MTKEP06WD9BWLNG1N
MTKEP06WD9BWLNG1N
    SAMZO(三佐)
    SMD
    USB连接器 Type-C 6P 卧贴 端口数:1 额定电流:3A 额定电压:5V 工作温度:-25℃~+85℃
MTKEP06WD9BWLNG1N 数据手册
TR 巠 AO DESCRIPTION DATE 锋”“”发楠首 !APPROVED 20160406 NO芷: 1.MATERIAL SPECIFICATION: 1.HOUSING: HIGH 在MPERATURE RESISTANT PLASTIC,UL94 V-0. 2.CONTACTS:COPPER ALLOY 3.MID PLATE: STAINLESS S芷EL 4.FRONT SHELL: STAINLESS STEEL 0 书 名t �[ | | | 2.PLATING SPECIFICATION: 2-1.CONTACTS: Ni 50u" MIN. UNDER PLA兀D 0'1ER ALL. Au PLA兀D ON THE FUNCTIONAL AREA OF CONTACT. (GOLD PLATING lHICKNESS FOLLOW lHE P/N) PLATING SPECIFICATIONS OF lHE SOLDER AREA FOLLOW lHE P/N 2-2.FRONT SHELL: SEE TABLE1. 2-3.SHIELD PLA花&EMI PLA在: CLEAR ONLY 3.MECHANICAL PERFORMANCE, 3-1.INSERTION FORCE: 0.5~2.0kgf. 3-2.REMOVAL FORCE: 0.8kgf~2.0kgf. 3-3.DURABILITY: 5000 CYCLES. 4.ELEC1RICAL PERFORMANCE, 4-1. CURRENT RATING:3.0A VOLTAGE RATING: 5.0V 4-2. LLCR: VBUS & GND PINS AND OlHER PINS: 40m0/PIN MAX SHIELD: 50m0/MAX. LLCR MAX. CHANGE OF ALL PINS: 10m0. 4-3.INSULATION RESISTANCE: lOOMO MIN 4-4.DIELEC"TRIC WllHSTAND VOLTAGE.AC 100V FOR 1 MINU兀. 三勹 I 尸 9II 5. EN'1RONMENTAL PERFORMANCE: OPERATING 兀MPERATURE: -25'C~+85"C. 6.IR REFLOW: THE PEAK 在MPERATURE ON lHE BOARD SHALL BE MAINTAINED FOR 10 SECONDS AT 260飞 RE叨证NOEO P.taLAlUUT �CEUN戏UHU丿士0.05mm TOLERANCE x.x士030 .xx士0.20 .xxx士010 UNITS PIN ASSIGNMENTS A5 A9 A12 PIN CCI \llUS GND �GNAL NAME B12 B9 B5 PIN GND \llUS CC2 SIGNAL NIME I L I L IL IL =6.8 =6.5 | | ^ 2 X.士10' .x· 士 8. xx·士 5• mm NAME(INTENDED USE) CUSTOMER DRAWING PART NO. MTI
MTKEP06WD9BWLNG1N 价格&库存
很抱歉,暂时无法提供与“MTKEP06WD9BWLNG1N”相匹配的价格&库存,您可以联系我们找货
MTKEP06WD9BWLNG1N
  • 1+3.91020
  • 10+3.15560
  • 200+2.39120
  • 400+2.16580
  • 1000+2.04820
库存:1000
MTKEP06WD9BWLNG1N
  • 1+2.96514
  • 10+2.62656
  • 30+2.46240
  • 100+2.29824
  • 500+2.19564
  • 1000+2.14434
库存:788
