GM67X-CBL-304-P
GM67X-CBL-304-P
    KYCON
    模块化电缆 插孔至插头 8p8c(RJ45,以太网) 无屏蔽
GM67X-CBL-304-P 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GM67X-CBL-152-P Part Number Builder LR78160 GM67X-CBL 152 P Series Cable Length Plug Option IP67 Connectors: GM67X-CBL Series Box Side, IP67 Panel Mount Jack with Cable and Plug (Must Be Used with GM67X Series Cable Side Part) Product Features Series GM67X-CBL - Panel Mount IP67 Modular Jack with Cable and plug Cable Length 152 - 152mm 304 - 304mm IP67 Panel Mount Cable and Plug Termination Cat. 5 Cable UTP Optional Cap Available Plug Option P - Plug Performance Specifications Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Materials and Finish Housing Material Polycarbonate, UL 94V-0 Rated, Black Color Contact Material Phosphor Bronze Nut Material Polycarbonate, UL 94V-0 Rated, Black Color Gasket Material Silicone, UL 94HB Rated, Red Color Contact Kycon For Other Option GM67X-CBL Series Dimensions in mm GM67X-CBL-xxx-P Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V AC RMS for 1 Minute Contact Resistance 50 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Durability 1000 Mating Cycles Min. Operating Temperature -40°C to +80°C Note Plating Option *Must be used with GM67X series cable side part *Kycon can provide custom cable assemblies (mins will apply) Nut Gasket *Kit includes cable, nut, and gasket Recommended Nut Torque: 12 Kgf-cm Click here for our assembly videos Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0915
GM67X-CBL-304-P 价格&库存
很抱歉,暂时无法提供与“GM67X-CBL-304-P”相匹配的价格&库存,您可以联系我们找货
