C35-2420-41125
C35-2420-41125
    UVK(优为科)
    SMD,P=2.54mm
    排母 2x10Pin,立贴,P=2.54mm,塑高3.5mm,总高3.8mm,镀金1u,带定位柱,-40~105℃
C35-2420-41125 数据手册
REVISION DATA DESCRIPTION NEW DRAWING REV A0 G DATE 2014/10/16 Technical Data 2 4 1 3 Material: Contact Material: Brass Contact plating:Au Over 50µ" Ni Insulator Material:Black Polyester UL94V-0 Standard:PA6T+30%G.F F Electrical: Current rating:3.0Amps/contact max. Contact resistance: ≤20mΩ/contact Insulation resistance: ≥1000MΩ at V=100V Withstanding Voltage:550V AC/minute E Mechanical: Mechanical life cycle:min.200 Operaing temperatures: Gold Plated:-55°C to+105°C Tin plated:-40°C to+105°C Soldering temperature: +260°C max(PA6T) D C Ordering Information C 3 5 - X X XX- X X 1 X B High Option No. of row/tiers 1 H=2.0-2.1mm 1 Single row 2 H=3.4-3.5mm Single tier 3 H=4.0-4.3mm 4 Double row 4 H=4.6-5.0mm Single tier 5 H=5.7mm 6 H=6.35-6.8mm 7 H=7.0-7.1mm 8 H=8.5mm No. of Positions XX Positions Insulator Material Option 1 PBT 4 PA6T 5 PA9T 6 LCP Packing 0 Pe Box 1 Tube 2 Reel Terminal plating 0 Tin plating over all 1 Gold plating over all 东莞市优为科精密电子科技有限公司 U-Wilcome Precision Electronic Technology Co., Ltd A UNLESS OTHERWISE SPECIFIED TOLERANCES ARE X.X ±0.30 ±0.20 X.XX ±0.10 X.XXX ANG. ±°5 ≥ UNIT SIZE mm 1 2 3 4 5 6 A4 7 APPROVED BY DATE CHECKED BY DATE DRAWN BY TITLE 2.54mm Female Header Dual Row SMT Type H3.5 OE7.2 PAGE DATE DOCUMENT NO LIUWEI PART NO C35-24**-41125 8 1 2014/10/16 9 REV SHEET A0 1/1 SCALE 1:1 0
C35-2420-41125 价格&库存
很抱歉,暂时无法提供与“C35-2420-41125”相匹配的价格&库存,您可以联系我们找货
