ZP9D-115RM-LR-AU
ZP9D-115RM-LR-AU
    B+BSMARTWORX
    ZLINX RADIO MODEM, 115K, 900MHZ,
ZP9D-115RM-LR-AU 数据手册
Industrial Grade Radio Modems – Up to 40mi/64km Range Zlinx Wireless Radio Modems PRODUCT FEATURES • • • • • • • • • • Do you need to get a digital signal across a highway or river or to the other end of your big warehouse? Zlinx radio modems can do the job faster, easier, and less expensively than stringing cable. Easy plug-andplay set-up saves installation and maintenance time. These compact and rugged units are compatible with Modbus and Profibus so no additional converters are required. Despite their low prices, these are not wimpy consumer or office grade products. Select the power level you need to punch through whatever distance and interference situations you encounter. Zlinx radio modems are built to handle the heat, cold, and environments of industrial operations. RS-232/422/485, Serial communications Modbus compatible – no additional converters needed Ranges up to 40 miles (64 km) Heavy duty DIN mount industrial grade case and components Signal strength indicator aids trouble shooting 900 MHz, 868 MHz, 2.4 GHz Versions Wide temperature range -40º to 85º C Wide Range Power Input: 10 to 48 VDC or 18 to 30 VAC AES Encryption UL Class1/Division2 (Long Range Only) Ordering Information Model Number Description Zlinx Radio Modem 2.4 GHz Short Range, RS ZP24D-250RM-SR 232/422/485 Zlinx Radio Modem 900 MHz Long Range, RSZP9D-115RM-LR 232/422/485 ZP9D-115RM-LR-AU Zlinx Radio Modem 900 MHz Australian Version ZP8D-24RM-LR* Zlinx Radio Modem, 868 MHz, Long Range RM-LR-KIT 900 MHz Radio Modem, Long Range Starter Kit RM-SR-KIT 2.4 GHz Radio Modem Short Range Starter Kit RM-LR824-KIT 868 MHz Radio Modem Kit Kits contain: (2) radio modems, (2) power supplies, 24VDC 30W, and (2) 6ft/1.8m serial cables World-wide. Check with your local distributor for availability and options. * European - Check wireless regulations/standards in your geographic area. Accessories www.bb-elec.com | DR-75-24 75W Power Supply ZP9D-ANT1 900 MHz Spare Antenna ZP24D-ANT1 2.4 GHz Spare Antenna ZP9D-DIN1 Replacement DIN clip kit for ZP9D radio modems ZP24D-DIN1 Replacement DIN clip kit for ZP24D radio modems ZP9D-TB1 Replacement terminal block kit for radio modems. Contains complete set of terminal blocks and dip switch cover DRPM25 Panel Mount Adapter Zlinx Wireless Radio Modems_3713ds Industrial Grade Radio Modems – Up to 40mi/64km Range Zlinx Wireless Radio Modems MODEL NUMBER: RF Properties Standard Range(with included antenna) Frequency Transmit Power Software Support Features Included Omni Antenna ZP24D-250RM-SR ZP8D-24RM-LR     IEEE 802.15.4 Proprietary Radio up to 300ft/91m indoor Up to 24.9mi/40km outdoor or 1mi/1.6km outdoor 2.4 GHz 868 MHz 100mW 316mW     Win XP, Win 7 RSSI signal range test Modem emulation ZP9D-115RM-LR   Proprietary Radio up to 3000ft/.91km indoor or 14mi/22.5km outdoor 900 MHz 1W   2.1 dBi 3 dBi 3 dBi Antenna Connector Serial Properties Baud Data Bit; Parity; Stop Bit RS-232 RS-422 RS-485 Wireless Link Failure External Reverse Polarity SMA male jack connector, omni directional (included with product)       1200, 2400, 4800, 9600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 19200, 38400, 57600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400 115200 115200, 230400 7, 8; None, even, odd, mark, 7, 8; None, even, odd, mark, space; 1, 2 8 only; none only; 1 only space; 1, 2 DB9F DCE or Terminal Block (TX, RX, GND available on Terminal Block Removeable terminal block, 2 or 4 wire - TX+, TX-, RX+, RX-, GND, 120 Ohm Dipswitch selectable Removeable terminal block, 2 or 4 wire - TX+, TX-, RX+, RX-, GND, Bit wise, 120 Ohm Dipswitch selectable Removeable terminal block, Open collector, dry contact, 40mA Power Power Supply Power Consumption Dimensions Environmental Operating Temperature Storage Temperature Operating Humidity Enclosure Rating Rating Mounting LED Status Certifications FCC CE UL RoHS directive (lead free) 10-48 VDC, 18-30 VAC, Removeable terminal block 2.0W max 6W max 5.0W max 1.2W x 3.3D x 4.7H       -40° to 85ºC -40° to 85ºC 10 to 90% non-condensing       IP30 DIN rail mount, 35mm Power, Signal Strength, Wireless Data       FCC Part 15 Class B CISPR (EN55022) Class B EN61000-6-1 Generic Standards for Residential, Commercial, & Light Industrial EN61000-4-2-ESD, EN61000-4-3 RFI, EN61000-4-4 EFT, EN61000-4-5 Surge, EN61000-4-6 CI, EN61000-4-8 Power Frequency Magnetic, EN61000-4-11 Voltage Dips & Interruptions UL, cUL UL, cUL UL, cUL, Class 1 Div 2 Groups A, B, C, D File E245458 Yes orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
ZP9D-115RM-LR-AU 价格&库存
很抱歉,暂时无法提供与“ZP9D-115RM-LR-AU”相匹配的价格&库存,您可以联系我们找货
