B35-7620-R8411
B35-7620-R8411
    UVK(优为科)
    SMD,P=2.54mm
    排针 双排,20PIN,立贴,脚距2.54mm,座高10.16mm,针高10.24mm,总高21.04mm,镀金1u,带定位柱,-55~105℃,
B35-7620-R8411 数据手册
REVISION DATA DESCRIPTION NEW DRAWING REV A0 G DATE 2023/07/07 Technical Data Material: Contact Material: Brass Contact plating:Au≥1µ" Over 50µ" Ni Insulator Material:Black Polyester UL94V-0 Standard:PA6T/LCP+30%G.F F Electrical: Current rating:3.0Amps/contact max. Contact resistance: ≤20mΩ/contact Insulation resistance: ≥1000MΩ at V=100V Withstanding Voltage:550V AC/minute E Mechanical: Mechanical life cycle:min.200 Operaing temperatures: Gold Plated:-55°C to+105°C Tin plated:-40°C to+105°C Soldering temperature: +260°C max(LCP) D C Ordering Information B 3 5 - X X XX- XX X X B High Option 1 2 3 4 5 6 7 A H=0.65mm H=0.85mm H=1.00mm H=1.50mm H=1.70mm H=2.00mm H=2.54mm No. of row/tiers 4 Double row Single tier 5 Double row Double tiers No. of Positions XX Positions 东莞市优为科精密电子科技有限公司 Terminal plating 0 Tin plating over all 1 Gold plating over all Pin Length U-Wilcome Precision Electronic Technology Co., Ltd UNLESS OTHERWISE SPECIFIED TOLERANCES ARE X.X ±0.20 ±0.10 X.XX ±0.05 X.XXX ANG. ±°5 Insulator Material Option 1 PBT 4 PA6T 5 PA9T 6 LCP UNIT SIZE mm 1 2 3 4 5 6 A4 7 APPROVED BY DATE CHECKED BY DATE DRAWN BY TITLE 2.54mm Pin Header Dual Row S.M.T Type H2.54 L=23.0mm PAGE DATE DOCUMENT NO LIUWEI PART NO B35-7618-R8411 8 1 2023/07/07 9 REV SHEET A0 1/1 SCALE 1:1 0
B35-7620-R8411 价格&库存
很抱歉,暂时无法提供与“B35-7620-R8411”相匹配的价格&库存,您可以联系我们找货
