 100+6.40550100+0.82450
  • 250+6.34110250+0.81620
  • 500+5.93640500+0.76420
  • 1000+4.460801000+0.57420
库存:49
4628
    • 1+7.22249
    • 10+6.95499
    • 100+6.15250
    • 500+5.99200
