BB-EIRP410-2SFP-T
BB-EIRP410-2SFP-T
    B+BSMARTWORX
    GIGABIT POE (8) 10/100, (2) SFP
BB-EIRP410-2SFP-T 数据手册
10 Port Industrial Ethernet Switch with 2 RJ-45/SFP Combo Ports for Gigabit Ethernet EIRP410-2SFP-T PRODUCT FEATURES • • • • • The EIRP410-2SFP-T is a 10 Port unmanaged Industrial Ethernet Switch. In addition to 8 PoE copper RJ-45 ports, it has 2 RJ-45/SFP Combo ports to accommodate Gigabit Ethernet. Small Form-factor Pluggable (SFP) Port: The SFP Ports provide flexibility when planning a network. Modules are available in multiple fiber formats. If an SFP module is not inserted, the associated combo port can be used with standard RJ-45 copper. High-Speed Transmissions: The switch includes a switch controller that automatically senses transmission speed (10/100/1000 Mbps). The RJ-45 interface also auto-detects MDI or MDI-X, eliminating the requirement for a crossover cable. Each port is buffered and supports store-and-forward protocol. Dual Power Input: To reduce the risk of power failure, the switch has two 48 VDC power inputs. If the power fails, the switch will automatically use the secondary power input. Also, if the power goes out the corresponding P1 or P2 LED will go out and the Fault LED will light. The contacts for the alarm output will also open. Eight 10/100 BaseT 802.3af End Point PoE Ports Two RJ-45/SFP 100/1000 Combo Slots for Gigabit Ethernet UL, cUL CE/EN 60950 Wide Operating Temperature (-40 to 75C) DIN Rail or Panel Mount Ordering Information Model Number Description Industrial Gigabit Switch (8 PoE, 2 CU/SFP) EIRP410-2SFP-T Power Over Ethernet Sourcing Accessories SDR-240-48 - DIN-Rail Power Supply, 10A, 240W, 48V C5UMB3FBL - 3 ft. (1 M)- Blue - Category 5e UTP Patch Cord DFMM-LCLC-1M - Multi-Mode Duplex Fiber Cable, LC To LC, 1 Meter DFSM-LCLC-1M - Single-Mode Duplex Fiber Cable, LC To LC, 1 Meter SFP-1000SX-M-550M-T - SFP Module, 1000Base-SX, Multi-mode 550m, LC Connector (-40 to 85°C) SFP-100FX-M-2KM-T - SFP Module, 100Base-FX, Multi-mode 2km, LC Connector (-40 to 85°C) SFP-1000LX-S-10KM-T - SFP Module, 1000Base-LX, Single-mode 10km, LC Connector (-40 to 85°C) SFP-1000LX-S-20KM-T - SFP Module, 1000Base-LX, Single-mode 20km, LC Connector (-40 to 85°C) SFP-100FX-S-30KM-T - SFP Module, 100Base-FX, Single-mode 30km, LC Connector (-40 to 85°C) Flexible Mounting: IP30 metal enclosure - DIN or Panel mounted. Power Over Ethernet (PoE); The eight 10/100 ports are classified as power sourcing equipment (PSE) . These ports can be used to power IEEE 802.3af compliant powered devices (PD), eliminating the need for a separate power supply for each device. (15.4W per port) Wide Operating Temperature: With an operating temperature of -40 to 75°C (-40 to 167°F), this switch is suitable for use in harsh industrial environments. Easy Troubleshooting: There are two LED indicators for each port that display the link status and transmission speed. Three LED indicators for power (P1, P2 and Fault) show power status. FWD LEDs on each PoE port indicate when a powered device is connected. These indicators allow you to quickly diagnose and correct problems and ensure your network remains reliable. www.bb-elec.com | EIRP410-2SFP-T_3713ds 10 Port Industrial Ethernet Switch with 2 RJ-45/SFP Combo Ports for Gigabit Ethernet EIRP410-2SFP-T specifications Regulatory Safety UL, cUL CE/EN60950-1 FCC Class A CE EN61000-6-2 CE EN61000-6-4 CE EN61000-4-2 (ESD) EMC CE EN61000-4-3 (RS) CE EN61000-4-4 (EFT) CE EN61000-4-5 (Surge) CE EN61000-4-6 (CS) CE EN61000-4-8 (Magnetic Field) Free Fall IEC60068-2-32 Shock IEC60068-2-27 Vibration IEC60068-2-6 IEEE Standards IEEE 802.3 802.3. 10Base-T Ethernet IEEE 802.3u 100Base-TX and 100Base-FX Fast Ethernet IEEE 802.3ab 1000Base-T IEEE 802.3z Gigabit Fiber IEEE 802.3x Flow Control and Back Pressure IEEE802.3af Power over Ethernet Network Specifications Back-plane (Switching Fabric): 5.6Gbps Architecture Throughput (Full-dux): 8.3Mpps@64bytes 14,880 pps Ethernet Port Transfer Rate 148,800 pps Fast Ethernet Port 1,488,000 pps Gigibit Fiber Ethernet Buffer 1 MB MAC Table 8K Broadcast Storm Filtering Misc CSMA/CD Interface 8 x 10/100BaseT, 2 x10/100/1000, RJ-45 Ports Auto MDI/MDI-X CU/SFP 2 x Mini-GBIC SFP Combo Ports Per unit: Power (Green), Power 1 (Green), Power 2 (Green), Fault (Red), LED 8 port 10/100: Link/Activity (Green), Full duplex/ Collision (Amber), Power Feeding (Green) Gigabit port: Link/Activity orders@bb-elec.com support@bb-elec.com PoE Ports Standard Capacity Pin Assignment Power Input Voltage Power Connection Wire Size Power Use Fault Output Environmental Operating Temperature Storage Temperature Operating Humidity Mechanical Enclosure Mounting Dimensions 1 through 8 802.3af End Point Alternative A Power Source Equipment (PSE) 15.4W per port 1 & 2 – VCC(+), 3 & 6 – VCC(-) Dual 48 VDC Inputs Reverse Polarity Protection Removable Terminal Block 12 to 24 AWG 9.6 Watts (Without PoE Load) 140 Watts (Full PoE Load) 1 Relay Output – Normally Closed - 40 to 75°C (-40 to 167°F) - 40 to 85°C (-40 to 185°F) 0 to 95% IP30 Metal Enclosure 35mm DIN Rail or Panel Mount Attachments (72mm (W) x 105mm (D) x 152mm (H) 2.84 x 4.13 x 5.98 inch International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-EIRP410-2SFP-T 价格&库存
很抱歉,暂时无法提供与“BB-EIRP410-2SFP-T”相匹配的价格&库存,您可以联系我们找货
