SM712.TCT
Asymmetrical TVS Diode for Extended Common-Mode RS-485
DESCRIPTION
FEATURES
The transient voltage suppressor (TVS)
diode is designed for asymmetrical (12V to -7V)
protection in multi-point data transmission
standard RS-485 applications.
be used to protect devices from transient
voltages resulting from electrostatic discharge
(ESD), electrical fast transients (FET), and
lightning.
The features 400 Watts (tp=8/20μs) of
power handling capability to accommodate the
higher transient voltage levels which may be
expected
in
extended
common
mode
applications. This provides higher equipment
reliability and eliminates the “ guess work”
required when using zener diodes that are not
rated to handle such transient conditions.
The integrated design aids in reducing voltage
over-shoot associated with trace inductance. The
low clamping voltage of the minimizes
the stress on the protected transceiver. The
SOT-23 package allows flexibility in the design of
“crowed” circuit boards.
400 watts peak pulse power (tp=8/20μs)
Transient protection for asymmetrical data lines to
IEC 61000-4-2 (ESD) ±15kV(air), ±8kV(contact)
IEC 61000-4-4 (FET) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 12A (8/20μs)
Protects two +12V to -7V lines
Low capacitance
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
RoHS compliant
MACHANICAL DATA
SOT-23 package
Terminal: Matte tin plated.
Packaging: Tape and Reel
High temperature soldering guaranted:260℃/10s
Reel size: 7 inch
ORDERING INFORMATION
APPLICATIONS
Package: SOT-23
Marking: 712 or C72
Material: Halogen free
Packing: Tape & Reel
Quantity per reel: 3,000pcs
Protection of RS-485 transceivers with extended
common-mode range
Security systems
Automatic Teller Machines
HFC systems
Networks
PIN CONFIGURATION & SCHEMATIC
CIRCUIT DIAGRAM
1/4
SM712.TCT
ABSOLUTE MAXIMUM RATING
Symbol
Parameter
Value
Units
PPP
Peak Pulse Power (8/20μs)
400
W
IPP
Peak Pulse Current (8/20μs)
17
A
VESD
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
±15
±8
kV
TOPT
Operating Temperature
-55/+150
°C
TSTG
Storage Temperature
-55/+150
°C
ELECTRICAL CHARACTERISTICS (Tamb=25°C)
Symbol
Parameter
Pin 1 to 3 and
Pin 2 to 3
Test Condition
Min
VRWM
VBR
IR
Reverse Working
Voltage
Reverse
Breakdown Voltage
Reverse Leakage
Current
Typ
Pin 3 to 1 or
Pin 2 to 1
IT = 1mA
Max
Pin 3 to 1 and
Pin 3 to 2
Min
Typ
12
13.3
Units
Max
7
7.5
V
V
VR = VRWM
1
μA
VC1
Clamping Voltage 1
IPP = 5A,
tp = 8/20μs
V
VC2
Clamping Voltage 2
IPP = 17A,
tp = 8/20μs
26
12
V
Junction
Capacitance 1
Junction
Capacitance 2
VR = 0V,
f = 1MHz
VR = VRWM,
f = 1MHz
75
75
pF
CJ1
CJ2
45
2/4
45
pF
SM712.TCT
ELECTRICAL CHARACTERISTICS CURVE
3/4
SM712.TCT
SOT-23 PACKAGE OUTLINE DIMENSIONS
4/4
很抱歉,暂时无法提供与“SM712.TCT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25816
- 300+0.20795
- 1200+0.18001
- 3000+0.14709
- 国内价格
- 20+0.28164
- 200+0.22686
- 600+0.19638
- 3000+0.16047
- 9000+0.14467
- 21000+0.13616
- 国内价格
- 1+0.23210
- 200+0.15070
- 1500+0.13090
- 3000+0.11550
