BB-WDR-120-24
BB-WDR-120-24
    B+BSMARTWORX
    AC/DC CONVERTER 24V 120W
BB-WDR-120-24 数据手册
120W Single Output Industrial DIN RAIL Power Supply WDR-120 series ■ Features : Single and two phase wide input range 180 ~ 550VAC Protections: Short circuit / Overload / Over voltage / Over temperature Cooling by free air convection Built-in constant current limiting circuit Can be installed on DIN rail TS-35/7.5 or 15 UL508(industrial control equipment)approved EN61000-6-2(EN50082-2) industrial immunity level 100% full load burn-in test Built-in DC OK relay contact 3 years warranty SPECIFICATION WDR-120-12 Ultra MODEL Compact Modbus Gateways WDR-120-24 WDR-120-48 DC VOLTAGE Models MESP211D, MESP211T 12V 24V 48V RATED CURRENT 10A 5A CURRENT RANGE 0 ~ 10A 0 ~ 5A RATED POWER 120W 120W 120W RIPPLE & NOISE (max.) Note.2 120mVp-p 120mVp-p 150mVp-p VOLTAGE ADJ. RANGE 24 ~ 29V ±1.0% 48 ~ 58V ±1.0% OUTPUT 12 ~ 15V VOLTAGE TOLERANCE Note.3 ±1.5% 2.5A 0 ~2.5A ±0.5% • Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 • Modbus Flexibility – Serial & Ethernet, LOAD REGULATION ±0.5% ±0.5%Masters & Slaves View Messaging Status in Real 70ms, Time 10ms/230VAC at full load SETUP, RISE, HOLD UP TIME 2000ms, 70ms, • 50ms/400VAC 2000ms, • Ultra Compact IP30 Metal Enclosure VOLTAGE RANGE 180 ~ 550VAC 254 ~ 780VDC • International Power Supply (included ±0.5% FREQUENCY RANGE 47 ~ 63Hz EFFICIENCY (Typ.) 89.5% / 400V 92% / 400V AC CURRENT INRUSH CURRENT (max.) 0.7A/400VAC 1.2A/230VAC COLD START 50A LINE REGULATION INPUT PRODUCT FEATURES www.advantech-bb.com ±0.5% 91% / 400V ±0.5% ™ LEAKAGE
BB-WDR-120-24 价格&库存
很抱歉,暂时无法提供与“BB-WDR-120-24”相匹配的价格&库存,您可以联系我们找货
