1003GX2-SX
1003GX2-SX
    B+BSMARTWORX
    NETWORK SWITCH-UNMANAGED 3 PORT
1003GX2-SX 数据手册
THE INDUSTRIAL NETWORK COMPANY The N-TRON® 1003GX2 is an unmanaged three port Gigabit Industrial Ethernet Switch. It is housed in a hardened, metal, DIN-Rail enclosure, and is designed for use in industrial data acquisition, control, and Ethernet I/O applications. PRODUCT FEATURES • Compact Size, Small Footprint • Unmanaged Operation • Full IEEE 802.3, 802.3u, 802.3z, and 802.3ab Compliance • One 10/100/1000BaseT RJ-45 Port • Two 1000BaseSX/LX SFP (Mini-GBIC) Ports • Mix-and-Match Multimode and Singlemode LC Style SFP Gigabit Fiber Transceivers • Extended Environmental Specifications • -40ºC to 85ºC Operating Temperature • >2M Hours MTBF • RJ-45 Port Supports Full/Half Duplex Operation • Up to 6.0 Gb/s Maximum Throughput • Supports up to 1,024 MAC Addresses • Store-and-forward Technology • RJ-45 Port Auto Senses Speed and Flow Control • Full Wire Speed Communications • MDIX Auto Cable Sensing (RJ-45) • Hardened Metal DIN-Rail Enclosure • LED Link/Activity Status Indication • Redundant Power Inputs (10-30 VDC) PRODUCT OVERVIEW The 1003GX2 Gigabit Industrial Ethernet Switch is designed to solve the most demanding industrial communications requirements while providing high throughput and minimum downtime. The 1 0 0 3 G X 2 provides one RJ-45 auto sensing 10/100/1000BaseT port and two 1000BaseSX/LX SFP ports. The RJ-45 port is full/half duplex capable, using "state of the art" Ethernet switching technology. The 1003GX2 auto-negotiates the speed and flow control capabilities of the copper port connection, and configures itself automatically. Each 1000BaseSX/LX fiber optic port utilizes industry standard SFP transceivers with LC style connectors and is configured for full duplex operation. Both multimode and singlemode fiber models are available. Since the TX port of the 1003GX2 is auto sensing, there will be no need to make extensive wiring changes if upgrades are made to host computers, plant systems, or Ethernet I/O modules. The switching fabric simply scales up or down automatically to match your specific network environment. The 1003GX2 supports up to 1,024 MAC addresses, thus enabling these products to support extremely sophisticated and complex network architectures. The N-TRON 1003GX2 is an ideal candidate for upgrading existing hubs and repeaters to increase bandwidth and determinism by virtually eliminating network collisions. The product also keeps the network affordable, while maintaining the plug & play simplicity of the unmanaged hub. The 1003GX2 is engineered to withstand the extremes of industrial environments and carries an impressive operating temperature rating of -40ºC to 85ºC. For cost savings and convenience the media converter can be DIN-Rail mounted alongside Ethernet I/O or other Industrial Equipment. The unique compact size provides a small footprint, conserving space in the most critical dimension. In addition, as with other DIN-Rail devices, the 1003GX2 can be panel mounted by using our 1000-PM kit. To increase reliability, the 1003GX2 contains redundant power inputs. LEDs are provided to display the link status and activity of each port, as well as power on/off status. THE INDUSTRIAL NETWORK COMPANY BENEFITS 1003GX2 SPECIFICATIONS Case Dimensions Height: Width: Depth: Weight: DIN-Rail: 4.3" 1.0" 3.7 0.76 lbs. 35mm (11.0 cm) (2.6 cm) (9.4 cm) (0.22 kg) Electrical Input Voltage: Input Current: Inrush: 10-30 VDC 200mA@24V 13Amp/0.8ms@24V Environmental Operating Temperature: Storage Temperature: Operating Humidity: Operating Altitude: -40oC to 85oC -40oC to 85oC 10% to 95% (Non Condensing) 0 to 10,000 ft. Network Media 10BaseT: 100BaseT: 1000BaseT: 1000BaseSX Multimode: 1000BaseLX Singlemode: >Cat3 Cable >Cat5 Cable >Cat5e Cable 50-62.5/125μm 7-10/125μm Connectors 10/100/1000BaseT: 1000BaseSX/LX SFP: One (1) RJ-45 TX Port Two (2) SFP LC Duplex Gigabit Fiber Ports Recommended Wiring Clearance Front: 5" (12.70 cm) Top: 1" (2.54 cm) SFP Gigabit Fiber Transceiver Characteristics Fiber Length TX Power Min RX Sensitivity Max Wavelength Assumed Fiber Loss Laser Type 550m for 50/125μm 275m for 62.5/125μm* 10km** 40km** 70km** -9.5dBm -17dBm -9.5dBm -20dBm -2dBm -22dBm 0dBm -23dBm 850nm 3.5 to 3.75 dB/km VCSEL 1310nm .45 dB/km FP 1310nm .35 dB/km DFB 1550nm .25 dB/km DFB Regulatory Approvals * SX Fiber Optic Cable ** LX Fiber Optic Cable FCC/CE (CFR 47, Part 15, Subpart B, Class A) EN 61000-6-2/4, IEC 61000-4-2/3/4/5/6 EN 55011, ICES-003 UL/cUL: Class I, Division 2, Groups A, B, C and D; T4A UL 508, ICE and ANSI/ISA-12.12.01-2007 ABS Type Approval for Shipboard Applications DNV Type Approval Certification GOST-R Certified, RoHS Compliant Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/TS2 for Traffic Control Industrial Ethernet Switch • Compact Size, Small Footprint • High Reliability/Availability • Extended Environmental Specifications • Hardened Metal DIN-Rail Enclosure • High Performance • High MTBF >2M Hours (measured) • ESD Protection Diodes on RJ-45 Ports • Surge Protection Diodes on Power Inputs Ease of Use • Plug & Play Operation • RJ-45 Auto Sensing 10/100/1000BaseT Port • RJ-45 Port Auto Senses Duplex, Speed, and Cable Type • Compact DIN-Rail Package Increased Performance • Full Wire Speed Capable • Two 1000BaseSX/LX Fiber Uplinks • Full Duplex Capable • Eliminates Network Collisions • Increases Network Determinism Ordering Information 1003GX2-B One 10/100/1000BaseT Port Two 1000BaseSX/LX Ports with mix-and-match SFP Transceivers* 1003GX2-SX One 10/100/1000BaseT Port Two 1000BaseSX SFP Transceivers 1003GX2-LX-10 One 10/100/1000BaseT Port Two 1000BaseLX-10 SFP Transceivers 1003GX2-LX-40 One 10/100/1000BaseT Port Two 1000BaseLX-40 SFP Transceivers 1003GX2-LX-70 One 10/100/1000BaseT Port Two 1000BaseLX-70 SFP Transceivers 1000-PM Panel Mount Kit NTPS-24-1.3 DIN-Rail Power Supply 24V@1.3 Amp NTSFP-SX One 1000BaseSX Multimode SFP Gigabit Transceiver (two required per unit) NTSFP-LX-ZZ One 1000BaseLX Singlemode SFP Gigabit Transceiver (two required per unit) ZZ = 10, 40, or 70 for GB Singlemode SFP Transceiver *Unit must be fully populated with two SFP transceivers upon shipment. Contact Information N-TRON Corp. N-TRON Europe GmbH 820 S. University Blvd., Suite 4E Alte Steinhauserstr 19 Mobile, AL 36609 USA 6330 Cham / Zg Switzerland TEL: (251) 342-2164 TEL: +41 41 7406636 FAX: (251) 342-6353 FAX: +41 41 7406637 Website: www.n-tron.com Email: N-TRON_info@n-tron.com REV 090805 ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 1003GX2 Drawings on N-TRON Tech Docs Page ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
1003GX2-SX 价格&库存
很抱歉,暂时无法提供与“1003GX2-SX”相匹配的价格&库存,您可以联系我们找货
