EIS-EXTEND-C-UK
EIS-EXTEND-C-UK
    B+BSMARTWORX
    NETWORKING POWER ADAPTER ETHERNT
EIS-EXTEND-C-UK 数据手册
Ethernet Coaxial Extender for 10/100 Networks EIS-EXTEND-C PRODUCT FEATURES • • • • • • • • • • • The model EIS-EXTEND-C allows your existing coaxial cable to be used to extend Ethernet connections up to 8530 feet (2,600 M). Two EIS-EXTEND-C models are required for the Ethernet extension, (one at each end of your extension points). This product can be used with included power supply or in a 19 inch rack mount chassis, which can house up to 16 EIS-EXTEND-C units or EIS Media Converters. One 10/100Base TX (TX) Ethernet port with RJ-45 connector Auto negotiation of speed and duplex mode on TX port Auto MDI/MDIX on Ethernet port IEEE 802.3 10BaseT and IEEE 802.3u 100BaseTX compliant Line port uses BNC connector or F-Type connector Line port link is full-duplex up to 85Mbps over existing coaxial cable One DIP switch for configuring local or remote mode Status LED’s for monitoring and connection status External AC to DC power adapter included Used as a stand-alone device or with a 19 inch rack chassis Hot-swappable when used in 19 inch rack chassis Ordering Information Model Number Description 10/100-TX Ethernet Copper Extender w/USA Power EIS-EXTEND-C Adaptor 10/100-TX Ethernet Copper Extender w/USA Power EIS-EXTEND-C-UK Adaptor 10/100-TX Ethernet Copper Extender w/EU Power EIS-EXTEND-C-EU Adaptor Accessories EIS-RACK-PS - Power Supply For EIS-Rack-16, 84 Watts EIS-RACK-16 - Media Converter 19 Inch 2U Rack Chassis - 16 Slots Mechanical Diagram 10.92cm10.92cm 4.30 in 4.30 in 2.38cm 2.38cm 0.94 in 0.94 in 8.03cm 8.03cm 3.16 in 3.16 in www.bb-elec.com | EIS-EXTEND-C_3713ds Ethernet Coaxial Extender for 10/100 Networks EIS-EXTEND-C specifications Ethernet Technology IIEEE802.3 10Base-T, IEEE802.3u 100Base-TX, Standards IEEE802.3x, Ethernet over VDSL Protocols Transparent to higher layer protocols Processing Type IEEE802.3x Full-duplex flow control Interface RJ-45, 10/100Base-TX Full/Half-duplex AutoEthernet Port Negotiation, Auto-MDI/MDIX Speed 10/100Mbps Distance 328 ft. (100meters) 10Base-T: UTP CAT. 3, 4, 5 (2-pair wire), 100Base-TX: Cable UTP CAT. 5 (2-pair wire) Extender Line Port BNC Coaxial Speed 1/5/10/20/30/40/50/60/70/75Mbps Distance 8,530 ft. (2,600meters) Cable Coaxial Cable (5C2V / RG6AU) Power Input Voltage 12 VDC Power Consumption 5.76W Max. 0.48A@12VDC Environmental Operating Temperature: -10°C to 60°C (14°F to 140°F) Storage Temperature -20°C to 70°C (-4°F to 158°F) Humidity 5% to 95% (non-condensing) MTBF 57,515 hours MTBF Calculation Parts count reliability prediction Mechanical Enclosure Aluminum case 8.03cm (W) x 10.92cm (D) x 2.38cm (H) Dimensions 3.16” (W) x 4.30” (D) x 0.94” (H) Weight 150g (0.33 lb.) Top LEDs (BNC Line Connections) LEDs Status Green 1 Amber Green 2 Amber Green 3 Amber Green 4 Amber Green 5 Amber Speed 1~ 5Mbps 6~10Mbps 11~16Mbps 17~20Mbps 21~29Mbps 30~43Mbps 44~54Mbps 55~63Mbps 64~74Mbps 75~85Mbps Distance up to 2600M up to 2400M up to 2000M up to 1800M up to 1600M up to 1400M up to 1200M up to 1000M up to 600M up to 200M orders@bb-elec.com support@bb-elec.com Regulatory Approvals RoHS - Yes Safety UL60950-1, EN60950-1, IEC60950-1 FCC Part 15, Class A VCCI, Class A EMI EN61000-6-3 EN55022, EN61000-3-2, EN61000-3-3 EN61000-6-2 EN61000-4-2 (ESD Standards) Contact: + / - 4KV; Criteria B Air: + / - 8KV; Criteria B EN61000-4-3 (Radiated RFI Standards) 10V/m, 80 to 1000MHz; 80% AM Criteria A EN61000-4-4 (Burst Standards) Signal Ports: + / 2KV; Criteria B D.C. Power Ports: + / 2KV; Criteria B EMS EN61000-4-5 (Surge Standards) Signal Ports: + / - 1KV; Line-to-Line; Criteria B D.C. Power Ports: + / - 0.5KV; Line-to-earth; Criteria B EN61000-4-6 (Induced RFI Standards) Signal Ports: 10Vrms @ 0.15~80MHz; 80% AM Criteria A D.C. Power Ports: 10Vrms @ 0.15~80MHz; 80% AM Criteria A EN61000-4-8 (Magnetic Field Standards) 30A/m @ 50, 60Hz; Criteria A Environmental Test IEC60068-2-6 Fc (Vibration Resistance) 5g @ Compliance 10~150KHz, Amplitude 0.35mm (Operation/Storage/ Transport) IEC60068-2-27 Ea (Shock) 25g @ 11ms (Half-Sine Shock Pulse; Operation) 50g @ 11ms (Half-Sine Shock Pulse; Storage/Transport) IEC60068-2-32 Ed (Free Fall) 1M (3.281 ft.) Front Panel LEDs (Ethernet and Line Connections) Port LEDs Status Description Ethernet (RJ-45) Pwr Steady Power on (Pwr stands for POWER) Off Power off Lnk/Act Steady Valid Ethernet connection established (Lnk stands for LINK) Flashing Transmitting or receiving Ethernet data (Act stands for ACTIVITY) Off No valid Ethernet connection nor transmitting/receiving Ethernet data Fdx Steady Ethernet connection in full duplex mode (Fdx stands for FULL-DUPLEX) Flashing Collision occurred Off Ethernet connection in half-duplex mode Line (BNC) Rmt Steady The device operates in remote mode Loc Steady The device operates in local mode Err Steady Error occurred Lnk Steady A valid connection established between local & remote units International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
EIS-EXTEND-C-UK 价格&库存
很抱歉,暂时无法提供与“EIS-EXTEND-C-UK”相匹配的价格&库存,您可以联系我们找货
