BB-SD-15C-24
BB-SD-15C-24
    B+BSMARTWORX
    DC/DC CONVERTER 24V 15W
BB-SD-15C-24 数据手册
SD-15 15W Single Output DC-DC Converter Ultra Compact Modbus Gateways series ■ Models MESP211D, MESP211T www.advantech-bb.com PRODUCT FEATURES SPECIFICATION MODEL SD-15A-05 DC VOLTAGE RATED CURRENT OUTPUT 5V 3A SD-15B-05 • • • • SD-15C-05 • Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 Modbus Flexibility – Serial & Ethernet, Masters & Slaves View Messaging Status in Real Time Ultra Compact IP30 Metal Enclosure SD-15A-24 SD-15B-24 SD-15C-24 SD-15A-12 SD-15B-12 SD-15C-12 International Power Supply (included 12V 24V 1.25A 0.625A CURRENT RANGE 0 ~ 3A 0 ~ 1.25A 0 ~ 0.625A RATED POWER 15W 15W 15W RIPPLE & NOISE (max.) Note.2 100mVp-p VOLTAGE ADJ.RANGE 4.75~5.5VDC Models MESP211D and MESP211T, Vlinx™ series Modbus Gateways, connect ±2.0% VOLTAGE TOLERANCE Note.3 Modbus devices to Ethernet networks and let you monitor and control Modbus ±0.5% LINE REGULATION 120mVp-p 10.8~13.2VDC ORDERING INFORMATION ±1.0% ±0.3% MODEL NUMBER devices from anywhere on the Ethernet LAN or WAN. Supporting up to 16 ±0.5% ±0.3% LOAD REGULATION MESP211D masters and 32 slaves, these gateways feature an auto-detecting 10/100 SETUP, RISE ,HOLD UP TIME 2.5s, 25ms,--- 12VDC/24VDC/48VDC atMESP211T full load Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485 VOLTAGE RANGE A: 9.2 ~18VDC B:18 ~ 36VDC C:36~72VDC communications viaEFFICIENCY(Typ.) a DB9 male or a terminal block connection. PROTOCOL RS-232/422/485 RS-232/422/485 150mVp-p 21.6~26.4VDC ±1.0% SERIAL ETHERNET ±0.2% PORT PORT ±0.2% DB9 Male 1 Removable 1 Terminal Block ETHERNET CONNECTOR RJ45 RJ45 79% 78% 70% 77% 76% 76% 75% 72% 1.9A/12VDC 0.9A/24VDC 0.45A/48VDC The product is built for use in industrial environments a heavy-duty 105with ~160% rated outputmetal power ACCESSORIES OVER LOAD or DIN rail mountable (with optional adapters). enclosure that is panel (standard) Protection type : Hiccup mode, recoversSMI6-12-V-P5 automatically -after fault Power condition is removed Included Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, PROTECTION The product can be supplied with a DC power source ranging from 10 to 30 International AC Blades 13.8~ 16.2V 27.6 ~ 32.4V 5.75 ~ 6.75V VDC and features aOVER barrelVOLTAGE connector. A power supply is included. Protection type : Shut off o/p voltage, clamping by zener diode DRAD35 - Optional DIN rail adapter clip (pair) 68% INPUT DC CURRENT(Typ.) WORKING TEMP. -10 ~ +60℃ (Refer to "Derating Curve")232NM9 - Optional mull modem crossover cable EMC EMISSION Compliance to EN55032(CISPR32) Ease of Use WORKING HUMIDITY 20 ~ 90% RH non-condensing Configuration, upgrades and monitoring of the serial-20 server are 10 simple, ~ +85℃, ~ 95%easy RH STORAGE TEMP., HUMIDITY ENVIRONMENT tasks with Vlinx Manager Software. It installs on your PC giving access ±0.03%/℃ (0 ~ 50℃)to TEMP. COEFFICIENT the serial server via VIBRATION your desktop. Remotely manage Modbus Gateway 10the ~ 500Hz, 2G 10min./1cycle, 60min.each along X, Y, Z axes over a LAN or WAN WITHSTAND via the build-in web server. This is helpful for off-site I/P-O/P:1.5KVAC I/P-FG:1KVAC O/P-FG:0.5KVAC VOLTAGE SAFETY &andISOLATION troubleshooting can be done with an ordinary web browser. I/P-O/P,I/P-FG,O/P-FG:100M Ohms / 500VDC / 25℃/ 70% RH RESISTANCE EMC (Note 4) Software Support EMC IMMUNITY Compliance to EN61000-4-2,3,4,6,8, EN55024, light industry level, criteria A Windows XP (32/64MTBF bit), 2003 Server (32/64 bit), Vista 32/64 2008 Server 652.5K hrs min.(SD-15B) 644.2K hrsbit), min.(SD-15A) 653.5K Hrs min.(SD-15C) (32/64 OTHERS bit), WindowsDIMENSION 7 (32/64 bit), Windows 8 (32/6478*51*28mm bit), Windows 10 (32/64 (L*W*H) 0.18Kg,60 PCS/11.8Kg PACKING bit). NOTE MIL-HDBK-217F (25℃) ℃      File Name:SD-15-SPEC 2017-07-14 All product specifications are subject to change without notice. MESP211D & MESP211T_3617ds orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 SD-15 15W Single Output DC-DC Converter Mechanical Specification Case No. 931A series Unit:mm 7.62 1 2 4 2-M3 L=4 25.4 6 .6 2 51 3 5 +V ADJ. LED 55 10.5 78 14max. Pin No. 4 5 Assignment DC INPUT V+ DC INPUT VFG Assignment DC OUTPUT +V DC OUTPUT -V 2-M3 L=6 14 Pin No. 1 2 3 28 Terminal Pin No. Assignment 66.5 Block Diagram 2.75 fosc : 96KHz POWER SWITCHING EMI FILTER I/P PWM CONTROL OLP RECTIFIERS & FILTER +V -V DETECTION CIRCUIT Derating Curve 100 80 LOAD (%) 60 40 20 -10 -10 0 10 20 30 40 50 45 60 55 (HORIZONTAL) (VERTICAL) AMBIENT TEMPERATURE (℃) File Name:SD-15-SPEC 2017-07-14
BB-SD-15C-24 价格&库存
很抱歉,暂时无法提供与“BB-SD-15C-24”相匹配的价格&库存,您可以联系我们找货
