SSP7615-12MR
SSP7615-12MR
    SIPROIN(矽朋)
    SOT23-3
    线性稳压器/LDO 输入电压:7V 输出电压:1.2V~5V SOT23-3
SSP7615-12MR 数据手册
SSP7615 Input voltage 8V Current 400mA Voltage Regulator SSP7615 General Description The SSP7615 is a high accuracy, low noise, high speed CMOS Linear regulator with low power consumption and low dropout voltage, which provide large output currents even when the difference of the input-output voltage is small. The devices offer a new level of cost effective performance in cellular phones, laptop and notebook computers, and other portable devices. The current limiter's fold-back circuit also operates as a short circuit protection and an output current limiter at the output pin. The SSP7615 regulators are available in standard SOT23-3, SOT23-5 and DFN1×1-4 packages. Standard products are Pb-free and Halogen-free. Features ● Input voltage:1.5V~8V ● Output range:1.2V~5.0V ● Maximum output current: 400mA @ VOUT=3.3V ● PSRR: 60dB @1KHz ● Dropout voltage:200mV @ IOUT=100mA ● Quiescent current: 0.5 μ A Typ. ● Shut-down current:
SSP7615-12MR
物料型号:SSP7615
器件简介: SSP7615是一款高精度、低噪声、高速CMOS线性稳压器,具有低功耗和低降额电压特性。即使输入输出电压差较小,也能提供较大的输出电流。该器件在移动电话、笔记本电脑、便携式设备等领域提供了新的性价比水平。
引脚分配: - SOT23-3封装:1. GND(地),2. VOUT(输出电压),3. VIN(输入电压) - SOT23-5封装:1. VIN(输入),2. GND(地),3. EN(使能,高电平有效,不可浮空),4. NC(未连接),5. VOUT(输出) - DFN1x1-4封装:1. VOUT(输出),2. GND(地),3. EN(使能,高电平有效,不可浮空),4. VIN(输入)
参数特性: - 输入电压:1.5V至8V - 输出范围:1.2V至5.0V - 最大输出电流:在3.3V输出时为400mA - 电源抑制比(PSRR):1kHz时为60dB - 降额电压:在100mA输出电流时为200mV - 静态电流:典型值为0.5μA - 关断电流:小于1μA - 推荐电容:1μF - 内置短路保护和电流限制器
功能详解: SSP7615提供了高精度的电压输出,并且具有低功耗和低降额电压的特点。它还具备内置的短路保护和电流限制功能,以提高系统的可靠性。
应用信息: 适用于无线电控制系统、移动电话、无线电电话、数码相机、蓝牙设备以及其他便携式消费电子产品。
封装信息: SSP7615提供SOT23-3、SOT23-5和DFN1x1-4标准封装,所有标准产品均为无铅和无卤素。
