NJM2113M
NJM2113M
    NISSHINBO(日清纺)
    SOIC-8
    放大器 IC 1-通道(单声道) AB 类 8-DMP
NJM2113M 数据手册
SIP8 is the NRND product as of February,2023 NJM2113 LOW VOLTAGE AUDIO POWER AMPLIFIER ■ GENERAL DESCRIPTION The NJM2113 is an audio power amplifier designed for telephone application, such as in speakerphones. Coupling capacitors to the speaker are not required,as it has differential speaker outputs. The closed loop gain is set with two external resistors. A CD pin permit powering down with muting the input signal. ■ PACKAGE OUTLINE NJM2113D ( DIP8 ) ■ FEATURES ● Wide Operating Voltage ( 2~16V ) ● Low Operating Current ( 2.7mA Typ. ) ● CD Input to Power Down the IC with Mute NJM2113E ● Low Power-Down Operating Current ( 72μA Typ. ) + ( SOP8 ) ● Output Power Exceeds 250mW ( V =6V,RL=32Ω ) ● Gain Adjustable (GVD=0~43dB,Voice Band ) ● Package Outline DMP8, DIP8, SOP8 JEDEC 150mil SIP8, SSOP8, VSP8 ● Bipolar Technology ■ RECOMMENDED OPERATING CONDITIONS ● Load Impedance RL 8~200Ω ● Differential Gain GVD 0~43dB ( 5kHz bandwidth ) ● Input Voltage at CD VCD 0~V+ Vdc NJM2113R ( VSP8 ) NJM2113M ( DMP8 ) NJM2113V ( SSOP8 ) t c du ro P D N NRNJM2113L ( SIP8 ) ■ PIN CONFIGURATION PIN FUNCTION 1. CD 2. VREF 3. +VIN 4. –VIN 5. VOUT1 + 6. V 7. GND 8. VOUT2 NJM2113D NJM2113M NJM2113E NJM2113V NJM2113R NJM2113L ■ BLOCK DIAGRAM Ver.2014-03-17 -1- NJM2113 SIP8 is the NRND product as of February,2023 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Output Peak Current SYMBOL + V IOP Input Voltage Range VIN Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS +18 ± 250 + ( 1~4pin )-0.3 to V +0.3 + ( 5,8pin )-0.3 to V +0.3 ( when Power-Down ) ( note1 ) ( DIP8 ) 500 ( SIP8 ) 800 ( note1 ) ( DMP8 ) 500 ( note2 ) ( SSOP8 ) 360 ( note2 ) ( VSP8 ) 320 ( note1 ) ( SOP8 ) 300 ( note1 ) -20~+75 -40~+125 UNIT V mA V mW ˚C ˚C ( note1 ) Device itself. ( note2 ) Mounted on PC Board. ■ ELECTRICAL CHARACTERISTICS ( V+=6V,Ta=25˚C,unless otherwise specified ) PARAMETER Operating Current ( no signal ) Open Loop Gain Closed Loop Gain Output Power ( note3 ) Total Harmonic Distortion ( f=1kHz ) Power Supply Rejection Ratio + + ( V =6.0V,ΔV =3.0V ) Mute Attenuation Output Voltage ( Rf=75kΩ,DC ) Output High Level Output Low Level Output DC Offset Input Bias Current Equivalent Resistance CD Input Voltage H CD Input Voltage L CD Input Resistance SYMBOL ICC1 ICC2 ICCD AV1 AV2 PO1 PO2 PO3 THD1 THD2 THD3 PSRR1 PSRR2 PSRR3 MAT VO1 VO2 VO3 VOH VOL ΔVO IB R+IN RREF VCDH VCDL RCD TEST CONDITION + V =3.0V,RL=∞,1pin=0.8V + V =16.0V,RL=∞,1pin=0.8V + V =3.0V,RL=∞,1pin=2.0V Amplifier#A,f
NJM2113M 价格&库存
很抱歉,暂时无法提供与“NJM2113M”相匹配的价格&库存,您可以联系我们找货
NJM2113M
  • 1+1.46880
库存:10
