2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
GSGX-NS-2-88
Part Number Builder
LR78160
MODULAR JACKS AND PLUGS:
GSGX Series
Right Angle Ganged Jack
Product Features
Available in up to 12 Ports
Available Fully Shielded for Category 5 Applications
High Temperature Reflow Compatible Option Avaliable
CSA/NRTL Certified File No. LR78160
UL File No. E134345
Performance Specifications
Materials and Finish
Housing Material
PBT Thermoplastic, Glass Filled, UL 94V-0 Rated,Black Color
Shield Material
Copper Alloy, Nickel Plated
Contact Material
Phosphor Bronze
Electrical Characteristics
Insulation Resistance
500 Megohms Min.
Dielectric Withstanding Voltage
1000V RMS, 60Hz
Contact Resistance
20 milliohms Max.
Current Rating
1.5A
Voltage Rating
125V DC
Operating Temperature
-40°C to +85°C
Durability
500 Mating Cycles Min.
GSGX
NS
2
8
8
Series
Shield
Option
No. of
Port
No. of
Positions
No. of
Contacts
Ground Pin
Spacing
Plating
Option
Series
GSGX - Right Angle Ganged Jack
Shield Options
N - Non-Shielded
NS - Shielded
Number of Ports
2 - 2 Port
4 - 4 Port
5 - 5 Port
6 - 6 Port
8 - 8 Port
10 - 10 Port (Only with 3.68mm Ground Pin Spacing)
12 - 12 Port (Only with 3.68mm Ground Pin Spacing)
Number of Positions / Contacts
88 - 8 Positions / 8 Contacts
Ground Pin Spacing
Blank - 3.68mm Ground Pin Spacing
4.57 - 4.57mm Ground Pin Spacing (Only with NS option)
Plating Option
Blank - Standard
50 - 50µ" Gold Plating
Contact Kycon for Other Options
GSGX Series
Dimensions in mm
GSGX-N-x-88
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
很抱歉,暂时无法提供与“GSGX-N-3-88”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+34.58160
- 160+13.80240
- 480+13.33800
- 960+13.11120
