GSGX-N-8-88
GSGX-N-8-88
    KYCON
    插件
    GANGJACK 8PORT RT< 8P8C BLACK RO
GSGX-N-8-88 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GSGX-NS-2-88 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GSGX Series Right Angle Ganged Jack Product Features Available in up to 12 Ports Available Fully Shielded for Category 5 Applications High Temperature Reflow Compatible Option Avaliable CSA/NRTL Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, Glass Filled, UL 94V-0 Rated,Black Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS, 60Hz Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability 500 Mating Cycles Min. GSGX NS 2 8 8 Series Shield Option No. of Port No. of Positions No. of Contacts Ground Pin Spacing Plating Option Series GSGX - Right Angle Ganged Jack Shield Options N - Non-Shielded NS - Shielded Number of Ports 2 - 2 Port 4 - 4 Port 5 - 5 Port 6 - 6 Port 8 - 8 Port 10 - 10 Port (Only with 3.68mm Ground Pin Spacing) 12 - 12 Port (Only with 3.68mm Ground Pin Spacing) Number of Positions / Contacts 88 - 8 Positions / 8 Contacts Ground Pin Spacing Blank - 3.68mm Ground Pin Spacing 4.57 - 4.57mm Ground Pin Spacing (Only with NS option) Plating Option Blank - Standard 50 - 50µ" Gold Plating Contact Kycon for Other Options GSGX Series Dimensions in mm GSGX-N-x-88 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
GSGX-N-8-88 价格&库存
很抱歉,暂时无法提供与“GSGX-N-8-88”相匹配的价格&库存,您可以联系我们找货
