KLDHCX-8-0202-B
KLDHCX-8-0202-B
    KYCON
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 通孔,直角
KLDHCX-8-0202-B 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDHCX-8-0202-A Part Number Builder KLDHCX-8-0202 A Series Diameter DC POWER CONNECTORS: KLDHCX Series High Current Thru-hole Power Jack Product Features 2.0mm and 2.5mm. Laptop and Palm Computers, Portable Modems, Radar Detectors, and Other Portable Device Applications. Series KLDHCX-8-0202 - High Current Thru-hole DC Power Jack Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Performance Specifications Materials and Finish Housing: PBT Thermoplastic, UL94V-0 Rated, Black Color Contact Materials Center Pin: Copper, Nickel Plated Contact #1: Brass,Silver Plated over Nickel Underplate Contact #2: Copper Alloy, Silver Plated over Nickel Underplate Spring: Copper Alloy, Silver Plated over Nickel Underplate Shield: Brass, Nickel Plated Contact Kycon For Other Option KLDHCX-8-0202 Series Dimensions in mm KLDHCX-8-0202-x Spring Electrical Characteristics Rated Current: 8A Rated Voltage: 24V DC Insulation Resistance: 100 Megohms Min. at 500V DC Contact Resistance: 30 milliohms Max. Dielectric Withstanding Voltage: 500V for 1 Minute Mechanical Characteristics Insertion Force: 0.3kg - 3.0kg Withdrawal Force: 0.3kg - 3.0kg Durability: 5000 Mating Cycles Min. Operating Temperature: -25°C to +85°C Recommended for Use with Tuning Fork Style Plug. Kycon Part Numbers: KLDX-PA-0202-A-LT KLDX-PA-0202-B-LT Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0423
KLDHCX-8-0202-B
- 物料型号:KLDHCX-8-0202-A - 器件简介:KLDHCX系列是高电流通孔直流电源插座,适用于笔记本电脑、掌上电脑、便携式调制解调器、雷达探测器等便携设备。 - 引脚分配:中心针直径有2.0mm和2.5mm两种规格。 - 参数特性: - 额定电流:8A - 额定电压:24V DC - 绝缘电阻:最小100兆欧姆 - 接触电阻:最大30毫欧姆 - 介质耐压:500V,持续1分钟 - 功能详解:具有调谐叉式接触,推荐与调谐叉式插头一起使用。 - 应用信息:适用于需要高电流传输的便携设备。 - 封装信息:外壳材料为PBT热塑性塑料,符合UL94V-0标准,颜色为黑色。接触材料包括铜镀镍中心针、黄铜镀银接触点等。 - 机械特性:插入力和拔出力在0.3kg至3.0kg之间,耐用性至少为5000次配对周期,工作温度范围为-25°C至+85°C。
KLDHCX-8-0202-B 价格&库存
很抱歉,暂时无法提供与“KLDHCX-8-0202-B”相匹配的价格&库存,您可以联系我们找货
KLDHCX-8-0202-B
  • 1+19.750651+2.54800
  • 10+16.7923210+2.16635
  • 25+15.7408025+2.03070
  • 50+14.9874650+1.93351
  • 100+14.27134100+1.84112
  • 250+13.37742250+1.72580
  • 500+12.73891500+1.64343
  • 1000+12.130911000+1.56499
  • 2500+11.371882500+1.46707
库存:3567
