105TX
105TX
    B+BSMARTWORX
    NETWORK SWITCH-UNMANAGED 5 PORT
105TX 数据手册
The N-TRON ® 105TX is a low cost unmanaged five port Industrial Ethernet Switch. It is housed in a hardened, metal, DIN-Rail enclosure, and is designed for use in mission critical data acquisition, control, and Ethernet I/O applications. PRODUCT FEATURES • Compact, Space Saving Package • Full IEEE 802.3 Compliance • American Bureau of Shipping (ABS) Type Approval • EN50155 for Railway applications • Five 10/100BaseTX RJ-45 Ports • Unmanaged Operation • Extended Environmental Specifications • -40ºC to 80º Operating Temperature • >2M Hours MTBF • Supports Full/Half Duplex Operation • Up to 1.0Gbs Maximum Throughput • MDIX Auto Sensing Cable • Auto Sensing Speed and Flow Control • Full Wire Speed Communications • Store-and-forward Technology • Redundant Power Inputs (10-30 VDC) • LED Link/Activity Status Indication • Hardened Metal DIN-Rail Enclosure PRODUCT OVERVIEW The 105TX Industrial Network Switch is designed to solve the most demanding industrial communication requirements while providing high throughput and minimum downtime. The 105TX provides four RJ-45 auto sensing 10/100BaseTX ports. All ports are full/half duplex capable, using "state of the art" Ethernet switching technology. The 105TX auto-negotiates the speed and flow control capabilities of the four TX port connections, and configures itself automatically. Since the 105TX is auto sensing, there will be no need to make extensive wiring changes if upgrades are made to host computers, plant systems, or Ethernet I/O modules. The switching fabric simply scales up or down automatically to match specific network environments. The 105TX supports up to 2,000 MAC addresses, enabling these products to support extremely sophisticated and complex network architectures. The is an ideal candidate for upgrading existing hubs and repeaters to increase bandwidth and determinism by virtually eliminating network collisions. The N-TRON 105TX combines affordability and the plug & play simplicity of the unmanaged hub. The 105TX can simplify plant wiring by eliminating the need to bring data acquisition and control network connections back to a climate controlled environment. The 105TX has extended operating environmental specifications to meet the harsh needs of the industrial environment. For cost savings and convenience it can be DIN-Rail mounted alongside Ethernet I/O or other Industrial Equipment. To increase reliability the 105TX provides dual redundant power inputs. LED's are provided to display the link status and activity of each port. 105TX SPECIFICATIONS BENEFITS Case Dimensions Industrial Network Switch Height: Width: Depth: Weight: DIN-Rail: 2.9" 1.5" 3.6" 0.6 lbs. 35mm (7.3cm) (3.8 cm) (9 cm) (0.28 kg) Electrical Input Voltage: Steady Input Current: Inrush: 10-30 VDC 215mA@24V 7.8Amp/0.7ms@24V Environmental Operating Temperature: Storage Temperature: Operating Humidity: Operating Altitude: -40oC to 80oC -40oC to 85oC 10% to 95% (Non Condensing) 0 to 10,000 ft. Shock and Vibration (bulkhead mounted) Shock: 200g @ 10ms Vibration/Seismic: 50g, 5-200Hz, Triaxial Reliablity MTBF: >2 Million Hours Network Media 10BaseT: 100BaseTX: >Cat3 Cable >Cat5 Cable Connectors 10/100BaseTX: Five (5) RJ-45 TX Copper Ports Recommended Wiring Clearance Front: Top: 2" (5.08 cm) 1" (2.54 cm) Ordering Information 105TX Five 10/100BaseTX Ports NTPS-24-1.3 DIN-Rail Power Supply 24V@1.3 Amp • • • • • • • Compact Size / Small Footprint Extended Environmental Specifications Hardened Metal DIN-Rail Enclosure High Performance High MTBF >2M Hours ESD Protection Diodes on RJ-45 Ports Surge Protection Diodes on Power Inputs Ease of Use • • • • • Plug & Play Operation Auto Sensing 10/100BaseTX Auto Negotiation Full/Half Duplex MDIX Auto Cable Sensing Unmanaged Operation Increased Performance • Full Wire Speed Capable • Full Duplex Capable • Eliminates Network Collisions • Increases Network Determinism Regulatory Approvals FCC Title 47 Part 15 Class A ICES-003- Class A CE: EN61000-6-2,4 EN61000-4-2,3,4,5,6 EN55011 UL Listed (US and Canada) per ANSI/ISA-12.12.01-2000, Class I, Div 2, Groups A,B,C,D,T4A; GOST-R Certified ABS Type Approval for Shipboard Applications DNV Type Approval Certification EN50155 for Railway Applications RoHS Compliant Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/TS2 for Traffic Control Equipment Contact Information N-TRON Corp. N-TRON Europe GmbH 820 S. University Blvd., Suite 4E Alte Steinhauserstr 19 Mobile, AL 36609 USA 6330 Cham / Zg Switzerland TEL: (251) 342-2164 TEL: +41 41 7406636 FAX: (251) 342-6353 FAX: +41 41 7406637 Website: www.n-tron.com Email: N-TRON_info@n-tron.com REV 090805 ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 105TX Drawings on N-TRON Tech Docs Page ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
105TX 价格&库存
很抱歉,暂时无法提供与“105TX”相匹配的价格&库存,您可以联系我们找货
