BB-VESR321
BB-VESR321
    B+BSMARTWORX
    ETHERNET TO SER RS-232/422/485
BB-VESR321 数据手册
Isolated Industrial Ethernet Serial Servers VESR321 Series PRODUCT FEATURES • • • • • • • Take control of your serial devices with Vlinx™ VESR321 Isolated Industrial Ethernet Serial Servers. Easy to use Vlinx™ Manager software puts access to your whole shop right on your desktop. Configure your serial devices, upgrade firmware and monitor activity from a single location. The data ports are isolated from one another and also from the power supply. Multiple fiber optic options make integration into any existing network quick and easy. Choose from Multi-mode LC and Single-mode LC. Three-way, 2 kV isolation Ethernet enable serial devices Direct IP, virtual COM port, or paired mode Ethernet pass-through port available Ethernet fiber options Serial RS-232/422/485 port NEMA TS2 (VESR321) Ordering Information Model Number Ethernet Port Ethernet Fiber Ports 2 RJ45 0 VESR321 † VESR321-ML 1 RJ45 1 LC multi-mode optical VESR321-SL 1 RJ45 1 LC single-mode optical All Models RS-232/422/485 All Models DB9 or Removable Terminal Block Includes DIN Rail clips and Panel Mount Brackets † NEMA TS2 Accessories VESR321 series servers also feature an additional copper pass-through RJ45 port that functions like an unmanaged switch, allowing you to connect another Ethernet device or PC work-station. Heartbeat connectivity keeps the serial server on-line. If connectivity is lost it attempts to reconnect every five seconds until a connection is regained. A manual reboot is not required when communications are restored. PS12BVLB-INT-MED - Medical Power supply 24VDC 1.7A TBKT2 - Replacement Terminal block, 5 position ERS35 - 1M DIN Rail 35mm Mechanical diagram 13.823 cm 5.442 in 8.633 cm 3.399 in VESR321 3.500 cm 1.378 in VESR321-ML, VESR321-SL * Fiber Product Options www.bb-elec.com | VESR321 Series_3713ds Isolated Industrial Ethernet Serial Servers VESR321 Series specifications Port to Port Isolation Serial to Ethernet 2 kV Serial to Power 2 kV Ethernet to Power 1.5 kV Power Source External Input Voltage 10 to 48 VDC (58 VDC Maximum) Removable Terminal Block (12 – 28 AWG and barrel Connector connector) Power Consumption 4W Mechanical LED Indicators Ready, Power, Serial Data, Ethernet Speed, Ethernet Link Switches Reset Button (Mode) Dimensions 13.823 x 8.633 x 3.500 cm (5.442 x 3.399 x 1.378 in) Enclosure DIN Rail, Panel, metal, IP30 Weight 635 g (1.4 lbs) Environmental Operating Temperature -40 to 80°C (-40 to 176°F) Operating Humidity 10 to 95% Non-condensing Storage Temperature -40 to 85°C MTBF 86,882 hours Based on MIL 217F using Parts Count Reliability MTBF Calc Method Prediction Network Serial Memory 8 KB per port Network Memory 8 KB LAN 10/100 Mbps Auto-detecting, 10BaseT or 100BaseTX IEEE 802.3 auto detecting & auto MDI/MDX, 10BaseT Ethernet and 100Base TX Protocols Protocols TCP, IPv4, UDP, ARP, HTTP 1.0, ICMP/PING, DHCP/BOOTP IP Mode Static, DHCP TCP/UDP User definable other Connection Mode Server, Client, VCOM, Paired Client Connection At power up or upon data arrival Search Serial direct COM and Ethernet Auto Search or specific IP Display PC IP, ping, test VCOM, save test config (text Diagnostics readable) Firmware Upgrade Vlinx Manager Configuration Software Win XP (32/64 bit), 2003 Server (32/64 bit), Vista (32/64 Vlinx Manager bit), 2008 Server (32/64 bit), Win 7 (32/64 bit), Windows 2008 Server ethernet pass-through port Standards IEEE 802.3, 802.3u, 802.3x Store and Forward with 802.3x full duplex, non blocking Processing Type flow control Flow Control IEEE 802.3x flow control, back pressure flow control MAC Address Table 2K Serial Technology RS-232 TD, RD, RTS, CTS, DTR, DSR, DTD, GND RS-485 2-Wire Data A(-), Data B(+), GND RS-422/485 4-Wire TDA(-), TDB(+), RDA(-), RDB(+), GND Serial Connector DB9M RS-232, Terminal Block RS-422/485 Data Rate Up to 230.4 Kbps Approvals / Certifications Emissions FCC Class B, CISPR Class B (EN55022), NEMA TS2 (VESR321) CE EN61000-6-2:2005 (Heavy Industrial) EN61000-4-2:2008 (ESD) +/-8kV Contact, +/-15kV Air 10V/m, 80-1000MHz; 3V/m, 1.3 EN61000-4-3:2006 (RI) to 2.7 GHz DC ports; +/-1kV signal EN61000-4-4:2004 (EFT Burst) +/-2kV ports +/- 0.5 kV DC Ports, +/- 1 kV EN61000-4-5:2005 (Surge) Signal Ports EN61000-4-6:2005 (CI) 10 VRMS, 0.15 to 80 MHz EN61000-4-8:2001 (Magnetic) 10A/m, 50Hz & 60Hz Shock IEC60068-2-27 50G peak, 11ms, 3 axes Vibration IEC60068-2-6 10-500Hz, 4G, 3 axes Freefall IEC60068-2-32 10 total drops from sides, corner and edges, 1M (Drop) Fiber optic SPECIFICATIONS Mode and Wavelength OUtput power Distance Multi-mode (2 km) 1310 nm -23 to -14 dBm Single-mode (15 1310 nm 15 to -8 dBm km) Single-mode (40 1310 nm -5 to 0 dBm km) Single-mode (80 1550 nm -5 to 0 dBm km) receive sensitivity
BB-VESR321 价格&库存
很抱歉,暂时无法提供与“BB-VESR321”相匹配的价格&库存,您可以联系我们找货
