112FX4-ST
112FX4-ST
    B+BSMARTWORX
    NETWORK SWITCH-UNMANAGED 12 PORT
112FX4-ST 数据手册
THE INDUSTRIAL NETWORK COMPANY 112FX4 PRODUCT FEATURES • • • • • • • • • • • • • • • Compact, Space Saving Package Full IEEE 802.3 Compliance Eight 10/100BaseTX RJ-45 Ports Four 100BaseFX Ports, ST or SC Style Unmanaged Operation Extended Environmental Specifications • -40ºC to 80ºC Operating Temperature • >2 Million Hours MTBF Supports Full/Half Duplex Operation Auto Sensing 10/100BaseTX, Duplex, MDIX Full Wire Speed Communication Store-and-Forward Technology Redundant Power Inputs (10-49 VDC) ESD Protection Diodes on all RJ-45 Ports Surge Protection Diodes on Power Inputs LED Link/Activity Status Indication Hardened Metal DIN-Rail Enclosure PRODUCT OVERVIEW The N-TRON 112FX4 unmanaged industrial network switch is designed to meet the most demanding communications requirements while providing high throughput and minimum downtime. The 12-port Ethernet switch is the perfect low-cost solution for mission critical data acquisition, control, and Ethernet I/O applications. Exceptional Quality The ultra-compact 112FX4 provides exceptional performance and reliability under harsh conditions. Enclosed in a high-grade metal case, the switch offers a robust feature set that includes an extended temperature range, superior shock and vibration resistance, redundant power inputs, surge and ESD protection, and an exceptional MTBF—greater than two million hours. The space-saving design includes an attached DIN-rail bracket for quick installation. Versatile Connectivity The 112FX4 includes eight RJ-45 auto-sensing 10/100BaseTX ports. All ports support full/half duplex transmission and use N-TRON's proven Ethernet switching technology. Setup is easy. The unit automatically configures itself on the network and auto-negotiates both speed and flow control for all copper ports. For fiber optic networks, the 112FX4 supplies four 100BaseFX ports. These connections provide vital support for applications where EMI immunity or communication over long distances (up to 80 km) is required. N-TRON offers singlemode or multimode options, as well as SCor ST-style connectivity. Excellent Network Support The 112FX4 is a brilliant plug-and-play solution for unmanaged operations, eliminating virtually all network collisions. Designed with advanced communication processing, store-and-forward programming and memory for up to 8,000 MAC-addresses, this powerful unit handles the demands of even the most complex networks. Intelligent auto-sensing ports instantly recognize and resolve 10/100BaseTX, MDIX and duplex conflicts. For added convenience, LEDs are provided to display link status and activity for each port. RUGGED • RELIABLE • AFFORDABLE THE INDUSTRIAL NETWORK COMPANY 112FX4 Specifications Fiber Transceiver Characteristics Switch Properties Number of MAC Addresses: Latency Typical: Switching Method: 8000 2.6 μs Store-and-Forward Fiber Length 2km* 15km** 40km** TX Power Min -19dBm -15dBm -5dBm -5dBm RX Sensitivity Max -31dBm -31dBm -34dBm -34dBm Wavelength 1310nm 1310nm 1310nm 1550nm * Multimode Fiber Optic Cable ** Singlemode Fiber Optic Cable Case Dimensions Height: Width: Depth: Weight (max): DIN-Rail Mount: 4.3" 3.1" 4.6" 1.6 lbs 35mm (10.8 cm) (7.9 cm) (11.5 cm) (0.73 kg) 10-49 VDC (Regulated) 455mA max.@24VDC 37.3 @ 24VDC NTPS-24-1.3 (1.3A@24V) Environmental Operating Temperature: Storage Temperature: Operating Humidity: Operating Altitude: Connectors 10/100BaseTX: 100BaseFX: Eight (8) RJ-45 Copper Ports Four (4) SC or ST Fiber Duplex Ports Recommended Wiring Clearance Electrical Redundant Input Voltage: Input Current (max): BTU/hr: N-TRON Power Supply: 80km** -40oC to 80oC -40oC to 85oC 5% to 95% (Non Condensing) 0 to 10,000 ft. Front: Side: 4" 1" (10.16 cm) (2.54 cm) Regulatory Approvals • FCC: Title 47, Part 15, Subpart B, Class A; ANSI C63.4; ICES-003 • UL /cUL: Class I, Div 2, Groups A, B, C, D and T4 • CE: IEC 61000-4-2/3/4/5/6/8/11, EN 61000-6-2/4 • GOST-R Certified, RoHS Compliant Shock and Vibration (bulkhead mounted) Shock: Vibration/Seismic: Reliability MTBF: Network Media 10BaseT: 100BaseTX: 200g @ 10ms 50g, 5-200Hz, Triaxial >2 Million Hours ≥Cat3 Cable ≥Cat5 Cable Contact Information N-TRON Corp. 820 S. University Blvd., Suite 4E Mobile, AL 36609 USA TEL: (251) 342-2164 FAX: (251) 342-6353 Website: www.N-TRON.com Email: N-TRON_info@N-TRON.com N-TRON Asia Suite #: 2267, 22/F, One Lujiazui 68 Yin Cheng Road Center, Pudong New Area 200120 Shanghai, P.R. China TEL: +86 (0) 21 6194 6777 FAX: +86 (0) 21 6194 6699 N-TRON Europe GmbH Alte Steinhauserstr 19 6330 Cham / Zg Switzerland TEL: +41 41 7406636 FAX: +41 41 7406637 REV 101103 ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 112FX4 Industrial Ethernet Switch Ordering Information 112FX4-XX Eight 10/100BaseTX Ports, Four Multimode100BaseFX Fiber Optic Ports 112FXE4-XX-YY Eight 10/100BaseTX Ports, Four Singlemode100BaseFX Fiber Optic Ports NTPS-24-1.3 N-TRON Power Supply (1.3 amp @ 24VDC) CPMA-2 Compact Panel Mount (factory installed option) URMK Universal Rack Mount Kit Where: XX = ST or SC YY = 15, 40, or 80 for Singlemode, Blank for Multimode E = Singlemode ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
112FX4-ST
物料型号:112FX4
器件简介:112FX4 是一款由 N-TRON 提供的非管理型工业以太网交换机,专为满足严苛的通信要求而设计,同时提供高吞吐量和最小化停机时间。
它具有紧凑的空间节省型封装,完全符合 IEEE 802.3 标准,提供了 8 个 10/100BaseTX RJ-45 端口,4 个 100BaseFX 端口(ST 或 SC 样式),并且支持全双工或半双工操作。
引脚分配:该设备具有 8 个 RJ-45 自感应 10/100BaseTX 端口和 4 个 100BaseFX 端口,这些端口支持全/半双工传输,并使用 N-TRON 验证的以太网交换技术。
参数特性: - MAC 地址数量:8000 - 典型延迟:2.6 微秒 - 交换方法:存储转发 - 机箱尺寸:高 4.3 英寸(10.8 厘米),宽 3.1 英寸(7.9 厘米),深 4.6 英寸(11.5 厘米),最大重量 1.6 磅(0.73 公斤) - 电源输入:冗余输入电压 10-49 VDC(调节),最大输入电流 455mA @ 24VDC - 工作温度:-40°C 至 80°C - 存储温度:-40°C 至 85°C - 工作湿度:5% 至 95%(非冷凝) - 工作高度:0 至 10,000 英尺(非冷凝)
功能详解:112FX4 支持自动感应 10/100BaseTX、双工、MDIX,全线速通信,以及存储转发技术。
提供了冗余电源输入(10-49 VDC),所有 RJ-45 端口上都有 ESD 保护二极管,电源输入上有浪涌保护二极管,以及 LED 指示灯显示每个端口的链接状态和活动。
应用信息:112FX4 非常适合用于关键任务的数据采集、控制和以太网 I/O 应用,它的超紧凑设计包括一个附带的 DIN 导轨支架,便于快速安装。
封装信息:112FX4 采用加固的金属导轨外壳,提供了一个坚固的特性集,包括扩展的温度范围、优越的抗冲击和抗振动能力、冗余电源输入、浪涌和 ESD 保护,以及卓越的 MTBF(超过两百万小时)。
112FX4-ST 价格&库存
很抱歉,暂时无法提供与“112FX4-ST”相匹配的价格&库存,您可以联系我们找货
