BB-SD-25A-24
BB-SD-25A-24
    B+BSMARTWORX
    DC/DC CONVERTER 24V 26W
BB-SD-25A-24 数据手册
SD-25 25W Single Output DC-DC Converter Ultra Compact Modbus Gateways Models MESP211D, MESP211T OUTPUT SD-25A-5 DC VOLTAGE 5V RATED CURRENT CURRENT RANGE RATED POWER ■ ‧ ‧ www.advantech-bb.com ‧ ‧ ‧ ‧ ‧ ‧PRODUCT  FEATURES ‧•  Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 SPECIFICATION MODEL series SD-25B-5 • Modbus Flexibility – Serial & Ethernet, Masters & Slaves • View Messaging Status in Real Time • Ultra Compact IP30 Metal Enclosure SD-25C-5 SD-25A-12 SD-25B-12 SD-25C-12 SD-25A-24 SD-25B-24 • International Power Supply (included 12V 24V 5A 2.1A 1.1A 0 ~ 5A 0 ~ 2.1A 0 ~ 1.1A 25W 25.2W 26.4W RIPPLE & NOISE (max.) Note.2 100mVp-p 120mVp-p 150mVp-p VOLTAGE ADJ. RANGE 11 ~ 16VDC 23 ~ 30VDC 4.5 ~ 5.5VDC ™ Models MESP211DVOLTAGE and MESP211T, VlinxNote.3 series Modbus Gateways, connect TOLERANCE ±2.0% Modbus devices toLINE Ethernet networks and let you monitor REGULATION ±0.5% and control Modbus devices from anywhere on the Ethernet LAN or WAN. LOAD REGULATION ±0.5%Supporting up to 16 masters and 32 slaves, these gateways feature an auto-detecting 10/100 SETUP, RISE, HOLD UP TIME 2.5s, 50ms, ------ at full load Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485 VOLTAGE RANGE A:9.2 ~ 18VDC B:19 ~ 36VDC communications viaEFFICIENCY a DB9 male(Typ.) or a terminal block 71%connection. 72% 74% INPUT DC CURRENT 3.2A/12V 1.6A/24V 0.8A/48V WORKING TEMP. -10 ~ +60℃ (Refer to "Derating Curve") ±1.0% ORDERING INFORMATION ±0.3% MODEL NUMBER PROTOCOL ±0.3% MESP211D RS-232/422/485 MESP211T C:36 ~ 72VDC RS-232/422/485 ±1.0% SERIAL ±0.2% PORT ±0.2% DB9 Male Removable Terminal Block SD-25C-24 ETHERNET ETHERNET PORT CONNECTOR 1 RJ45 1 RJ45 72% 75% 78% 75% 78% 81% 3.2A/12V 1.6A/24V 0.8A/48V 3.2A/12V 1.6A/24V 0.8A/48V The product is built for use in industrial environments with arated heavy-duty metal 105 ~ 150% output power ACCESSORIES OVERLOAD enclosure that is panel (standard) or DIN rail mountable adapters). Protection(with typeoptional : Hiccup mode, recovers automatically after fault condition is removed SMI6-12-V-P5 - Included Power Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, PROTECTION The product can be supplied with a DC power source from 10 to 30 5.75 ~ ranging 6.75V/10% load 16.8 ~ 20V/10% load 31.5 ~ 37.5V/10% load International AC Blades VOLTAGE VDC and features OVER a barrel connector. A power supply is included. Protection type : Hiccup mode, recovers automatically after fault condition is removed DRAD35 - Optional DIN rail adapter clip (pair) 232NM9 - Optional mull modem crossover cable Ease of Use 20 ~ 90% RH non-condensing WORKING HUMIDITY Configuration, upgrades and TEMP., monitoring of the serial ENVIRONMENT -20 ~ server +85℃, are 10 ~simple, 95% RHeasy STORAGE HUMIDITY TEMP. COEFFICIENT tasks with Vlinx Manager Software. It installs on ±0.03%/℃ your PC giving access to (0 ~ 50℃) 10 ~ 500Hz, 2G 10min./1cycle, the serial server viaVIBRATION your desktop. Remotely manage the Modbus Gateway 60min. each along X, Y, Z axes Design to LVD over a LAN or WANSAFETY via theSTANDARDS build-in web server. This is refer helpful for off-site WITHSTAND VOLTAGE I/P-O/P:1.5KVAC SAFETY &and troubleshooting can be done with an ordinary web browser. I/P-FG:2KVAC O/P-FG:0.5KVAC ISOLATION RESISTANCE EMC EMISSION Software Support EMC (Note 4) I/P-O/P, I/P-FG, O/P-FG:100M Ohms / 500VDC / 25℃/ 70% RH Compliance to EN55032 (CISPR32) Class B EMC EN61000-4-2,3,4,6,8, Windows XP (32/64 bit),IMMUNITY 2003 Server (32/64 bit),Compliance Vista 32/64to bit), 2008 Server EN55024,heavy industry level, criteria A MTBF 374.3K hrs min.(SD-25A) 377.5K Hrs min.(SD-25C) (32/64 bit), Windows 7 (32/64 bit), Windows 8 (32/64 bit), Windows 10 (32/64365.9K hrs min.(SD-25B) 99*97*36mm (L*W*H) OTHERS DIMENSION bit). PACKING NOTE MIL-HDBK-217F (25℃) 0.38Kg; 45pcs/17.8Kg/0.9CUFT ℃      File Name:SD-25-SPEC 2017-07-14 All product specifications are subject to change without notice. MESP211D & MESP211T_3617ds orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 SD-25 25W Single Output DC-DC Converter series Ultra Compact Modbus Gateways Specification ModelsMechanical MESP211D, MESP211T Case No. 905 Unit:mm 36 www.advantech-bb.com 51.5 3.5 2 ψ 9.5 1 3 5.5 PRODUCT FEATURES M 2- 5 20.5 ψ3 . 55.5 8.2 3 97 4 55 • • • • • Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 Modbus Flexibility – Serial & Ethernet, Masters & Slaves View Messaging Status in Real Time Ultra Compact IP30 Metal Enclosure International Power Supply (included 5 4.5 89 99 6.5 87 The product is built for use in industrial environments with a heavy-duty metal Block Diagram enclosure that is panel (standard) or DIN rail mountable (with optional adapters). The product can be supplied with a DC power source ranging from 10 to 30 VDC and features a barrel connector. A power supply is included. EMI FILTER I/P POWER SWITCHING Ease of Use Configuration, upgrades and monitoring of the serial server are simple, easy tasks with Vlinx Manager Software. It installs on your PC giving access to FG PWM the serial server via your desktop. Remotely manage O.L.P. the Modbus Gateway CONTROL over a LAN or WAN via the build-in web server. This is helpful for off-site troubleshooting and can be done with an ordinary web browser. Software Support Derating Curve Windows XP (32/64 bit), 2003 Server (32/64 bit), Vista 32/64 bit), 2008 Server (32/64 bit), Windows 7 (32/64 bit), Windows 8 (32/64 bit), Windows 10 (32/64 bit). SD-25B,C/12,24 ORDERING INFORMATION SERIAL Terminal Pin No. Assignment MODEL NUMBER PROTOCOL PORT Pin No. Assignment MESP211D RS-232/422/485 1 DC INPUT VMESP211T 2 RS-232/422/485 DC INPUT V+ 3 FG ACCESSORIES RECTIFIERS DRAD35 - Optional DIN rail adapter clip (pair) LOAD (%) 60 40 20 -10 -10 0 0 10 20 30 40 50 45 AMBIENT TEMPERATURE (℃) 60 55 (VERTICAL) (HORIZONTAL) +V -V & 232NM9 -FILTER Optional mull modem crossover cable DETECTION CIRCUIT O.V.P. Static Characteristics(SD-25C-24V) OUTPUT VOLTAGE (V) SD-25A SD-25B-5 SD-25C-5 RJ45 SMI6-12-V-P5 - Included Power Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, fosc : 83KHz International AC Blades 100 80 ETHERNET ETHERNET PORT CONNECTOR RJ45 Pin No. Assignment DB9 Male 1 4 DC OUTPUT +V Removable 1 DC OUTPUT -V 5 Terminal Block 32 350 28 300 24 250 20 200 16 150 12 100 8 50 25 30 35 40 45 50 55 60 65 70 OUTPUT RIPPLE (mVp-p) 36 28 17.5 7 Models MESP211D and MESP211T, Vlinx™ series Modbus Gateways, connect Modbus devices to Ethernet networks and let you monitor and control Modbus .5 .5 ψ3 M3 devices from anywhere on the2 -Ethernet LAN or WAN. Supporting up to 16 ψ3 masters and 32 slaves,18these gateways feature an auto-detecting 10/100 74 Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485 communications via a DB9 male or a terminal block connection. 72 INPUT VOLTAGE (V) All product specifications are subject to change without notice. MESP211D & MESP211T_3617ds File Name:SD-25-SPEC 2017-07-14 orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-SD-25A-24 价格&库存
很抱歉,暂时无法提供与“BB-SD-25A-24”相匹配的价格&库存,您可以联系我们找货
