1005TX
1005TX
    B+BSMARTWORX
    NETWORK SWITCH-UNMANAGED 5 PORT
1005TX 数据手册
THE INDUSTRIAL NETWORK COMPANY The N-TRON® 1005TX is a low cost unmanaged five port Gigabit Industrial Ethernet Switch. It is housed in a hardened, metal DIN-Rail enclosure, and is designed for use in mission critical data acquisition, control, and Ethernet I/O applications where gigabit capability is required. PRODUCT FEATURES • Compact, Space Saving Package • Full IEEE 802.3, 802.3u, and 802.3ab Compliance • Five 10/100/1000BaseT RJ-45 Ports • Unmanaged Operation • Extended Environmental Specifications • -40ºC to 85º Operating Temperature • >2M Hours MTBF • Supports Full/Half Duplex Operation • Up to 10.0 Gb/s Maximum Throughput • MDIX Auto Sensing Cable • Auto Sensing Speed and Flow Control • Full Wire Speed Communications • Supports up to 4,000 MAC Addresses • Store-and-Forward Technology • Jumbo Frame support • Redundant Power Inputs (10-30 VDC) • LED Link/Activity Status Indication • Hardened Metal DIN-Rail Enclosure The switching fabric simply scales up or down automatically to match your specific network environment. The 1005TX supports up to 4000 MAC addresses, thus enabling these products to support extremely sophisticated and complex network architectures. The N-TRON 1005TX is an ideal candidate for upgrading existing hubs and repeaters to increase bandwidth and determinism by virtually eliminating network collisions. PRODUCT OVERVIEW The product also keeps the network affordable, while The 1005TX Gigabit Industrial Network Switch is maintaining the plug & play simplicity of the unmanaged designed to solve the most demanding industrial hub. communication requirements while providing high The 1005TX can simplify plant wiring by eliminating throughput and minimum downtime. the need to bring data acquisition and control network The 1005TX provides five RJ-45 auto sensing connections back to a climate controlled environment. 10/100/1000BaseT ports. All ports are full/half duplex The 1005TX has extended operating environmental capable, using "state of the art" Ethernet switching specifications to meet the harsh needs of the industrial technology. The 1005TX auto-negotiates the speed and environment. For cost savings and convenience the flow control capabilities of the five TX port connections, network switch can be DIN-Rail, or panel mounted and configures itself automatically. alongside Ethernet I/O or other Industrial Equipment. Since the 1005TX is auto sensing, there will be no need to To increase reliability the 1005TX provides dual make extensive wiring changes if upgrades are made to redundant power inputs. LED's are provided to display host computers, plant systems, or Ethernet I/O modules. the link status and activity of each port. THE INDUSTRIAL NETWORK COMPANY 1005TX SPECIFICATIONS BENEFITS Case Dimensions Height: Width: Depth: Weight: DIN-Rail: Industrial Network Switch 4.0" 1.0" 3.7 0.61 lbs. 35mm (10.2 cm) (2.6 cm) (9.4 cm) (0.27 kg) Electrical Input Voltage: Steady Input Current: Inrush: 10-30 VDC 230mA@24V 13Amp/61us@24V Environmental Operating Temperature: Storage Temperature: Operating Humidity: Operating Altitude: -40oC to 85oC -40oC to 85oC 10% to 95% (Non Condensing) 0 to 10,000 ft. Reliablity MTBF: >2 Million Hours Network Media 10BaseT: 100BaseTX: 1000BaseT: >Cat3 Cable >Cat5 Cable >Cat5e Cable Five (5) RJ-45 TX Copper Ports Recommended Wiring Clearance Front: Top: 2" (5.08 cm) 1" (2.54 cm) Compact Size / Smaller Footprint Extended Environmental Specifications Hardened Metal DIN-Rail Enclosure High Performance High MTBF >2M Hours ESD Protection Diodes on RJ-45 Ports Surge Protection Diodes on Power Inputs Ease of Use • • • • • Plug & Play Operation Auto Sensing 10/100/1000BaseT Auto Sensing Full/Half Duplex MDIX Auto Cable Sensing Unmanaged Operation Increased Performance • Full Wire Speed Capable • Full Duplex Capable • Eliminates Network Collisions • Increases Network Determinism Regulatory Approvals Connectors 10/100/1000BaseT: • • • • • • • FCC/CE (CFR 47, Part 15, Subpart B, Class A) EN 61000-6-2/4, IEC 61000-4-2/3/4/5/6 EN 55011, ICES-003 UL/cUL: Class I, Division 2, Groups A, B, C and D; T4 UL 508, ICE and ANSI/ISA-12.12.01-2007 ABS Type Approval for Shipboard Applications DNV Type Approval Certification RoHS Compliant Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/TS2 for Traffic Control Contact Information N-TRON Corp. 820 S. University Blvd., Suite 4E Mobile, AL 36609 USA TEL: (251) 342-2164 FAX: (251) 342-6353 Website: www.n-tron.com Email: n-tron_info@n-tron.com N-TRON Asia Suite #: 2267, 22/F, One Lujiazui 68 Yin Cheng Road Center, Pudong New Area 200120 Shanghai, P.R. China Phone: +86 (0) 21 6194 6777 Fax: +86 (0) 21 6194 6699 N-TRON Europe GmbH Alte Steinhauserstr 19 6330 Cham / Zg Switzerland TEL: +41 41 7406636 FAX: +41 41 7406637 REV 100513 ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY Ordering Information 1005TX Five 10/100/1000BaseT Ports 1000-PM Panel Mount Kit NTPS-24-1.3 DIN-Rail Power Supply 24V@1.3 Amp ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
1005TX 价格&库存
很抱歉,暂时无法提供与“1005TX”相匹配的价格&库存,您可以联系我们找货
