702M12-W
702M12-W
    B+BSMARTWORX
    NETWORK SWITCH-MANAGED 1 PORT
702M12-W 数据手册
THE INDUSTRIAL NETWORK COMPANY The N-TRON ® 702M12-W Industrial Wireless Radio offers outstanding performance and ease of use. It is ideally suited for connecting wireless devices to a wired network or for connecting two wired networks in an IP67 environment, where it is not possible, impractical, or too expensive to install cable. Product Features • • • • • • • • • • • Full IEEE 802.11a,b,g,n Compliance IP67 Rated, Industrial Hardened Enclosure One 10/100BaseTX M12 Port Three Antennas for 3x3 MIMO Operations Four user definable LED's for display of signal quality Radio Enable, Link/Activity, and power LEDs 802.3af PoE Powered Device Extended Environmental Specifications Autosensing 10/100BaseTX, Duplex, and MDIX Redundant Power Inputs (20-49 VDC) Web Browser Management Wireless Compliance: • IEEE 802.11a/b/g/n Compliant Security: • 802.11i with AES-CCM & TKIP Encryption • 802.1x, 64/128 bit WEP Data Rates: • Legacy 802.11a/b/g (1-54Mbps), • 802.11n (up to 300Mbps) Range Performance: • Indoor (Antenna Dependent) greater than 300m • Outdoor (Antenna Dependent) greater than 60km Applications In industrial environments, the installation of fiber or Cat5e cable and associated power cables is difficult or cost prohibitive. There are also applications which require communication with mobile devices such as laptop computers, forklifts, cockpits or control centers on mobile equipment such as cranes, and other devices which are impossible to connect with copper or fiber cable. The N-TRON 702M12-W provides a wireless connection that can be quickly and easily deployed. With it's wide operating temperature range and 1 million hours MTBF, the 702M12-W offers the industrial ruggedness that customers have come to expect of N-TRON products. The IP67 sealed enclosure insures that outdoor, wash down, and the most dusty environments will present no problems to the 702M12-W. Three antennas enable the use of Multiple-In, Multiple-Out (MIMO) technology for increased throughput. Power over Ethernet (PoE) technology allows the 702M12-W to receive power through the Cat5e cable from a PoE sourcing device, such as the N-TRON 105TX-POE Switch. This eliminates the need for power cables or power supplies for the 702M12-W. Using wireless and PoE technology makes temporary deployment of network nodes much easier because only one Cat5e cable is required. Industrial Packaging and Specifications The 702M12-W is specifically designed to operate in industrial environments. With it's rugged enclosure and industrial specifications such as extended shock and vibrations specs plus redundant power inputs, the 702M12-W easily meets and exceeds the operating parameters of the connected equipment. Multiple Wireless Modes The 702M12-W provides a number of configuration options that allow it to be customized to suit specific application requirements. Station: In "station" configuration the 702M12-W is used to connect a single device (MAC Address) to a wireless access point. Station, WDS (Wireless Distribution System): In "station, WDS" mode the 702M12-W can be connected to a remote wired switch and will allow multiple devices (MAC Address forwarding) to be connected to the wireless access point with WDS activated. Access Point: The "Access Point" mode allows the 702M12-W to serve as a wireless switch for the attached wireless stations. Wireless access points are commonly used to create one wireless local area network (WLAN) that spans an area around the Access Point. Each access point typically supports up to 253 stations. Access Point, WDS (Wireless Distribution System): The 702M12-W in "Access Point, WDS" mode allows wireless connection of a number of access points to extend the coverage of the wireless network. The main base Access Point in WDS mode is extended using a series of relay Access points in WDS mode (Extended Service Set) and can in turn form a WLAN consisting of thousands of stations. All stations should be configured in "Station WDS" mode. Correctly configured switches using WDS will create a single network, providing station mobility throughout the wireless network. Multiple Network Modes Bridge: In this mode the 702M12-W will operate in Layer two without network segmentation. Router: Router operating mode offers Layer three routing to allow network segmentation. THE INDUSTRIAL NETWORK COMPANY Scenario 1 – Basic Bridge Access Point: The "Access Point" mode a l l o w s t h e 702M12-W to serve as a wireless switch for the wireless stations attached to it. Station: In "station" configuration the 702M12-W is used to connect a single device (MAC Address) to a wireless access point. For added security, the 702M12-W supports WEP, WPA™, and WPA2™. WPA and WPA2, TKIP (Temporal Key Integrity Protocol) and CCMP (Counter Mode with Cipher Block Chaining Message Authentication Code Protocol) are available. Scenario 2 – Control Network In Station WDS mode the 702M12-W can be connected to a remote wired Ethernet switch with multiple devices connected to the switch. THE INDUSTRIAL NETWORK COMPANY Scenario 3 – WDS Peering In this scenairio, each 702M12-W has been configured as a peer of selected other 702M12-W(s) by using the MAC Addresses of the select unit(s). This allows forklifts or other mobile wireless devices to maintain communication seamlessly as they move from the area covered by one 702M12-W into the area covered by the next 702M12-W. Scenario 4 – Broadband Modem Wireless Router (W/ DHCP) The N-TRON 702M12-W configured as a router can act as a DHCP server and supports the Network Address Translation (Masquerading) feature which is widely used by Access Points. This automates the assigning of IP addresses to devices as they connect. NAT will act as a firewall between LAN and WLAN networks. Additional firewall settings can be configured for layer 3 packet filtering and access control in Router mode. THE INDUSTRIAL NETWORK COMPANY 702M12-W Specifications Case Dimensions Height: (w/o antennas) Width: Depth: Weight (max): Radio Output Power: 6.7" 6.7" 1.8" 3.5 lbs (17.2 cm) (17.2 cm) (4.6 cm) (1.6 kg) Environmental Operating Temperature: Storage Temperature: Operating Humidity: Operating Altitude: N-TRON Power Supply: -40oC to 70oC -40oC to 85oC 5% to 100% (Non Condensing) 0 to 10,000 ft. NTPS-24-1.3 Electrical Redundant Input Voltage: Input Current (max): 702M12-W Max Power: Input Ripple: 20-49 VDC (Regulated) 200mA max @24 VDC 4.8Watts max Less than 100mV Reliability MTBF: >1 Million Hours Network Media 10BaseT: 100BaseTX: 802.11abgn: >Cat3 Cable >Cat5 Cable Air Connectors 10/100BaseTX: 802.11abgn One (1) M12 Copper Port PoE Powered device support (3) RP-TNC connectors Recommended Wiring Clearance (Antenna Dependent) Front: Side: Top: 4" (10.16cm) 4" (10.16cm) 6" (15.24cm) Contact Information N-TRON Corp. 820 S. University Blvd., Suite 4E Mobile, AL 36609 USA TEL: (251) 342-2164 FAX: (251) 342-6353 Website: www.N-TRON.com Email: N-TRON_info@N-TRON.com Radio Receiver Sensitivity Up to 250mW US 802.11a DataRate 1-24Mbps 36Mbps 48Mbps 54Mbps 5GHz Avg TX ±2dB 24 dBm 22 dBm 20 dBm 19 dBm 802.11a DataRate 1-24Mbps 36Mbps 48Mbps 54Mbps 5GHz Sens. ±3dB -96 dBm -95 dBm -94 dBm -91 dBm 802.11b/g DataRate 1-24Mbps 36Mbps 48Mbps 54Mbps 2.4GHz Avg TX ±2dB 24 dBm 22 dBm 20 dBm 19 dBm 802.11b/g DataRate 1-24Mbps 36Mbps 48Mbps 54Mbps 2.4GHz Sens. ±3dB -97 dBm -90 dBm -86 dBm -84 dBm 802.11n DataRate MCS0 MCS1 MCS2 MCS3 MCS4 MCS5 MCS6 MCS7 MCS8 MCS9 MCS10 MCS11 MCS12 MCS13 MCS14 MCS15 2.4GHz 5GHz Avg TX ±2dB 24dBm 24dBm 24dBm 24dBm 24dBm 24dBm 22dBm 22dBm 22dBm 22dBm 22dBm 22dBm 18dBm 18dBm 15dBm 15dBm 24dBm 24dBm 24dBm 24dBm 22dBm 22dBm 20dBm 20dBm 20dBm 20dBm 17dBm 17dBm 17dBm 17dBm 15dBm 15dBm 802.11n DataRate MCS0 MCS1 MCS2 MCS3 MCS4 MCS5 MCS6 MCS7 MCS8 MCS9 MCS10 MCS11 MCS12 MCS13 MCS14 MCS15 2.4GHz 5GHz Sens. ±3dB -97dBm -96dBm -96dBm -95dBm -93dBm -92dBm -91dBm -90dBm -87dBm -86dBm -84dBm -83dBm -78dBm -77dBm -75dBm -74dBm -96dBm -95dBm -94dBm -93dBm -91dBm -90dBm -88dBm -87dBm -85dBm -84dBm -80dBm -79dBm -79dBm -78dBm -76dBm -75dBm Regulatory Approvals UL /cUL Class I, Div 2, Groups A, B, C, D, and T4A ANSI/ISA-12.12.01-2007 and UL 508 and 1604 FCC/CE (CFR 47, Part 15, Subpart B - Class A), EN 301 489-3, IEC 6100-4-2, 6100-4-3, R&TTE Directive 99/5/EC, ANSI C63.4, and ICES-003 Issue 3 GOST-R Certified, RoHS Compliant, Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/ TS2 for Traffic control N-TRON Asia Suite #: 2267, 22/F, One Lujiazui 68 Yin Cheng Road Center, Pudong New Area 200120 Shanghai, P.R. China Phone: +86 (0) 21 6194 6777 Fax: +86 (0) 21 6194 6699 N-TRON Europe GmbH Alte Steinhauserstr 19 6330 Cham / Zg Switzerland TEL: +41 41 7406636 FAX: +41 41 7406637 REV 100924 ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 702M12-W WIRELESS ETHERNET RADIO Cables with M12 connectors Ordering Information Ordering Information 702M12-W Industrial Wireless Radio CAT5E-M12-M12-X Straight M12 to Str. M12, Shielded 702M12-PK Pole mount kit for 702M12-W CAT5E-M12-RJ45-X Straight M12 to RJ-45, Shielded ANT-CAB-400-N-RPTNC-X Low Loss Coaxial Antenna cable 1 RP-TNC and 1 N Male connector CAT5E-M12-X Straight M12 to bare end, Shielded ANT-MD24-12 2.4GHz 12dBi Mini Directional Antenna CAT5E-RM12-M12-X 90º M12 to Str. M12, Shielded ANT-PAD24-16 2.4GHz 16dBi Directional Antenna CAT5E-RM12-RM12-X 90º M12 to 90º M12, Shielded ANT-PAD58-19 5.8GHz 19dBi Directional Antenna CAT5E-RM12-RJ45-X 90º M12 to RJ-45, Shielded ANT-PD58-32 5.8 GHz Parabolic Dish 32dBi Directional Antenna CAT5E-RM12-X ANT-LA6-NFF 2-6GHz quarter wave lightning arrestor PWR-M12-A-X (N-female to N-female, less than 0.2dB insertion loss, IP65, -40 to 85°C) Power Cable, M12 A-Coded Straight Female to bare end, Shielded ANT-CAB-400-N-X Low loss CA-400 coaxial cable with (2) N Female connectors for use with the ANT-LA6-NFF lightning arrestor PWR-RM12-A-X Power Cable, M12 A-Coded 90º Female to bare end, Shielded M12DRC-ISO DIN-Rail kit, two isolated plastic clips M12DRC-MTL DIN-Rail kit, two metal clips Where:X = length of cable, fill in desired amount in feet. Example: CAT5E-RM12-10 (for a 10ft cable) NTPS-24-1.3 DIN-Rail Power Supply 24V@1.3 Amp 90º M12 to bare end, Shielded ® 2010 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
702M12-W 价格&库存
很抱歉,暂时无法提供与“702M12-W”相匹配的价格&库存,您可以联系我们找货
