HoLRS3920-3W-1mR-1%
HoLRS3920-3W-1mR-1%
    MILLIOHM(毫欧)
    电流采样电阻 3920 1mΩ ±1% +25~+50ppm/℃ 3W
HoLRS3920-3W-1mR-1% 数据手册
系列号 HoLRS Serial number HoLRS 3 9 2 0 裸露合金系列规格书修订日期 2022-06-02 date HoLRS3920 bare alloy series specification Revision 版本号 Ho-B1 Version number 规格书 Specification 制造商:深圳市毫欧电子有限公司 Manufacturer: Shenzhen Hao Ou Electronics Co., LTD 适用:本规格书适用于深圳市毫欧电子有限公司裸露合金电阻 HoLRS3920 系列产品选型。 Application: This specification is suitable for the selection of bare alloy resistance HoLRS3920 series products of Shenzhen Hao Ou Electronics Co., LTD.  产品特点 Features: 电子束焊工艺,焊接性能良好,易于焊接 Electron beam welding technology, good welding performance, easy to weld 高可靠性,高过载能力,产品精度高 High reliability, high overload capacity, high product accuracy 使用温度范围较宽无感型设计,电感小于 1 0纳亨 Wide operating temperature range non-inductive design, inductance less than 10 nH 电阻温度系数T CR(2 5~5 0ppm/℃) Temperature coefficient of resistance TCR (25 ~ 50 PPM /℃) 产品符合 ROHS 要求 Products comply with ROHS requirements 产品符合AEC-Q200要求 Products comply with AEC-Q200 requirements  产品名称 Product Name 裸露合金电阻  Bare alloy resistance 产品型号 Product number Ho LRS 3920 5W 制造商 额定功率 封装 产品系列 manufacturer Product series encapsulation Rated power Bare alloy Milliohm electron resistance Ho 3920 5W 3mR 1% 阻值 Resistance value 精度 precision 0.2~5mR D=±0.5% F=±1% J=±5% AEC-Q200 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 Address: 8th Floor, Building A, Nantong Bang High-tech Industrial Park, Dabutou Road, Guanlan, Longhua New District, Shenzhen 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn Shenzhen Milliohm Electronics Co.,Ltd | Tel:0755-28153546 | Fax:0755-22630181 | Web:www.moolee.com.cn 系列号 HoLRS Serial number HoLRS 3 9 2 0 裸露合金系列规格书 修订日期 2022-06-02 HoLRS3920 bare alloy series specification Revision date 版本号 Ho-B1 Version number  产品尺寸 ProductSize 阻值 封装 Resistance encapsulation value 0.2mR 3920  (Unit:mm) W A B H D2 T 10±0.5 5.2±0.5 5±0.5 2.1±0.2 1.66±0.1 2.0±0.5 0.25mR 10±0.5 5.2±0.5 5±0.5 1.0±0.2 0.4±0.1 2.0±0.5 0.3mR 10±0.5 5.2±0.5 5±0.5 1.9±0.2 1.38±0.1 2.0±0.5 0.5mR 10±0.5 5.2±0.5 5±0.5 1.2±0.2 0.74±0.1 2.0±0.5 0.7mR 10±0.5 5.2±0.5 5±0.5 1.0±0.2 0.56±0.1 2.0±0.5 1mR 10±0.5 5.2±0.5 5±0.5 1.8±0.2 1.32±0.1 1.6±0.2 1.1±0.1 2mR 10±0.5 5.2±0.5 5±0.5 1.1±0.2 0.58±0.1 2.0±0.5 2.5mR 10±0.5 5.2±0.5 5±0.5 1.1±0.2 0.54±0.1 2.0±0.5 3mR 10±0.5 5.2±0.5 5±0.5 0.8±0.2 0.44±0.1 2.0±0.5 4mR 10±0.5 5.2±0.5 5±0.5 0.9±0.2 0.38±0.1 2.0±0.5 5mR 10±0.5 5.2±0.5 5±0.5 0.9±0.2 0.30±0.1 2.0±0.5 2.0±0.5 电气参数 Electrical parameter 电阻值 Resistance values (mR) 0.2 to 5 额定功率 Rated power (W) 5 最大额定电流 Max.Rated Current (A) 158 准确度 Accuracy (%) 0.5 to 5 电阻温度系数 TCR ( ppm / ℃ ) 25~50 工作温度范围 Operating Temperature Range -50℃~+170℃ 电感值 Inductance (nH) <10 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 Address: 8th Floor, Building A, Nantong Bang High-tech Industrial Park, Dabutou Road, Guanlan, Longhua New District, Shenzhen 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn Shenzhen Milliohm Electronics Co.,Ltd | Tel:0755-28153546 | Fax:0755-22630181 | Web:www.moolee.com.cn 系列号 HoLRS Serial number 修订日期 HoLRS 3 9 2 0 裸露合金系列规格书 2022-06-02 HoLRS3920 bare alloy series specification Revision date 版本号 Ho-B1 Version number  功率降额曲线 Power curve 操作温度范围 - 55 ~+170 ℃电阻温度达到 70℃时降功率示意图 Operating temperature range -55to+170℃ Schematic diagram of power reduction when the resista nce temperature reaches 70℃ 100 70 负 80 Load 载 power 功 60 ratio 率 比 40 (%) (%) 20 0 -50 0 25 50 75 100 125 150 170 环境温度( ℃) Ambient temperature (℃)  性能测试 Performance Testing Parameters Test conditions Speci ied values Temperature Cycling 2000 cycles (-55℃to +150℃) ±0.5 % Low Temperature Storage and Operation -65℃ for 24 h ±0.1 % Resistance to Soldering Heat 260℃for 10 sec/8h steam aging n.a. Moisture Resistance MIL-STD-202 method 106 ±0.1 % Mechanical Shock 100 g, 6 ms half sine ±0.2 % Vibration, High Frequency 20 g, 10-2000 Hz ±0.2 % Operational Life 2000 h, TK max at nominal load ±1.0 %, TK = 130℃ High Temperature Exposure 2000 h/170℃ ±1.0 % (in covered condition)* Bias Humidity +85℃, 85 r.F., 1000 h ±0.5 %  建议焊盘尺寸 Recommended Solder Pad Dimension Solder pad type 3920 L A B 11 6.2 5.6 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 Address: 8th Floor, Building A, Nantong Bang High-tech Industrial Park, Dabutou Road, Guanlan, Longhua New District, Shenzhen 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn Shenzhen Milliohm Electronics Co.,Ltd | Tel:0755-28153546 | Fax:0755-22630181 | Web:www.moolee.com.cn 系列号 HoLRS Serial number HoLRS 3 9 2 0 裸露合金系列规格书修订日期 2022-06-02 Revision date HoLRS3920 bare alloy series specification 版本号 Ho-B1 Version number  包装方式Packing 编带盘装:2500pcs/盘 Braid disk loading: 2500pcs/ disk  载带尺寸 Ribbon size (Unit:mm) 1.5 ±0.1 -0 A0 B0 W F E T K0 5.55±0.1 10.35±0.1 24±0.3 11.5±0.1 1.75±0.1 0.3±0.05 2.4±0.1  卷轴规格 Reel Specification W 24+0.5 M 350±1 P P0 8±0.1 4±0.1 P2 2.0± 0.1 (Unit:mm) A 2.3±1 B 13.2±1 D 100±2 Packaging Quantity 2500PCS 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 Address: 8th Floor, Building A, Nantong Bang High-tech Industrial Park, Dabutou Road, Guanlan, Longhua New District, Shenzhen 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn Shenzhen Milliohm Electronics Co.,Ltd | Tel:0755-28153546 | Fax:0755-22630181 | Web:www.moolee.com.cn 修改履历表Revise your resume: 序号 Serial number 1 2 修改内容 Modify content 增加电阻0.25mR Increase resistance by 0.25mR 增加焊盘尺寸推荐及 包装尺寸图 Add pad size recommendations and package size drawings 修改原因 修改日期 Revision date Reason for modification 2021-12-14 2022-06-02 新增电阻0.25mR New resistance 0.25mR 内部增加 Internal increase 版本 edition 更改人 Alteration party A0升级B0 黄永康 A0 Upgrade B0 YongKangHuang B0升级B1 B0 Upgrading B1 黄忠亮 ZhongLiangH uang 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
HoLRS3920-3W-1mR-1% 价格&库存
很抱歉,暂时无法提供与“HoLRS3920-3W-1mR-1%”相匹配的价格&库存,您可以联系我们找货
