EVQP2R02M
EVQP2R02M
    SAMZO(三佐)
    SMD,4.7x3.5mm
    轻触开关 4.7*3.5*2.1mm 立贴
EVQP2R02M 数据手册
Light Touch Switches/EVQP2/P9/3P2 ■ Dimensions in mm (not to scale) No. 2 (General dimension tolerance±0.2) EVQP2 EVQP9 1.6 H 2.1 +0.2 –0.1 Short push travel With J-bent terminals (With Ground terminal) 2.5 +0.2 –0.1 H 0.6     +0 5.5 –0.3 2.6 4.7±0.1 f2   Circuit diagram   1.65±0.1 3.5±0.1 1.7±0.1 0.6±0.1 2.7±0.1 0.7±0.1 6.6±0.1 3.7±0.1 PWB land pattern for reference Part Numbers Ground Terminal Operating Force H=Height Push Plate Color Operating Life EVQP2P02M With 1.0 N 2.1 mm White 1000000 cycles EVQP2P02W With 1.0 N 2.5 mm White 1000000 cycles EVQP2R02M With 1.6 N 2.1 mm White 1000000 cycles EVQP2R02W With 1.6 N 2.5 mm White 1000000 cycles EVQP2T02M With 2.4 N 2.1 mm White 500000 cycles EVQP2T02W With 2.4 N 2.5 mm White 500000 cycles EVQP2V02M With 3.5 N 2.1 mm White 200000 cycles EVQP2V02W With 3.5 N 2.5 mm White 200000 cycles EVQP9H02M With 5.0 N 2.1 mm White 200000 cycles EVQP9H02W With 5.0 N 2.5 mm White 200000 cycles EVQP2002M Without 1.0 N 2.1 mm White 1000000 cycles EVQP2002W Without 1.0 N 2.5 mm White 1000000 cycles EVQP2202M Without 1.6 N 2.1 mm White 1000000 cycles EVQP2202W Without 1.6 N 2.5 mm White 1000000 cycles EVQP2402M Without 2.4 N 2.1 mm White 500000 cycles EVQP2402W Without 2.4 N 2.5 mm White 500000 cycles EVQP2602M Without 3.5 N 2.1 mm White 200000 cycles EVQP2602W Without 3.5 N 2.5 mm White 200000 cycles EVQP9W02W Without 4.0 N 2.5 mm White 200000 cycles EVQP9P02M Without 5.0 N 2.1 mm White 200000 cycles EVQP9P02W Without 5.0 N 2.5 mm White 200000 cycles 01 Apr. 2015
EVQP2R02M 价格&库存
很抱歉,暂时无法提供与“EVQP2R02M”相匹配的价格&库存,您可以联系我们找货
EVQP2R02M
    • 1+4.77360
    • 10+3.83400
    • 30+3.36960
    • 100+2.90520
    库存:251
    EVQP2R02M
    • 1+3.84250
    • 30+3.71000
    • 100+3.44500
    • 500+3.18000
    • 1000+3.04750
    库存:3989
