WTFM-207H02LDA
WTFM-207H02LDA
    WORLDPO(沃德披欧)
    SMD,P=1.27mm
    连接器 SMD,P=1.27mm 2x7Pin
WTFM-207H02LDA 数据手册
1.27 mm PITCH • WTOLC/WSOLC SERIES WTOLC Mates: WSOLC WTOLC - 4X WTOLC 4X 05 H02 NO.PINS PER ROW 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 WSOLC Mates: WTOLC (Standard Sizes) SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Current Rating: 2.4 A per pin (6 adjacent pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth (WSOLC): 1.68 mm to 3.61 mm with 0.38 mm wipe Max Cycles (WSOLC): 100+ PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: 0.10 mm max (05-35) 0.15 mm max (40-50) stencil solution may be available; L LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = Gold flash on contact, Gold flash on tail Q Q OTHER OPTION F A = Alignment Pin (N/A with LC) LC = Locking Clip (N/A with A) (Manual placement required) L = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail No. of positions x (1.27) .050 + (2.54) .100 LEAD STYLE (8.13) .320 K = (9.00 mm) .354" DIA Polyimide film Pick & Place Pad MATED HEIGHT A H02 (5.59) .220 (6.35) .250 H12 (7.24) .285 (8.00) .315 H22 (9.25) .364 (10.00) .394 H32 (11.23) .442 (12.00) .472 TR = Tape & Reel (5.08) .200 A Style H02 Styles H12,H22,H32 WSOLC - 4X WSOLC 4X ALSO AVAILABLE MOQ Required A OPTION 05 H02 H02 NO.PINS PER ROW 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 Other sizes Other platings Q Q F (Standard Sizes) L = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail      7
WTFM-207H02LDA 价格&库存
很抱歉,暂时无法提供与“WTFM-207H02LDA”相匹配的价格&库存,您可以联系我们找货
