702-W-PM
702-W-PM
    B+BSMARTWORX
    NETWORK SWITCH-MANAGED 1 PORT
702-W-PM 数据手册
700 SERIES Industrial Wireless Radio THE INDUSTRIAL NETWORK COMPANY 702-W The N-TRON® 702-W Industrial Wireless Radio provides outstanding performance and extreme reliability under the harshest industrial conditions. It is ideally suited for connecting wireless devices to a wired network or for connecting two wired networks where it is not possible, practical, or cost-effective to install cable. The 702-W provides three antennas to facilitate Multiple In, Multiple Out (MIMO) technology for increased throughput. Power over Ethernet (PoE) capability enables the unit to receive power through a Cat5e cable from a PoE sourcing device, such as N-Tron's 105TX-POE Switch or 100-PoE4 Midspan Injector. This ability makes deployments of network nodes much easier as a single Cat5e cable is all that is needed to carry both power and data. PRODUCT FEATURES • One 10/100BaseTX RJ-45 port • Three antennas for 3x3 MIMO operations • Four user-definable LEDs for display of signal quality • Radio enable, link/activity, and power LEDs Industrial Packaging and Specifications • Station roaming • Auto sensing 10/100BaseTX, duplex, and MDIX The 702-W is specifically designed to operate in industrial environments. With its rugged enclosure and industrial specifications—including redundant power inputs and expanded tolerance to shock, vibration, electrical noise and temperature fluctuations—the 702-W easily meets and exceeds the operating parameters of connected equipment. • Rugged DIN-rail enclosure Multiple Wireless Modes • Redundant power inputs (20-49 VDC) The 702-W provides a number of configuration options that allow customization to suit specific applications. • 802.3af PoE-powered device • Extended environmental specifications • Web browser management Wireless Compliance • IEEE 802.11a Compliant Station: In "station" configuration, the 702-W is used to connect a single device • IEEE 802.11b Compliant Station, WDS (Wireless Distribution System): In "station, WDS" mode, • IEEE 802.11g Compliant the 702-W can be connected to a remote wired switch, allowing multiple devices (MAC Address forwarding) to be connected to the wireless access point when WDS is activated. (MAC Address) to a wireless access point. • IEEE 802.11n Compliant Security • 802.11i with AES-CCM & TKIP Encryption Access Point: In "access point" mode, the 702-W serves as a wireless switch for attached wireless stations. Wireless access points are commonly used to create one wireless local area network (WLAN) that spans an area around the access point. Each access point typically supports up to 253 stations. • 802.1x, 64/128 bit WEP Data Rates • Legacy 802.11a/b/g (1-54 Mbps) Access Point, WDS (Wireless Distribution System): In "access point, WDS" • 802.11n (up to 300 Mbps) Range Performance • Indoor (antenna dependent) greater than 300m • Outdoor (antenna dependent) greater than 60km APPLICATIONS The 702-W provides a reliable wireless connection that can be quickly and easily deployed at a fraction of the cost of hardwired installations. It is also ideal for network communications between mobile devices such as forklifts, heavy equipment, laptop computers, and other devices that are impractical or impossible to connect with copper or fiber cable. mode, the 702-W provides wireless connections to a number of access points, expanding the coverage of the wireless network. In this configuration, the main base access point is extended using a series of relay access points in WDS mode (Extended Service Set) and, in turn, can form a WLAN consisting of thousands of stations. All stations should be configured in "station WDS" mode. Correctly configured switches using WDS will create a single network, providing station mobility throughout the wireless network. Multiple Network Modes Bridge: The 702-W will operate in Layer 2 without network segmentation. Router: The 702-W offers Layer 3 routing to allow network segmentation. RUGGED • RELIABLE • AFFORDABLE www.n-tron.com 702-W Scenario 1 – Basic Bridge Access Point: Station: The "access point" mode allows the 702-W to serve as a wireless switch for the wireless stations attached to it. Wireless access points are commonly used to create one wireless local area network (WLAN) that spans an area around the access point. Each access point typically supports up to 253 stations. In "station" configuration, the 702-W is used to connect a single device (MAC address) to a wireless access point. For added security, the 702-W supports WEP, WPA™, and WPA2™. WPA and WPA2, TKIP (Temporal Key Integrity Protocol) and CCMP (counter mode with Cipher Block Chaining Message Authentication Code Protocol) are available. Scenario 2 – Control Network In station WDS mode, the 702-W can be connected to a remote wired Ethernet switch with multiple devices connected to the switch. www.n-tron.com 702-W Scenario 3 – WDS Peering These 702-W wireless radios have been configured as peers. This topology allows forklifts, or other mobile wireless devices, to maintain communication as they move from the area covered by one 702-W into the area covered by the next 702-W. Scenario 4 – Broadband Modem Wireless Router (W/ DHCP) The 702-W configured as a powered router allows Layer 3 routing to setup network segmentation. It supports the Network Address Translation (Masquerading) feature which is widely used by access points. NAT will act as the firewall between LAN and WLAN networks. Additional firewall settings can be configured for Layer 3 packet filtering and access control in router mode. It can also act as a DHCP server, automating the assigning of IP addresses. www.n-tron.com 702-W SPECIFICATIONS Physical Height: (w/o antennas): 5.2" (13.2 cm) Width: 7.4" (18.8 cm) Depth (includes DIN-Rail mount): 1.5" (3.9 cm) Weight (max): 1.9 lbs (0.9 kg) DIN-Rail Mount: 35 mm Environmental Operating Temperature: -40oC to 70oC Storage Temperature: -40oC to 85oC Operating Humidity: 5% to 95% (non condensing) Operating Altitude: 0 to 10,000 ft. N-TRON Power Supply: NTPS-24-1.3 (sold separately) Electrical Redundant Input Voltage: 20-49 VDC (regulated) Input Current (max): 200 mA max @ 24 VDC 702-W Max Power: 4.8 watts max Input Ripple: Less than 100 mV Reliability MTBF: >1 million hours Network Media 10BaseT: ≥Cat3 cable 100BaseTX: ≥Cat5 cable 802.11abgn: Air Connectors 10/100BaseTX: One (1) RJ-45 copper port; PoE-powered device support 802.11abgn: (3) RP-SMA connectors Recommended Wiring Clearance (Antenna Dependent) Front: 4" (10.2 cm) Side: 4" (10.2 cm) Top: 6" (15.3 cm) Radio Output Power: Radio Receiver Sensitivity: Up to 250mW US 802.11a 5GHz 802.11a 5GHz DataRate Avg TX ±2dB DataRate Sens. ±3dB 1-24Mbps 36Mbps 48Mbps 54Mbps 802.11b/g DataRate 24 dBm 22 dBm 20 dBm 19 dBm 1-24Mbps 36Mbps 48Mbps 54Mbps 2.4GHz 802.11b/g Avg TX ±2dB 1-24Mbps 36Mbps 48Mbps 54Mbps 24 dBm 22 dBm 20 dBm 19 dBm 802.11n 2.4GHz DataRate MCS0 MCS1 MCS2 MCS3 MCS4 MCS5 MCS6 MCS7 MCS8 MCS9 MCS10 MCS11 MCS12 MCS13 MCS14 MCS15 DataRate 5GHz Avg TX ±2dB 24dBm 24dBm 24dBm 22dBm 22dBm 22dBm 18dBm 15dBm 24dBm 24dBm 22dBm 20dBm 20dBm 17dBm 17dBm 15dBm 24dBm 24dBm 24dBm 22dBm 22dBm 22dBm 18dBm 15dBm 24dBm 24dBm 22dBm 20dBm 20dBm 17dBm 17dBm 15dBm Regulatory Approvals • Safety: UL 508 and 1604 • Hazardous Location: Class I, Div 2, Groups A, B, C, D, T4A; ANSI/ISA-12.12.01-2007 • EMI: FCC/CE (CFR 47, Part 15, Subpart B - Class A); ANSI C63.4; • EMC: R&TTE Directive 99/5/EC ; EN 301 489-3; IEC 61000-4-2 (ESD); IEC 61000-4-3 (RS) • GOST-R Certified • ROHS compliant www.n-tron.com Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/ TS2 for Traffic Control -96 dBm -95 dBm -94 dBm -91 dBm 2.4GHz Sens. ±3dB 1-24Mbps 36Mbps 48Mbps 54Mbps -97 dBm -90 dBm -86 dBm -84 dBm 802.11n 2.4GHz DataRate MCS0 MCS1 MCS2 MCS3 MCS4 MCS5 MCS6 MCS7 MCS8 MCS9 MCS10 MCS11 MCS12 MCS13 MCS14 MCS15 5GHz Sens. ±3dB -97dBm -96dBm -93dBm -91dBm -87dBm -84dBm -78dBm -75dBm -96dBm -94dBm -91dBm -88dBm -85dBm -80dBm -79dBm -76dBm -96dBm -95dBm -92dBm -90dBm -86dBm -83dBm -77dBm -74dBm -95dBm -93dBm -90dBm -87dBm -84dBm -79dBm -78dBm -75dBm 702-W www.n-tron.com 702-W ORDERING INFORMATION PART NUMBER DESCRIPTION 702-W ........................................................ 1 Port (10/100BaseTX) Industrial Wireless Radio with three MIMO antennas, DIN-rail 702-W-PM ................................................. Panel mount kit for use with N-Tron's 702-W Wireless Radio ANT-CAB-400-N-RPSMA-X ...................... Low loss CA-400 coaxial cable with (1) RP-TNC connector and (1) N-male connector ANT-CAB-195-RPSMA-RPSMA-X ............ 702-W antenna bulkhead extension cable set; each cable includes (1) straight RP-SMA bulkhead jack and (1) 90° RP-SMA plug (package of 3) ANT-MD24-12............................................ 2.4GHz 12dBi mini directional antenna and pole mount bracket included ANT-PAD24-16 .......................................... 2.4GHz 16dBi panel directional antenna and pole mount bracket included ANT-PAD58-19 .......................................... 5.8GHz, 19dBi panel directional antenna N-female connector and pole mount bracket included ANT-PD58-32 ............................................ 5.8 GHz parabolic dish 32dBi directional antenna and pole mount bracket included ANT-LA6-NFF ............................................ 2-6GHz quarter wave lightning arrestor (N-female to N-female, less than 0.2dB insertion loss, IP65, -40° to 85°C) ANT-CAB-400-N-X .................................... Low loss CA-400 coaxial cable with (2) N-female connector (for use with the ANT-LA6-NFF lightning arrestor) NTPS-24-1.3 ............................................. DIN-rail power supply 24 VDC @ 1.3 amp
702-W-PM 价格&库存
很抱歉,暂时无法提供与“702-W-PM”相匹配的价格&库存,您可以联系我们找货
