DG125-5.08-06P-14-00Z(H)
    DEGSON(高松)
    插件,P=5.08mm
    间距5.08 1x6P单排绿色接线端子
DG125-5.08-06P-14-00Z(H) 数据手册
FOR-1755 Rev.1.7 6 未注公差/General tolerances(mm) 0 >3 >6 >10 >18 >30 >50 >80 >120 >180 >250 >315 >400 ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ >500 3 6 10 18 30 50 80 120 180 250 315 400 500 ±0.12 ±0.18 ±0.22 ±0.26 ±0.31 ±0.37 ±0.57 ±0.80 ±0.93 ±1.05 ±1.15 ±1.60 ±2.20 ±2.50 PCB LAYOUT 5.08 3.11 .5 0.1/10 ±2° 1 O1 4.5 A 2 B 9 0.57 3 Note: The A&Z(H) in the name means: A(H) and Z(H). 14.2 4.5 3.2 ±0.3 Transfer or duplication of this document as well as the utilization or communication of its contents are prohibited unless explicit authorization is granted. Violations will be liable for compensation. All rights reserved for patent, utility model or designs registrations. 除非给予明确授权,否则禁止转让、复制、利用、交流本文件的内容。侵犯者将负赔偿责任。本公司保留对涉及发明、实用新型和外观专利的所有权利。 5 4 3 2 2.54 5.08 4 1 4 Pin header Copper alloy Sn plated 3 Cage Copper alloy M2.5/Ni plated 2 Screw Steel M2.5/Zn plated 1 Housing PA66 UL94V-0 ITEM NAME OF PART MATERIAL NOTES UL 标准/UL Standard: 额定电压/电流/Rated Voltage(V)/Current(A) IEC 标准/IEC Standard: 过压类别/Overvoltage Category/污染等级/Pollution Degree 额定电压/电流/Rated Voltage(V)/Current(A) 额定脉冲电压(KV)/Rate Impulse Voltage(KV) 螺丝扭矩/Torque Tightening(N· m/Lb.in) 线径范围(硬线和软线)/Wire Range(rigid and flexible)(AWG/mm²) 间距/Pitch(mm)/线数范围/Poles 剥线长度/Stripping length(mm) 使用温度范围/Operating temperature(°C) 符合RoHS环保要求/Conform to RoHS 0.8 5.08X(N-1) 5.08XN MATERIAL: MAT NO./REV: 00 REV 1 ECN 2 DESCRIPTION 3 龚徐涛 2022.11.23 DRFT DATE APPD: 兰春华 CHKD: 陈招 DRFT: 龚徐涛 A4 4 2022.11.23 NAME 2022.11.23 2022.11.23 mm (inch) DRAWING NO. / 00 B 300/16 C / D / Ⅲ/3 250/18 4 Ⅲ/2 Ⅱ/2 320/18 630/18 4 4 M2.5, 0.4/3.54 26~12 / 0.5~2.5 5.08/N=02~24P 6~7 ­40~+105 Yes SURFACE/COLOR: MAT STATUS: 批量 DG125-5.08-XXP-1Y-00A&Z(H) TYPE CUSTOMER DRAWING 200029290 5 C DRAWING STATUS SCALE SHEET 已发布 3:1 1/1 6 D
DG125-5.08-06P-14-00Z(H) 价格&库存
很抱歉,暂时无法提供与“DG125-5.08-06P-14-00Z(H)”相匹配的价格&库存,您可以联系我们找货
