TJ-F10RYTLF62-A3
TJ-F10RYTLF62-A3
    TOGIALED(台湾统佳)
    插件,P=2.54mm
    发光二极管/LED 10mm圆头白发红透明
TJ-F10RYTLF62-A3 数据手册
承 認 書 Specification For Approval Customer: Description: 10MM圆头白发红透明 Part number: TJ-F10RYTLF62-A3 Date: Approved By: Customer Check Inspection Approval Date Prepared By: TONGJIA Drawn Check Approval Date GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com Features : * Low power consumption * Small efficiency. * Versatile mounting on p.c board or panel. * I.C compatible/ low current requirement. * Package Dimensions: Unit : mm Note: 1:All dimensions are in millimeters (inches). 2:Tolerance is ±0.25mm (.010”) unless otherwise noted. 3: Specifications are subject to change without notices. 4:This specification is for reference only for one year GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com Absolute Maximum Ratings at Ta=25℃ 项目 符号 额定值 单位 消耗功率 Pd 60 mW 正向电流 IF 20 mA 最大脉冲电流*1 IFP 100 mA 反向电压 VR 5 V 静电释放等级(人体模式)*2 ≥2000V 操作温度 Topr -30 ~ +85 存放温度 Tstg -30 ~ +85 焊接温度*3 Tsol 260℃ 5s ℃ ℃ Electronical / Optical Charateristics at Ta=25℃ ` Parameter Test Condition Min Tvo Max Unit Luminous Intensity(IV) 4000 ----- 6000 mcd If=20mA Viewing Angle(2 θ1/2) ----- 45 ----- deg If=20mA The wavelength(λ) 620 ----- 630 Nm If=20mA Forward Voltage(VF) 1.8 ----- 2.4 V If=20mA ----- 5 µA Vr=5V Reverse Current(IR) Selection Guide : Lens color Chip Material Emittedcolor λp(nm ) Water Clear AIGAINP RED 625 GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com Selection Guide Typical Electrical/Optical Characteristics Curves(25℃ Ambient Temperature Unle 图1.光谱图 图2.顺向电流与正向电压曲线图 1.0 50 顺向电流 IF(mA) 相对辐射强度 0.8 0.6 0.4 0.2 40 30 20 10 0.0 610 400 700 0 图3.电流与相对发光强度关系曲线图 5 图4.环境温度与顺向电流关系曲线图 60 允许通过顺向电流 IF(mA) 相对发光强度 4 3 正向电压 (v) 3 2 1 0 2 1 波长(nm) 10 40 30 20 10 50 40 30 20 50 0 20 顺相电流 IF (mA) 40 60 80 环境温度( ℃) 焊接温度曲线 波峰焊温度曲线(如图 6) 预热温度 : 120℃~150℃, 120~180 sec. 操作温度 : 245℃±5℃,5 sec.260℃ (Max) Temperature Soldering heat Max. 260 ℃ 245 ±5℃ within 5 sec. 120~150℃ Preheat 120~180 sec. Time 波峰焊温度曲线 手动焊接条件 电烙铁温度不超过 350 度,焊接时间 3 秒钟 GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com 100 Labe P/N: The product model IV: Luminous intensity rank VF: Forward voltage rank TC: Color temperature Q`T: number QC: Production order The packing Desiccant Aluminum moisture-proof bag The cardboard Package specification: Package Method: packaged in anti-static bag White:Packaged in sorted light and color 1000pcs/bag note: General light 1000pcs/bag Package specification mentioned above is under normal circumstance. Specific demand can be negotiated GUANGDONGTONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com Supporter shaping: Shaping of the supporter must be conducted before welding. While shaping, the bending position of the supporter must at least be located at 3mm from the bottom of the encapsulating resin. Also, avoid multiple bending on the same position。Please choose the appropriate apparatus to fixate the supporter in order to avoid exerting extra pressure on resin. Using the jointing section of the pin and resin as fulcrum is strictly prohibited since the pressure mounted would directly damage the internal 。illuminating structure and thus cause irreversible defection of the product..Due to the same reason, the interval between the welding hole on the PCB board should be strictly matched with the pin interval of the product when assembling the product. GUANGDONGTONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com Reliability experiment items and conditions Serial number 1 Sample quantity Acceptance/rejection 20 0/1 20 0/1 -40℃- +100℃ 20min 10s 20min Testing time;100 cycle 20 0/1 High temperature;100℃ 20 0/1 20 0/1 -40℃-- +100℃ 60min 20min 60min Testing time;20 A cycle 20 0/1 260℃(Max), The biggest not more than 5 seconds 20 0/1 Testing project Test conditions Life test Test current;20MA temperature;25℃ Testing time;1000 hours High temperature high humidity (static test) 2 Cold and hot impact 3 temperature;=+65℃ humidity;90% RH Testing time;240 hours High temperature 4 storage Testing time;1000 hours Low temperature Low temperature;-40℃ storage Testing time;1000 hours 5 6 temperature cycle Reflow soldering 7 note Reliability experiment unqualified decision criteria IV; Attenuation of more than 30% VF; Change more than 20% ; 1. The same project experimental results of the test must be completed within two hours 2. Testing must be in every experiment is completed. Material return to normal conditions to carry out GUANGDONGTONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com ESD protective 1 Electrostatic generation 1;Friction: in the daily life. Any two different material object contact after the separation, can produce a staticelectric,Static electricity and the most common method,Is triboelectrification。The insulation material, the better,More letEasy triboelectrification。In addition,Any two different material object contact after separation,Can also produce electrostatic。 2. Induction: in view of the conductive material is concerned, because the surface of the electronic can free flow, such as placed it in electric fieldbecauseGay repellent,Opposites attract,Are negative ions will transfer, In its surface can produce charge。 3. Transmission: in view of the conductive material is concerned, because the surface of the electronic can free flow,If charged object contact, will be charge transfer. 4. The harm of static electricity LED: .1 For the moment's electric field or the heat generated by the current,Make LED localinjury,For the performance of the leakage current increase quickly,Can stillwork,But the brightness is reduced (white light will change color), life is damaged。 5 Because the electric field or current failure LED insulating layer,Make device can't work (destroyed),Performance for die lamp。 6;Electrostatic protection and elimination measures: a. For the whole process (production, testing, packaging, etc.) All LED directly contact member must do it well Prevent and Eliminate electrostatic measures, basically have: workshop laid anti-static floor and well grounded。 b. Table for esd workstation, the production of the good earth c. Operator wear anti-static clothing, with wrist strap, gloves or foot ring。 d. Application of ion fan, welding solder iron well grounding measures。 e. The package antistatic material GUANGDONGTONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 0769-86625999 400 676 8616 No.96, xintou Industrial Zone, Tangxia,Dongguan, Guangdong www.togialed.com
TJ-F10RYTLF62-A3 价格&库存
很抱歉,暂时无法提供与“TJ-F10RYTLF62-A3”相匹配的价格&库存,您可以联系我们找货
TJ-F10RYTLF62-A3
  • 10+0.34100
  • 100+0.31900
  • 500+0.29700
  • 2000+0.26400
  • 5000+0.25300
  • 10000+0.24640
库存:108
