BB-EPSG202
BB-EPSG202
    B+BSMARTWORX
    GIGABIT POE SPLITTER, (25W) 24 V
BB-EPSG202 数据手册
Industrial High Power PoE Splitter for 10/100/1000T EPSG202 PRODUCT FEATURES • • • • • • • • • The Industrial Power over Ethernet Splitter receives a unified PoE signal (data and power) via UTP/STP cable, and then separates the data from the power. The power is applied to two different outputs for non PoE devices which are not compliant with the IEEE802.3af standard. Supports 10/100/1000T for PoE in and data out Power isolation and short circuit protection for power output Auto disconnection for over power voltage input Supports Output power up to 25W at 24VDC Temperature - 40°C to 75°C IP-30 protection DIN rail or panel mount Provides EFT protection 3,000VDC for power line Supports 6,000 VDC Ethernet ESD protection Ordering Information Model Number description EPSG202 Industrial PoE Splitter for 10 /100/1000T High Power PoE Accessories MDR-60-48 - DIN Rail Power supply 48VDC, 60W ERS35 - DIN Rail 1 Meter 35 mm Steel C5UMB3FBL - 3 ft. (1 M) - Blue - Category 5e UTP Patch Cord www.bb-elec.com | EPSG202_3713ds Industrial High Power PoE Splitter for 10/100/1000T EPSG202 specifications IEEE Standard Compliance IEEE 802.3 802.3. 10Base-T Ethernet IEEE 802.3u 100Base-TX and 100Base-FX Fast Ethernet IEEE 802.3x Flow Control and Back Pressure IEEE 802.3af Power Over Ethernet Interface Data and power in: 1 x RJ-45. Data pin 1, 2, 3, 6, 4, 5, 7, 8 Connector Power pin: 4,5(V+) , 7,8(V-) or 1,2(V+) , 3,6(V-) Data out: 1 x RJ-45, Data pin 1, 2, 3, 6, 4, 5, 7, 8 Power out: 1x 6 pin Terminal Block ESD Protection 6000V ESD Protection LED Indicators System Power (Green) Regulatory Safety UL / cUL 508 / CE/EN60950-1 CE EN61000-6-2 CE EN61000-6-4 CE EN61000-4-2 (ESD) EMC CE EN61000-4-3 (RS) CE EN61000-4-4 (EFT) CE EN61000-4-6 (CS) CE EN61000-4-8 (Magnetic Field) Free Fall IEC60068-2-32 Shock IEC60068-2-27 Vibration IEC60068-2-6 Power Input Voltage Power Output Protection Power Connection Wire Size Power Use EFT Protection Environmental Operating Temperature Storage Temperature Operating Humidity Mechanical Enclosure Mounting Dimensions 17.6 W @ 48 VDC Power Isolation, Short Circuit Protection Removable Terminal Block (output power) 12 to 24 AWG 30.8 Watts 3000 V EFT Protection - 40 to 75°C (-40 to 167°F) - 40 to 85°C (-40 to 185°F) 5 to 95% (Non-condensing) IP30 Metal Enclosure 35 mm DIN Rail or Panel Mount Attachments 3 cm (W) x 9.5 cm (D) x 14 cm (H) 1.18 x 3.74 x 5.51 inches Mechanical Diagram 3 cm 1.18 in 9.5 cm 3.74 in 14 cm 5.51 in orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-EPSG202 价格&库存
很抱歉,暂时无法提供与“BB-EPSG202”相匹配的价格&库存,您可以联系我们找货
