ADAM-6151PN-AE
ADAM-6151PN-AE
    B+BSMARTWORX
    16-CH ISOLATED DI PROFINET MODUL
ADAM-6151PN-AE 数据手册
ADAM-6150 ADAM-6151/6156 ADAM-6160 2002/95/EC ƒƒ Input Impedance ƒƒ Transition Time 2002/95/EC Relay Output ADAM-6150: 8 ADAM-6151: 16 Logic level 0: open Logic level 1: close to DGND Logic level 0: 0 ~ 3 VDC or 0 ~ -3 VDC Logic level 1: 10 ~ 30 VDC or -10 ~ -30 VDC (Dry/Wet Contact decided by switch) 5.2 kΩ (Wet Contact) From logic level 0 to 1: 0.2 ms From logic level 1 to 0: 0.2 ms Digital Output ƒƒ Channels ADAM-6150: 7 ADAM-6156: 16 ƒƒ Output Voltage Range 8 ~ 35 VDC ƒƒ Normal Output Current 100 mA (per channel) Ordering Information ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ COMPLIANT Specifications Digital Input ƒƒ Wet Contact RoHS ADAM-6160 COMPLIANT Specifications ƒƒ Dry Contact 6-ch Relay Real-time Ethernet Module RoHS ADAM-6150/6151/6156 ƒƒ Channels 15-ch Isolated Digital I/O Real-time Ethernet Module 16-ch Isolated Digital Input/ Digital Output Real-time Ethernet Module ADAM-6150EI ADAM-6151EI ADAM-6156EI ADAM-6150PN ADAM-6151PN ADAM-6156PN 15-ch Isolated DI/O EtherNet/IP Module 16-ch Isolated DI EtherNet/IP Module 16-ch Isolated DO EtherNet/IP Module 15-ch Isolated DI/O PROFINET Module 16-ch Isolated DI PROFINET Module 16-ch Isolated DO PROFINET Module ƒƒ Channels ƒƒ Contact Rating ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ Max. Switching Voltage Breakdown Voltage Max. Breakdown Capacity Frequency of Operation Set/Reset Time Mechanical Endurance Isolation between Contact Insulation Resistance 5 Form C and 1 Form A 250 VAC @ 5A 30 VDC @ 5A 400 VAC 300 VDC 500 VAC (50/60Hz) 1250 VA 360 operations/hour with load 72,000 operations/hour without load 8 ms/8 ms > 15 x 106 operations 1000 Vrms > 10 GΩ @ 500 VDC Ordering Information ƒƒ ADAM-6160EI ƒƒ ADAM-6160PN 6-ch Relay EtherNet/IP Module 6-ch Relay PROFINET Module Common Specifications Protection General ƒƒ LAN ƒƒ Power Consumption ƒƒ Connectors ƒƒ Watchdog ƒƒ Power Input 10/100Base-T(X) ADAM-6150: 3 W @ 24 VDC ADAM-6151: 2.7 W @ 24 VDC ADAM-6156: 3.2 W @ 24 VDC ADAM-6160: 4.5 W @ 24 VDC 2 x RJ-45 LAN, (Daisy Chain) Plug-in screw terminal block (I/O and power) System (1.6 second) 10 ~ 30 VDC ƒƒ Over Voltage Protection ±35 VDC ƒƒ Isolation Protection 2,500 VDC ƒƒ Power Reversal Protection Environment ƒƒ ƒƒ ƒƒ ƒƒ Operating Temperature -10 ~ 70°C (14 ~ 158°F) Storage Temperature -20 ~ 80°C (-4 ~ 176°F) Operating Humidity 20 ~ 95% RH (non-condensing) Storage Humidity 0 ~ 95% RH (non-condensing) 0 ~ 95% RH (non-condensing) Ethernet I/O Modules All product specifications are subject to change without notice Last updated : 19-Mar-2014
ADAM-6151PN-AE 价格&库存
很抱歉,暂时无法提供与“ADAM-6151PN-AE”相匹配的价格&库存,您可以联系我们找货
