SK32 THRU SK310
Product specification
SK32 THRU SK310
MECHANICAL DATA
FEATURES
Case: Molded plastic
Ideal for surface mount applications
Epoxy: UL 94V-0 rate flame retardant
Easy pick and place
Metallurgically bonded construction
Built-in strain relief
Polarity: Color band denotes cathode end
Low forward voltage drop
Mounting position: Any
Weight: 0.063 grams
Reference News
PACKAGE OUTLINE
PIN CONFIGURATION
SMA(DO-214AC)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified .
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Maximum Recurrent Peak Reverse Voltage
40
50
60
80
90
100
V
Maximum RMS Voltage
14
21
28
35
42
56
63
70
V
Maximum DC Blocking Voltage
40
50
60
80
90
100
V
Maximum Average Forward Rectified Current
At TL=100℃
A
3.0
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
80
Maximum Instantaneous Forward Voltage at 3.0A
0.55
Maximum DC Reverse Current
Ta=25℃
at Rated DC Blocking Voltage
Ta=100℃
A
0.70
0.1
5
300
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JL (Note 2)
0.85
V
0.02
mA
2
mA
pF
10
C/W
Operating Temperature Range TJ
-65
+150
Storage Temperature Range TSTG
-65
+150
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
SK32 THRU SK310
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
60
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
36
K
31
~S
K
32
~S
3.0
38
SK
0.5
SK
1.0
10
35
1.5
SK
2.0
~S
K3
4
50
2.5
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
100
.01
80
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
60
8.3ms Single Half
Tj=25 C
Sine Wave
40
JEDEC method
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
700
600
500
400
300
200
10
1.0
Tj=75 C
.1
Tj=25 C
100
.05
.1
.5
1
REVERSE VOLTAGE,(V)
Copyright© Msksemi Incorporated
5
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
www.msksemi.com
SK32 THRU SK310
PACKAGE ECHANICAL DATA
A
Ref.
B
C
Dimensions
H
F
G
D
E
L
J
K
Millimeters
Min.
Max.
A
4.25
B
Min.
Max.
4.65
0.167
0.183
2.50
2.90
0.098
0.114
C
1.35
1.65
0.053
0.065
D
0.76
1.52
0.030
0.060
E
4.93
5.28
0.194
0.208
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
1.98
2.41
0.078
0.095
J
6.50
L
0.256
2.30
K
DO-214AC (SMA)
Inches
1.70
0.090
0.067
REEL SPECIFICATION
P/N
PKG
QTY
SK32 THRU SK310
SMA
2000
www.msksemi.com
SK32 THRU SK310
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“SK34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18520
- 200+0.14520
- 600+0.12270
- 2000+0.09680
- 10000+0.08620
- 20000+0.08050
- 国内价格
- 20+0.13000
- 100+0.10500
- 500+0.09500
- 2000+0.08000
- 6000+0.07500
- 国内价格
- 20+0.18940
- 200+0.15062
- 600+0.12907
- 2000+0.10189
- 10000+0.09070
- 20000+0.08465
- 国内价格
- 1+0.19800
- 50+0.09856
- 2000+0.07469
