SMQS-04R-TP
SMQS-04R-TP
    SM(斯茂)
    插件,P=2.54mm
    间距2.54mm 平拨,凸起式4位拨码开关
SMQS-04R-TP 数据手册
- 规 格 书 - 产品型号: SMQS系列 产品名称: 拨码开关 SM SWITCH CO.,LTD Add :江苏省无锡市新吴区弘毅路8号金帛座706室 韩国京畿道富川市三鹊路22号富川科技园103-506栋 TEL :+86-510-8591-9217 E-mail:SMSWITCH@SIMAOKJ.COM Web :WWW.SIMAOKJ.CN 拨码开关/DIP SWITCH ➢ Type selection table description. SMQS 系列名称 Series name 档位数 Position 包装方式 Form of packaging TP:管装/Tube packing TR:编带/Carrier tape packaging 01:1档/1 Bits 02:2档/2 Bits 拨码开关颜色及针脚类型 DIP Switch Color And Pin Type 03:3档/3 Bits 04:4档/4 Bits 05:5档/5 Bits 06:6档/6 Bits R(I):红色(直角)/Red Straight Pin B(I):蓝色(直角) Blue Straight Pin RY:红色Y型脚/Red Y Pin BY:蓝色Y型角/Blue Y Pin 07:7档/7 Bits 08:8档/8 Bits 09:9档/9 Bits 10:10档/10 Bits 12:12档/12 Bits ⚫ Please check the type of switch according to the type specification. 拨码开关/DIP SWITCH ➢ Outline Dimensions ◆ SMQS-01 - ◆ SMQS-02 - ◆ SMQS-03 - ◆ SMQS-04 - ◆ SMQS-05 - ◆ SMQS-06 - 拨码开关/DIP SWITCH ◆ SMQS-07 - ◆ SMQS-08 - ◆ SMQS-09 - ◆ SMQS-10 - ◆ SMQS-12 - ➢ Packing 拨码开关/DIP SWITCH ➢ Material Description 拨柄/ACTUATOR PBT UL 94V-0 外壳/COVER PBT UL 94V-0 基座/BASE PBT UL 94V-0 接触端子/CONTACT&TERMINAL 填充胶/TAPE PHOSPHOR BRONZE GOLD PLATING EPOXY RESIN ➢ Characteristics 工作温度/Operation Temperature -40℃ to +85℃ 储存温度/Storage Temperature -40℃ to +85℃ 电气寿命/ Electrical Life 3000 cycles 机械寿命/ Mechanical Life 5000 cycles 动作力 / Operation Force 耐压 / Dielectric Strength 绝缘电阻/lnsulation Resistance 1000gf Max 500VDC/1 minute 100MΩ Min at 500VDC 接触电阻/Contact Resistance Initia : 50m ΩMax After life:100m ΩMax 额定电流/Rated Current Switching : 25mA at 24VDC Non-Switching:100mA at 50VDC 拨码开关/DIP SWITCH ➢ Welding Specification 波垾 /Wave Welding 240±5 ℃,3~5sec (Peak temperature) (Please refer to the profile below) 手工焊锡/ Manual Soldering 320°C 2 sec *Above refers to the temperature of copper foil on PCB. PCB temperature and switch surface temperature have big difference, namely PCB material. Small size, thickness, etc. are important, so please be careful not to exceed 240℃ on the switch surface. *上述提到的情况,是指 PCB 上铜箔的温度。 有一些情况会有 PCB 的温度和开关表面的温度会有很大的不同,这和 PCB 的材质,大小,厚度等有很大的关系. 因此要小心不要让开关表面的温度超过 240℃。 *Points to Note: Auxiliary flux on PCB board, do not stick to switch body. *处理时注意事项: 在 P.C.B 板面上助焊剂,不要沾到开关本身。
SMQS-04R-TP 价格&库存
很抱歉,暂时无法提供与“SMQS-04R-TP”相匹配的价格&库存,您可以联系我们找货
SMQS-04R-TP
    • 5+1.46190
    • 50+1.10340
    • 160+0.97090
    • 480+0.80540
    • 2480+0.73170
    • 5000+0.68750
    库存:24920
    SMQS-04R-TP
    • 5+1.30487
    • 50+0.98486
    • 160+0.86656
    • 480+0.71892
    • 2480+0.65316
    • 5000+0.61366
    库存:22731
